thisismatt Posted April 29, 2022 Report Share Posted April 29, 2022 DT2 looks correct to me. I zoomed that pic to the same size as my 521 ignition key and it looks right. The only difference looks like the shoulder is shorter than my original. Quote Link to comment
kcmwalker Posted June 1, 2022 Author Report Share Posted June 1, 2022 Quote On 4/28/2022 at 8:22 PM, thisismatt said: Or DT2... 😅 https://keymateinc.com/shop-online/key-blanks/automotive-keys/metal-head/ilco-dt2-key-blank-nissan-detail.html Spoke with keymate and they say ilco has discontinued the DT2. I finally found a locksmith who was willing to experiment on a couple more commonly available keys and we found the DT13 works in place of a DT2, but has to be cut down to size. Quote Link to comment
thisismatt Posted June 2, 2022 Report Share Posted June 2, 2022 3 hours ago, kcmwalker said: Spoke with keymate and they say ilco has discontinued the DT2. I finally found a locksmith who was willing to experiment on a couple more commonly available keys and we found the DT13 works in place of a DT2, but has to be cut down to size. But you were able to confirm that DT2 is the correct keyway and length? Quote Link to comment
kcmwalker Posted June 2, 2022 Author Report Share Posted June 2, 2022 10 hours ago, thisismatt said: But you were able to confirm that DT2 is the correct keyway and length? Yes, I verified with keymate that the DT2 would have been the correct blank for my truck. Interestingly enough, Ilco still has the DT3 available. 1 1 Quote Link to comment
thisismatt Posted June 3, 2022 Report Share Posted June 3, 2022 There are some on eBay, but kind of overpriced Quote Link to comment
kcmwalker Posted August 17, 2023 Author Report Share Posted August 17, 2023 Hello again everyone. It's been a solid year of headaches and joy with the 521, but now both my front wheel cylinders are leaking and I've lost the breaks a couple times. I've pulled, cleaned and reassembled the cylinders, but they both still leak once the system is pressurized. Most importantly, I'm looking for a dual master cylinder that will fit a '71 521 and I'd like to swap out for discs on the front at least. Looking to connect with anyone that may have the parts I'm looking for. Any help is much appreciated. Quote Link to comment
Lachlan Posted August 18, 2023 Report Share Posted August 18, 2023 On 4/13/2022 at 10:11 AM, datzenmike said: That would explain it. This was almost 50 years ago, I knew less than nothing. Now I know that there is even more I don't know. This is so true in much of life. Quote Link to comment
banzai510(hainz) Posted August 18, 2023 Report Share Posted August 18, 2023 (edited) 2 hours ago, kcmwalker said: I've pulled, cleaned and reassembled the cylinders, I buy new ones https://www.ebay.com/itm/324346648109?fits=Model%3A521+Pickup|Make%3ADatsun&_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D252698%26meid%3D48e4b343d5da4f6a8f5a88f5f32ddad0%26pid%3D101195%26rk%3D3%26rkt%3D12%26sd%3D225231104780%26itm%3D324346648109%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V2V4ItemNrtInQueryAndCassiniVisualRankerAndBertRecallWithVMEV3&_trksid=p2047675.c101195.m1851&amdata=cksum%3A32434664810948e4b343d5da4f6a8f5a88f5f32ddad0|enc%3AAQAIAAABYPqB0EgCndAssfMWNy0AT0GytGzF9%2By0G%2BlcW69DgBK3Qlz4BjwJQqPkN4K8I7qz9GoVciN1QNWqyS8EeqYS8rZRsDvyvw34m3N%2FyJKokwCTIIc3RNym2SNW8ARudP72DyiwgIY0dfUnIr5%2BMZDTaovYy1iTX9HiBj3uklXxZ8umUCYVQWgnkL6yQqtZtXkJC1NMe0jsbvV2eXzLIQhEy6htTUsD5CZWe1acB6dB%2FdLiEMr09RTrjrp%2BzVy1rNgWQyzyy7z9z5RJi0YdvYACvPnAnvHA%2BWeNGKP7cM2PXJsSZyiDeNMMQBA2Q2H%2BNig71YMYI2%2FFtBwPZBa0zrQ7veCuvDY%2BWKO%2Bry0etXhP%2Bvdj89uVrB4%2F6D%2F%2BVi2Aruhde5r7pe6HW1rSwDI79UyjFsBstzjX8EKF3aV0XzSDVnSVcStHFYn90EZHiDeTpfXf3LL0%2FN9yTwS342qt5Mlsa2E%3D|ampid%3APL_CLK|clp%3A2047675&epid=27010443312 Japan would be best but this has everything/Most likely chinese/Taiwan/Italy 521s are SAE size threads. !!!!! Edited August 18, 2023 by banzai510(hainz) Quote Link to comment
banzai510(hainz) Posted August 18, 2023 Report Share Posted August 18, 2023 japan made one https://www.ebay.com/itm/225231104780?fits=Model%3A521+Pickup|Make%3ADatsun&hash=item3470d1eb0c:g:7uIAAOSwuSRjYBZI&amdata=enc%3AAQAIAAAA8H4A5ZFDJp1T5hl2752gQIwoCq6ahDLn9M7SsjINKLwaZlx6MeaAOJE3dSrslsJpQB8nAOXjvOc%2F26VMlEiYCJuEJdZLk2vhv4TIW4%2BB7zAP7o24V7TWdvmK2qTOtviROeaSdnc6zTvYK%2B1F6KQaW24xphrPuhnemygpLNAh5IwmERSARDysbY9JqsV50D2lugInuM7OrAbcibkLhw8muM2VeYOfsQKsc7E7RYeCQRwadJ0gnIHfQ0q%2Bit2UDAJEjD59vrmltlqKGXSyGKB5Ns5v6NxS2Gxpu7AYOXiUwNKstoX%2FYPYXCz44u4%2B4p1rwDA%3D%3D|tkp%3ABk9SR8z2mOPAYg Quote Link to comment
datzenmike Posted August 18, 2023 Report Share Posted August 18, 2023 Cleaning them won't fix worn seals. Either rebuild with new seals.. (I've done this, it's very cheap, if you can find them) or just replace. Before my '71 I had a '68 510. I did take the dual master from it and put it on the 521. The flairs on the brake tubes did not match the master, and I know this will sound insane, but I filed them down and tightened the nuts. It worked just fine. This was almost 50 years ago when I had little money, no tools and less sense. Quote Link to comment
Stoffregen Motorsports Posted August 18, 2023 Report Share Posted August 18, 2023 Cleaning them can make them not leak though. If they get gunk in them from sitting too long they will leak. Moisture buildup causes corrosion and that corrosion can start pushing on the seals. I've had this happen to a few drum brake vehicles, one of which was my Datsun 320. Cleaned the cylinders and good as new. I did also install a residual valve in the 320 to help keep this from happening again, and that did help. Quote Link to comment
