datzenmike Posted January 24, 2009 Report Share Posted January 24, 2009 I always undo the manifold to down pipe bolts and push it over to the side a bit. Course I don't have torsion bars in the way either so this might not help you. Quote Link to comment
lynchfourtwenty Posted January 25, 2009 Report Share Posted January 25, 2009 with my header it was a pain in the ass.. i had the pipe out of the way but the header was still a mother fucker.. did you replace your pilot bushing? lol.. i kept a pry bar handy when puttin the tranny back up under.. really helped to push it away from the exhaust.. also i found that when you initialy get it up under there its most easy to doit with the clutch fork facing down to the ground.. this is a pain in the ass job to do alone.. especialy if you get the tail of the tranny wedged in by where the shifter goes.. then it sits on top of one of the torsion bar bolts... that can REALLY suck.. also it took 2 people because my engine sat crooked an i had to with 1 arm force the header up an over so the engine was straight an with the other arm push up an guide the engine in while my friend pushed.. post pics man!!!!!!!!!! Quote Link to comment
datzenmike Posted January 25, 2009 Report Share Posted January 25, 2009 Hey I had a header on my old 521... took the pass side torsion bar out. That did it!!! Quote Link to comment
lynchfourtwenty Posted January 25, 2009 Report Share Posted January 25, 2009 Hey I had a header on my old 521... took the pass side torsion bar out. That did it!!! thats just the chicken shit way about doin it... :fu: what did you use on the top driver side bolt mopar? i used fairy dust on mine.. oh the lowerd the engine all the way down an scooted it forward lol.. but he really man it just depends on how u wanna doit... as long as the end result is its running and driving (like mine) its all good :D Quote Link to comment
moparvwfreak Posted January 25, 2009 Author Report Share Posted January 25, 2009 its still not totally in but i will be working more on it in the next few days. it rally wasn't hard to pull it. just had to figure out the angles. thank god i have a short tail trans. the ONLY place i got hung up taking it out was the starter bulge. and even that if i rotated it just a few degrees, it came out like butter. i have the new clutch in place witht he new PP but i forgot to change the pilot bushing. gotta find my grease to do that. easy to deal with though. hell i think i have some in my grease gun even. nothing big to deal with. at least i dont have the trans installed yet. OH one BIG question. the input shaft seal is leaking. i yanked the bolts to pull the front hcover and it wont come out. ideas on how to make it come off so i can replace the seal???? Quote Link to comment
lynchfourtwenty Posted January 25, 2009 Report Share Posted January 25, 2009 yea i reccomend grease gun, and a bolt with tape on it lol, did you resurface the fly wheel? or atleast sand it ? little sanding an mine works perfect all grab no slip :) an smooth too Quote Link to comment
moparvwfreak Posted January 25, 2009 Author Report Share Posted January 25, 2009 thats teh route i am going with it. my flywheel looked great sbut while its off i will run a quick sand on it to make it shine as i forgot. Quote Link to comment
moparvwfreak Posted January 28, 2009 Author Report Share Posted January 28, 2009 trans is in. i was NOT able to get the pilot bearing out though. so i'll deal with it later as i need my truck now. even with the exhast in the way it was fairly easy to get up and in. Quote Link to comment
510er Posted January 28, 2009 Report Share Posted January 28, 2009 measure your transmissiono from the front of the bell to the rear and give me the measurement I have access to two 5 speeds, one makes a little noise in first the other makes a little in 5th, but i all i now is that they are both out of early 72 ish 240's which i have been told many times didnt come with 5 speeds but the guy knows his datto shit and swears to me that they are Quote Link to comment
moparvwfreak Posted January 28, 2009 Author Report Share Posted January 28, 2009 measure your transmissiono from the front of the bell to the rear and give me the measurement I have access to two 5 speeds, one makes a little noise in first the other makes a little in 5th, but i all i now is that they are both out of early 72 ish 240's which i have been told many times didnt come with 5 speeds but the guy knows his datto shit and swears to me that they are as far as i know its teh factory short tail transmission. i can measure it tomorrow when i am under buttoning things up. the only issue i have right now with putting a 5spd in is i would have to change my drive shaft length. unless its a dogleg out of a 200sx. but i will take the measurements anyway. and let ya know :D Quote Link to comment
moparvwfreak Posted January 29, 2009 Author Report Share Posted January 29, 2009 well its all in. new clutch, new slave done properly with the exception of the pilot bearing, and i now need a master cylinder to actually have a damn clutch. THIS IS PISSING ME OFF!!!!!!! Quote Link to comment
lynchfourtwenty Posted January 29, 2009 Report Share Posted January 29, 2009 dont worry, once its done its done an it wont give u any trouble for a long time, at least not the clutch.. Quote Link to comment
moparvwfreak Posted January 29, 2009 Author Report Share Posted January 29, 2009 dont worry, once its done its done an it wont give u any trouble for a long time, at least not the clutch.. yeah but it'll be another MONTH or so before i can get the last part. i need the damn truck NOW not in a month. Quote Link to comment
lynchfourtwenty Posted January 29, 2009 Report Share Posted January 29, 2009 you sure it needs a clutch m/c? Quote Link to comment
moparvwfreak Posted January 29, 2009 Author Report Share Posted January 29, 2009 everything else in the clutch system is NEW, EXCEPT that. and not rebuilt new either. Quote Link to comment
lynchfourtwenty Posted January 29, 2009 Report Share Posted January 29, 2009 does it move fluid when you bleed the slave? Quote Link to comment
moparvwfreak Posted January 29, 2009 Author Report Share Posted January 29, 2009 Barely. Went through half a bottle of brake fluid before I said enough. Quote Link to comment
banzai510(hainz) Posted January 29, 2009 Report Share Posted January 29, 2009 Whats wrong??????????? Is it a adjustable slave? or just a rod. Maybe the clutch wasnt bad in the first place?????? Quote Link to comment
moparvwfreak Posted January 30, 2009 Author Report Share Posted January 30, 2009 Whats wrong??????????? Is it a adjustable slave? or just a rod. Maybe the clutch wasnt bad in the first place?????? i now have NO pressure at all in the clutch system. i did before but it wasn't working at all. as fro the slave its just a rod. non adjustable. the clutch looked ok when i pulled it BUt i figured if i am this far i might as well just do it. as it sits i will be throwing a new master in it soon enough and a new hose as well. might as well while the system is open right?? Quote Link to comment
moparvwfreak Posted February 3, 2009 Author Report Share Posted February 3, 2009 master is in. i now have a working clutch! YAAAAAAAAY!!!!!!! but now i get to pull the damn motor and drill out ONE freaking bolt for the damn alt bracket! its teh first one. the stupid one right at teh front of the block. not enough room to get a tap in there let alone a drill. oh and BOTH lower bolts for the alt decided to go AWOL on me. the front one stripped hence why i was pulling the bracket. if its not one thing its another. Quote Link to comment
Phlebmaster Posted February 3, 2009 Report Share Posted February 3, 2009 Awesome about the clutch...sucks about the bolts. :D Quote Link to comment
510er Posted February 3, 2009 Report Share Posted February 3, 2009 shit man that sucks! i know what you mean with the one thing after another Quote Link to comment
ppeters914 Posted February 3, 2009 Report Share Posted February 3, 2009 shit man that sucks! i know what you mean with the one thing after another "One thing...or another...." Wasn't that a Pat Benetar song? :lol: Quote Link to comment
moparvwfreak Posted February 4, 2009 Author Report Share Posted February 4, 2009 "One thing...or another...." Wasn't that a Pat Benetar song? :lol: smartass! :lol: well i still have some adjusting to the master BUT it drives great. and none to soon either. as of midnight the tabs on my Pathfinder are dead and my rabbit truck is running worse than dog ass so..... i needed my truck :D as said i still have some things to adjust but so far shes running top notch. i REALLY need to get my EI dizzy dealt with. Quote Link to comment
datzenmike Posted February 4, 2009 Report Share Posted February 4, 2009 Got those highway blues, cant you hear my motor runnin Flyin down the road with my foot on the floor All the way in town they can hear me comin Dattos about to drop, she wont do no more And I smell my motor burnin Underneath the hood is smoke Cant stop, and I cant stop Got to keep on movin or Ill lose my mind Oh, rockin down the highway Oh, rockin down the highway Oh, rockin down the highway Oh, rockin down the highway..... Doobie Brothers (apologies to Ford) Quote Link to comment
