DatsunKaua'i Posted July 21, 2018 Report Share Posted July 21, 2018 So I've removed my rear diff to find that the cross shafts have earthier broke or come loose. So I've taken off bearing covers and ring gear assembly will not pop out,it's literally stuck in? Any suggestions and anyone have an old diff they wanna ship to hawaii!!?? Thanks guys I'll add some photos also. And here's a video link to see what I'm talking about. 1 Quote Link to comment
datzenmike Posted July 21, 2018 Report Share Posted July 21, 2018 The pinion mate shaft is simply held in with a roll pin that has sheared off. Replacing it may fix the problem. Well it will lock the shaft in place but what ever caused this problem may shear this pin as well??? 1 Quote Link to comment
DatsunKaua'i Posted July 21, 2018 Author Report Share Posted July 21, 2018 So this piece is called a pinion mate shaft? Do you know of a breakdown of the differential? Like a schematic or whatever you call it?... thx for such a quick reply too by the way! I can't even get the ring and spider gear assembly out? 1 Quote Link to comment
DatsunKaua'i Posted July 21, 2018 Author Report Share Posted July 21, 2018 http://datsun1200.com/modules/mediawiki/index.php?title=Differential_Part_Numbers found this now all I need to do is figure out how to order 1 Quote Link to comment
Rick-rat Posted July 21, 2018 Report Share Posted July 21, 2018 (edited) Remove the bearing caps and then give it a whack with a hammer and block of wood. it should come out. remove the ring gear and the pin should slide out. you will be able to see if the pin is broken or just the roll pin broke off. those small roll pins can be very difficult o remove sometimes, Your video looks like the pin is broken, still need to get the roll pin out to remove both parts of the pin. That is probably all you need to fix the rear end Edited July 21, 2018 by Rick-rat Quote Link to comment
DatsunKaua'i Posted July 21, 2018 Author Report Share Posted July 21, 2018 Rick-rat thx brother. Do you know where I could buy the parts needed to repair this? I'm having a hard time finding them online. Also the pinion gear is a little banged up but still mates well with ring gear and does not seem to make any noise or bind up just cosmetics. Quote Link to comment
Rick-rat Posted July 21, 2018 Report Share Posted July 21, 2018 (edited) Did you get it apart? I don't know where to get new parts, maybe someone has an old differential lying around that could have a good pin the roll pin should be available at any parts store. Try an ad in the classifieds, maybe you will get lucky Edited July 21, 2018 by Rick-rat 1 Quote Link to comment
datzenmike Posted July 21, 2018 Report Share Posted July 21, 2018 Make sure you mark the two bearing caps and any shims so it goes back together exactly as it came apart. You should be able to tap the broken roll pin out out and hammer a new one in. 2 Quote Link to comment
DatsunKaua'i Posted July 21, 2018 Author Report Share Posted July 21, 2018 So I got everything apart the bearing caps had no shims ? And the roll pin will not budge when hammering.?? Any suggestions? Pretty frustrating also can't find the parts to buy anywhere. Kinda have to just go to a parts store and see what'll match up.if anyone 1 Quote Link to comment
Z-train Posted July 21, 2018 Report Share Posted July 21, 2018 I have a center section , 4.37 gears. 100.00 plus the ride. 1 Quote Link to comment
Rick-rat Posted July 21, 2018 Report Share Posted July 21, 2018 (edited) They can be a bear to get out, get some penetrating oil, I like Kroil, get a good quality punch or 2, the same size as the roll pin. Did part of the pinion mate shaft come out when you removed the ring gear? When you get the roll p[in out finally you won't believe the small thing that is kicking your ass, don't let it win!!!!!!!!!!!! Edited July 21, 2018 by Rick-rat 1 Quote Link to comment
DatsunKaua'i Posted July 21, 2018 Author Report Share Posted July 21, 2018 If I can get the part would be better pretty tight on cash thx though! 2 Quote Link to comment
DatsunKaua'i Posted July 21, 2018 Author Report Share Posted July 21, 2018 Yes the broken part did but opposite side that is het in by roller pin is still in there. Because I can't hammer pin out? 1 Quote Link to comment
Rick-rat Posted July 21, 2018 Report Share Posted July 21, 2018 Keep trying, you can do it 1 1 Quote Link to comment
datzenmike Posted July 21, 2018 Report Share Posted July 21, 2018 8 minutes ago, Rick-rat said: get a good quality punch or 2, the same size as the roll pin. This! Spend the money on a good punch. Punch has to go all the way through to drive it out. Roll pins are compressed like a spring. 1 Quote Link to comment
DatsunKaua'i Posted July 21, 2018 Author Report Share Posted July 21, 2018 Thx Mike will do 1 Quote Link to comment
DatsunKaua'i Posted July 22, 2018 Author Report Share Posted July 22, 2018 Do you think I could drive the truck as is now that the broken piece is out. It seems to be operating properly but will the change in weight distribution make it wobble? 1 Quote Link to comment
DatsunKaua'i Posted July 22, 2018 Author Report Share Posted July 22, 2018 kk so another question? Still trying to pop out the pin, I will north give up!, thx gents 1 Quote Link to comment
datzenmike Posted July 22, 2018 Report Share Posted July 22, 2018 Yeah that pinion mate shaft is broken and in at least one place and maybe two. It's got to go. That thing in the middle is the thrust block. Replace the pinion mate shaft or swap in a new third member. 1 Quote Link to comment
DatsunKaua'i Posted July 22, 2018 Author Report Share Posted July 22, 2018 Thx so much Mike I really appreciate you! Do you think this is a stock 620 rear end? 1 Quote Link to comment
wayno Posted July 22, 2018 Report Share Posted July 22, 2018 (edited) That roll pin has to come out, sometimes they do not want to move but the roll pin in that is a lot easier to remove than the pin in a 320 pumpkin/gearset, they are solid pins and are a BITCH to get out(they come out shaped like a banana), I normally use as large a nail that will fit in the hole with the end ground flat, I just keep tapping away till it starts moving, a good punch made out of harder metal should work WAY better than a nail. an old drill bit might also work. You cannot use it the way it is, what will happen is the hole that the pin is still in holding that center block in will start to oval, once that happens the whole thing is garbage, I had that pin break on my C200 dually axle and it destroyed the carrier, lucky for me the C200 carrier in the late 4wd Nissan 720 is the same thing and I was able to fix my dually axle with them parts. Just keep tapping away at that roll pin till it starts moving, I have bent a few large nails over the years but have always got that pin out. I am sure it would be easier to just buy another pumpkin/gearset, but it will likely cost a lot for shipping. Edited July 22, 2018 by wayno 1 Quote Link to comment
Charlie69 Posted July 22, 2018 Report Share Posted July 22, 2018 Is there any rear end shops in your area. They might know where you can source parts. Quote Link to comment
datzenmike Posted July 22, 2018 Report Share Posted July 22, 2018 The pinion mate shaft came loose on my new 70 340 Dart. It went into the crown and tore half the teeth off. So no you can't run it like it is. OR... I have a center section , 4.37 gears. 100.00 plus the ride. 1 Quote Link to comment
G-Duax Posted July 22, 2018 Report Share Posted July 22, 2018 14 hours ago, DatsunKaua'i said: So I got everything apart the bearing caps had no shims ? I know, a little late to the party, as I don't come here much after the change to the new & improved forum format. You won't see the shims, as they are between the bearing & the diff, not between the outer race & housing like modern diffs. Don't mix up the races, as it may change the gear mesh. Want quick & cheap, have the diff welded up (locked diff). 1 Quote Link to comment
Z-train Posted July 22, 2018 Report Share Posted July 22, 2018 And I could disassemble it and send you everything minus the housing. 1 Quote Link to comment
