JK510 Posted July 28, 2020 Report Share Posted July 28, 2020 2 minutes ago, demo243 said: https://technotoytuning.com/nissan/510/front-weld-coilover-kit-datsun-510 Requires a "core" in that you still have the stock 510 struts or you have a set of 280zx --- but all the work is done by you. Great, thank you...! Quote Link to comment
dougfj62 Posted August 2, 2020 Report Share Posted August 2, 2020 Technotoy tuning best bang for the buck. Very easy to do if you have any welding abilities and you have the desired struts(280z or 510). Quote Link to comment
banzai510(hainz) Posted August 2, 2020 Report Share Posted August 2, 2020 Just remember if using a 510 strut the welded perch has to be higher if running a +25 15x7 rim as the rim would hit the spring set as most of the rim is inside to tuck up under the fender running a 15x6 would maybe work and less positive offset most time this is not a problem either zx strut as it 3/4 in more inside and one uses a a less positive offset wheel most are like 0 offset which the rim/tire will not hit the spring Quote Link to comment
rosso Posted August 3, 2020 Report Share Posted August 3, 2020 Here are my struts using the T3 kit. I paid $50 to have someone weld the collars on - the T3 kit fits both 510 and 280ZX struts so you can use them on your 510 struts first, then if you find some 280zx you can switch the kit over. Great bargain for getting coilovers. And on the car... 1 Quote Link to comment
