Vtech010 Posted May 2, 2020 Report Share Posted May 2, 2020 Does anyone have a pic of the washer fluid system in their 510. Mine does not have it and I want to see where it goes. Also a pic of the Horn location. Quote Link to comment
datzenmike Posted May 2, 2020 Report Share Posted May 2, 2020 Left inner fender about a foot behind the low beam headlamp for the washer.. 1 Quote Link to comment
rosso Posted May 2, 2020 Report Share Posted May 2, 2020 Plastic fluid line goes into the fender through an oval hole behind the washer bottle, then comes out another oval hole just to the rear of the strut tower. Then goes across the firewall along with the wiring harness to the two nozzles. There is a plastic "T" below the first nozzle. 1 Quote Link to comment
Vtech010 Posted May 2, 2020 Author Report Share Posted May 2, 2020 2 hours ago, datzenmike said: Left inner fender about a foot behind the low beam headlamp for the washer.. Thanks. I guess my car is missing everything. Where can I get the nozzles from Quote Link to comment
Vtech010 Posted May 2, 2020 Author Report Share Posted May 2, 2020 1 hour ago, rosso said: Plastic fluid line goes into the fender through an oval hole behind the washer bottle, then comes out another oval hole just to the rear of the strut tower. Then goes across the firewall along with the wiring harness to the two nozzles. There is a plastic "T" below the first nozzle. Thanks. Everything is missing. I will have to looks for the nozzles Quote Link to comment
KELMO Posted May 2, 2020 Report Share Posted May 2, 2020 Those nozzles are about as rare as chicken lips. They might have used something similar on a B210, just can't remember for sure. I just remember snagging a set in the past but the only thing I can remember was thinking "hey, this ain't a 510". Quote Link to comment
rosso Posted May 2, 2020 Report Share Posted May 2, 2020 Horn locations are just behind the headlights - there is a left and right horn and they mount with two screws but I replaced the rusted screws with new bolts. Driver side, one green wire: Passenger side, two green wires in one connector: replacements for screws why you don't want to use screws: ' once rusted they are awful to get out !! For your washer nozzles, put an ad in the ratsun.net classifieds - there are tons of guys out there with extra cars and parts. I have had very good luck with getting parts that way. 1 Quote Link to comment
thisismatt Posted May 3, 2020 Report Share Posted May 3, 2020 Best way to remove those screws is with the correct bit (#3 philips) and an impact driver. Quote Link to comment
thisismatt Posted May 3, 2020 Report Share Posted May 3, 2020 $10 wiper nozzles https://www.facebook.com/groups/TheZGang/permalink/2881696348532151/?sale_post_id=2881696348532151&rt=11 2 Quote Link to comment
Vtech010 Posted May 4, 2020 Author Report Share Posted May 4, 2020 On 5/2/2020 at 4:51 PM, datzenmike said: Left inner fender about a foot behind the low beam headlamp for the washer.. How does the bottle mount to the car? I don’t see a mount or anywhere to attache it to on my car. Quote Link to comment
datzenmike Posted May 4, 2020 Report Share Posted May 4, 2020 There's a metal clip that the plastic bottle slides down on. Quote Link to comment
slowlearner Posted May 4, 2020 Report Share Posted May 4, 2020 My bottle and pump were there, but the pump was knackered. I dodged up a new pump. One of the nozzles is a little blocked too, but it'll do for rego. P.s. when I saw washer fluid, I just thought headlight fluid and muffler bearings. So make sure you sort them too. 😄 Quote Link to comment
