Aaron707 Posted October 2, 2018 Report Share Posted October 2, 2018 The heater core in my 1985 720 pickup has started leaking. I've been trying to find a replacement heater core for several days without any luck. Is there any place that sells a replacement still? Or is there a similar core that will fit? Or last, should I just try to have this one rebuilt? Any input or direction on this would be appreciated. Thanks 1 Quote Link to comment
datzenmike Posted October 2, 2018 Report Share Posted October 2, 2018 Remove and pressure test it to confirm where it's leaking and solder it up. Rad shop could probably do this or maybe find replacement. Find another in a wreckiong yard and replace it yourself. Could it be... Loose or split hose? The stop valve leaking? It's plastic and mounted in line and replaceable. 1 Quote Link to comment
Aaron707 Posted October 20, 2018 Author Report Share Posted October 20, 2018 Got the core removed, its leaking only where the plastic ends of the core attach to the copper fingers. The metal is cracked in a few places. I would assume remove the plastic tanks and re-solder the cracked areas? Looked all over for a replacement with no luck so far, I normally just replace these and have never tried to fix one. 1 Quote Link to comment
Draker Posted October 21, 2018 Report Share Posted October 21, 2018 Post a wanted ad, you'll find one. Lots of 720's in the PNW. Ted probably has a bucket full of these. 1 Quote Link to comment
wayno Posted October 21, 2018 Report Share Posted October 21, 2018 I have a few 720 heater cores, but they are not all the same size, also mine do not have any plastic in them, they are completely made out of metal. 1 Quote Link to comment
Charlie69 Posted October 21, 2018 Report Share Posted October 21, 2018 I believe the 85 and 86 heater cores have the plastic elbows on them, both my 85 and 86 had the plastic ends. I do not know what my 84 had as I never pulled the heater all of the 1980 720s I have had had the all metal heater cores. Quote Link to comment
Aaron707 Posted October 21, 2018 Author Report Share Posted October 21, 2018 Here are some pics if someone knows if a metal one is same size: Thanks! 1 Quote Link to comment
wayno Posted October 21, 2018 Report Share Posted October 21, 2018 (edited) The metal ones have fixed positions for the elbows/heater hose connections, yours looks like the elbows can swivel. OK I looked at Mikes photo with plastic elbows, they both point the same direction, the metal ones I have do not point the same way, one points straight down. Edited October 21, 2018 by wayno 1 Quote Link to comment
Aaron707 Posted October 21, 2018 Author Report Share Posted October 21, 2018 They are in a fixed position exactly like the second post from datzenmike . They point back towards the firewall and down slightly. 1 Quote Link to comment
G8KeaPoR Posted October 21, 2018 Report Share Posted October 21, 2018 Just for s and giggles if it’s the brass part of the core that is leaking you can always silver soldier the hole. Have done that on quite a few VW and Toyota cores with great success. Quote Link to comment
Aaron707 Posted October 21, 2018 Author Report Share Posted October 21, 2018 The metal is cracked in two places where the plastic tank attaches. Here is a closeup of one. Quote Link to comment
