Eric Posted November 25, 2018 Report Share Posted November 25, 2018 I am looking into buying a 521, is there a company that makes new panels? doors, fenders, bed etc? Quote Link to comment
mrbigtanker Posted November 25, 2018 Report Share Posted November 25, 2018 Not really but plenty of good used panels to get. Quote Link to comment
DanielC Posted November 25, 2018 Report Share Posted November 25, 2018 Not so much in the Netherlands. In the USA, there are parts available, but you still have to make new floors, if you need them, and in a lot of 521 trucks, you need new floors 1 Quote Link to comment
wayno Posted November 26, 2018 Report Share Posted November 26, 2018 I found this place a long time ago and the link below is still good although it says it is not secure, they make hoods, fenders, and the front valance in fiberglass. http://www.up22.com/ranger.htm Part No 1969-72 & 73-79 Datsun Truck (Datsun Items NOW Available 5/16/2017) Please Call 877 735-7772 Notes Racer Net ($) Wt (Lb)* DA-101 69-72 STOCK FLAT HOOD (520) H 239.00 18 DA-128 73-79 DATSUN TRUCK COWL IND. HOOD 3-1/2" H 249.00 20 DA-102 69-72 HOOD WITH SC103 RAM AIR SCOOP H 249.00 18 DA-105 73-79 Stock flat fiberglass hood H 249.00 18 DA-103R&L 69-72 FRONT FENDERS . each 179.00 8 DA-104 69-72 LOWER FRONT GRAVEL PAN 150.00 5 NOTES: * All Weights are approximate H- Has small steel inserts or mounting flange for mounting to hinges P- Pin on only . Part No 1969-72 & 73-79 Datsun Truck "Race Weight Hoods" Notes Racer Net ($) Wt (Lb)* DA-101T 69-72 STOCK FLAT HOOD (520), Full Pin on 219.95 18 DA-128T 73-79 DATSUN TRUCK COWL IND. HOOD 3-1/2" , Full Pin on 229.95 20 DA-102T 69-72 HOOD WITH SC103 RAM AIR SCOOP, Full Pin on 229.95 18 DA-105T 73-79 STOCK FLAT HOOD, Full Pin on 229.95 18 Quote Link to comment
mikec4193 Posted November 26, 2018 Report Share Posted November 26, 2018 I found these folks on ebay.... https://www.ebay.com/itm/DATSUN-NISSAN-520-521-PICKUP-1965-72-BED-SIDE-PANELS-WITH-TAIL-BODY-UPPER-CORNER/323515109840?hash=item4b5300d1d0:g:WUgAAOSwiJhb0EaD:rk:6:pf:0 MikeC 1 Quote Link to comment
mikec4193 Posted November 27, 2018 Report Share Posted November 27, 2018 Here is another place that sells rocker panels for the 1969-73(?) Datsun trucks....their quality is very good... https://www.c2cfabrication.com/collections/all/datsun MikeC Quote Link to comment
Crashtd420 Posted November 27, 2018 Report Share Posted November 27, 2018 3 hours ago, mikec4193 said: Here is another place that sells rocker panels for the 1969-73(?) Datsun trucks....their quality is very good... https://www.c2cfabrication.com/collections/all/datsun MikeC Not sure If those will work or not..... look a little closer... it says 510 pickup, I think those are just for the 510 cars... maybe they are similar I'm not sure.... Quote Link to comment
mikec4193 Posted November 28, 2018 Report Share Posted November 28, 2018 18 hours ago, Crashtd420 said: Not sure If those will work or not..... look a little closer... it says 510 pickup, I think those are just for the 510 cars... maybe they are similar I'm not sure.... I would have to call them and make sure what they exactly intended on their website....I am hoping it is just a typo....they are more of American vintage replacement panel company...they probably dont even know the correct models are for Datsuns... MikeC Quote Link to comment
