Por 15
LeDevil
  • Replies 13
I get mine online because after shipping it's still considerably cheaper then anyplace local that will have to order it anyway. I am on the other side of the country though so prob dif your end, just saying.
I have gone through 1.5 gal on my z alone lol. I love por so much.
Just go to http://www.por15.com, that way you can order exactly what you want/need.
Especially since you can order it in various amounts, colors. Remember that POR15 Rust Prevention is UV Sensitive (it goes to a flat look over time), so its best to put a protective coat of paint over it.
The best results are 1 coat, allow to tach for an hour. 2nd Coat of POR15, then once it has tacked after about 3-4 hours, a coat of paint. If you allow it to dry and then spray an acid etch primer on it, it does not etch into the por15 quite as well. You can primer after it has tacked up for a few hours also.
