A14 fun factor
sick620
I am not new to driving datsuns with l series engines, but I am new to A series engines. Just picked up a 78 b210 with an A14. It was last registered in 88 so its going to be a minute before I get it going down the road. I was going to take it apart and do a budget rebuild new gaskets and rings etc, but before I do I'm wondering if these cars can be any fun with the original powerplant. I used to have all kinds of fun in my stock l20b datsun 620's with a weber and not much else done to them, they were not fast but I still was able to goof around in them and have a good time. A series motors have a lot less torque and HP, but these 210 chassis cars are a lot lighter right? after a quick rebuild and weber and maybe headers and exhaust will I have fun in one of these cars with an A series? or are they so god awfully underpowered that there is no way to have any fun and I should just go straight into looking for a l20b. nap z, KA etc?... I just want a fun Datsun I can cruise on the weekends and goof off in a little, I don't care at all about speed, just fun.
I guess what im saying is:
does stock l series car = stock A series car for fun factor?
what are the best bang for buck mods to do to an A series engine to get a horsepower or two when you already have it taken apart doing a basic rebuild?
Edited by sick620
  • Replies 16
If you're willing to redefine what constitutes fun, you'll have a blast. My girlfriend in high school had a B210 and let me tell you, the thing was gutless, but holy christ did we have fun doing it in that Datsun!
Along with a bigger carb and exhaust header, you may get a few ponies out of milling a bit off the head to raze compression and run it on premium.
Edited by paradime
  • Haha 1
doing it or DOING IT? haha was it fun the times you weren't actively DOING IT? 🤣
We tried DOING IT but the car was so damn small I got a cramp.
My first car was a 68' 510, and as are as driving fun goes, there was no comparison.
Haha okay so I should just find a l series or do a carbed ka24e swap probably at the minimum
I love the A motors. Parts interchangeability between A motors is pretty good, with the exception of the A12, which has a front mounted distributor and a driver side mounted alternator. The A12A, A13, A14 and A15 all have mid mounted distributors to make room for the alternator mounted high on the passenger side.
Building power with an A motor will require some internal mods though. As with any engine, a higher compression ratio, better flowing cylinder head and bigger cam do the trick. My parts knowledge for street driven A motors is almost non-existent, as most of the A motors I built were for SCCA GT5 racing, but if you travel over to the tech page at http://datsun1200.com/modules/mediawiki/index.php?title=Datsun_1200_encyclopedia  , you'll find all kinds of part numbers, casting numbers, etc.
Both of my Datsun 320 trucks were A motor swapped and both were really fun to drive. My L320 had a built A12 with a huge cam, some chamber and port work with a later cylinder head and a modified intake manifold and DGV Weber. That truck really did scream, and ran to 8K on a regular basis. The A14 I had in my NL320 was mostly stock, but with a GX head and dual SU carbs. It made more torque and was smooth as hell, but did not have the wow factor of the A12.
I've been racing a 1200 for last 32 years and I run a fairly mild set up. I give this advice every time this subject comes up.
For a street A-series engine go with the following: a Weber 32/36 carb, header, Delta cams 278 grind, 2" exhaust, dual valve springs, GX head gasket and clean up the ports in the head. I port my heads using nothing more than a dremel. The valve seats protrude into the head and restrict the flow. Check Datsun1200.com for.pics of porting.
All of that will get you 15-20hp more than stock. It won't be a rocket but it will rev like mad and be fun.
Edited by Tom1200
On 10/13/2021 at 8:11 PM, Tom1200 said:
I've been racing a 1200 for last 32 years and I run a faulty mild set up. I give this advice every time this subject comes up.
 Ok awesome this sounds like the plan. thanks for the cam grind info. Any benefit to lightening the flywheel?
Flywheels store kinetic energy and release it when starting from a stop to get the heavy ass vehicle moving without excessive revving and slipping the clutch. From then on, they are a liability as every time you speed up, some energy goes into speeding the flywheel up. Course it doesn't go to waste, you get it back when slowing down just like a truck with a heavy load. For strictly accelerating removing some weight frees up some power to move the car. If a race car, you only need enough flywheel to help keep the engine spinning as there are (hopefully) no stops. For the street I wouldn't go overboard lightening it as it adversely affects the take offs. I like to let the clutch up at idle and slowly pull away adding power and clutch for a seamless launch. Revving and slipping isn't for me. I have L4 car, truck and six cylinder L series flywheels. Car 4 cylinder and six cylinder are 21 pounds and trucks are 29. Trucks are 225 and 240mm pressure plates which are also heavier and add mass. The ZX car have heavier crank and rods for added mass. I do have a 21 and a 29 pound 240mm flywheel. The 21 may be from a 240sx?
  • 2 months later...
Where/how do you search/find a gx gasket? been looking on rock auto and eBay….
where do you find dual valve springs?
thanks for this I think I’m going to try this formula!
Edited by sick620
The A motor is a nicely upgraded British motor, it's main weakness was the head gaskets. Things like o rings instead of cork seals. The head gaskets were very easy to replace though. We actually did one on the side of the road in less than a hour on a club run once. Most [including the one in my garage] were simply parked when a gasket failed. Maybe the revival is as easy as this. The B210 5speeds are a direct bolt in, but the Bugeye Sprite guys also can bolt them in and they are kind rare now.
Dennis
