debbheff@gmail.com Posted March 16, 2021 Report Share Posted March 16, 2021 does anyone have a good source for coolant hoses for my 521. i can get upper and lower radiator hoses from O'Reilly's but no matter what search strings i use i cant seem to come up with a source(s) for the smaller molded heater and bypass hoses. any source information appreciated (I havnt contacted the local nissan dealer, yet) Thanks DH 1 Quote Link to comment
mainer311 Posted March 16, 2021 Report Share Posted March 16, 2021 They’re NLA. You won’t find any unless NOS items pop up on eBay or the classifieds on here. There’s a way that you can make you own by cutting a stock Gates hose. You buy 2 of the same hose, and cut each one differently to make the 2 hoses that you need. 1 Quote Link to comment
difrangia Posted March 16, 2021 Report Share Posted March 16, 2021 (edited) Measure and sketch out what you need and take your sketch and a tape measure and find a parts store that will let you go back and rummage around in their stock. Mind your manners and put everything back exactly where you got it and piece your own hoses together from parts of existing hoses. Use short pieces of tubing and clamps to piece it all together. This PCV hose for a 320 pickup was made from two moulded hoses. Sometimes you get lucky and you can find a hose and cut what you need out of one hose. Develop a good relation with a parts store and you're home free on future projects. I've done several hoses for the 320 and heater hoses for the 620 this way. Edited March 16, 2021 by difrangia 1 Quote Link to comment
debbheff@gmail.com Posted March 16, 2021 Author Report Share Posted March 16, 2021 Thanks, that's about what i thought, nla. I know someone who works at a parts store so i can likely look thru their hoses and come up with some suitable substitutes. Thanks again 1 Quote Link to comment
mainer311 Posted March 16, 2021 Report Share Posted March 16, 2021 Look for a Gates 18457 1 Quote Link to comment
mrbigtanker Posted March 16, 2021 Report Share Posted March 16, 2021 https://www.ebay.com/itm/Datsun-510-Heater-Hoses-Original-Factory-OEM/224381503183?hash=item343e2e06cf:g:3SgAAOSw3QpZbrwg Quote Link to comment
mrbigtanker Posted March 16, 2021 Report Share Posted March 16, 2021 510 I believe is the same. Quote Link to comment
mainer311 Posted March 16, 2021 Report Share Posted March 16, 2021 Those look different, but similar. Could probably make them work. 1 Quote Link to comment
banzai510(hainz) Posted March 16, 2021 Report Share Posted March 16, 2021 (edited) The 510 ones will NOT work bigger hole and the S shaped one is to long the long hose from fire wall to the inout of the block under the water pump one can most likely use a Generic hose that fits. The S shaped hose is not avail anymore but soemone had a Toyota replacement hose that one can cut the section off and use it. its here somewhere. I have gone thru 2 sets already. Wish I bought more when they was avail. Maybe ebay? here the parts numbers if soembody has them Nissan B7021-B2000 Long heater hose B7020-B2000 short S shaped hose to head Toyota part cut the section out to make S shape 2002 Tundra Gates 18457 heres a 521 S shape https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=datsun+521+heater+hose&_sacat=0 Edited March 16, 2021 by banzai510(hainz) Quote Link to comment
MikeRL411 Posted March 16, 2021 Report Share Posted March 16, 2021 See my hose build entry in the "how to" section. Several years old but has part numbers etc. for build instructions for the preformed hoses on the RL411. Not the same but use your imagination and you can fit the 521. Standard parts and a little careful cutting. Quote Link to comment
banzai510(hainz) Posted March 16, 2021 Report Share Posted March 16, 2021 most people stop looking in the HOW TO section by page 5. 1 Quote Link to comment
mrbigtanker Posted March 17, 2021 Report Share Posted March 17, 2021 10 hours ago, banzai510(hainz) said: The 510 ones will NOT work bigger hole and the S shaped one is to long the long hose from fire wall to the inout of the block under the water pump one can most likely use a Generic hose that fits. The S shaped hose is not avail anymore but soemone had a Toyota replacement hose that one can cut the section off and use it. its here somewhere. I have gone thru 2 sets already. Wish I bought more when they was avail. Maybe ebay? here the parts numbers if soembody has them Nissan B7021-B2000 Long heater hose B7020-B2000 short S shaped hose to head Toyota part cut the section out to make S shape 2002 Tundra Gates 18457 heres a 521 S shape https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=datsun+521+heater+hose&_sacat=0 I searched radiator hoses, good call on heater hoses.duh 1 Quote Link to comment
