Best Bang for Buck Front 510 Suspension
Spades
  • Replies 28
Just remember if using a 510 strut the welded perch has to be higher if running a +25 15x7 rim as the rim would hit the spring set as most of the rim is inside to tuck up under the fender
running a 15x6 would maybe work and less positive offset
most time this is not a problem either zx strut as it 3/4 in more inside and one uses a a less positive offset wheel most are like 0 offset which the rim/tire will not hit the spring
Here are my struts using the T3 kit.
I paid $50 to have someone weld the collars on - the T3 kit fits both 510 and 280ZX struts so you can use them on your 510 struts first, then if you find some 280zx you can switch the kit over. Great bargain for getting coilovers.
And on the car...
