RandyWanger Posted June 15, 2022 Report Share Posted June 15, 2022 (edited) This one: 60k good money Edited June 15, 2022 by RandyWanger Quote Link to comment
carterb Posted June 15, 2022 Author Report Share Posted June 15, 2022 Silver 1971 1800SSS Bluebird Coupe https://page.auctions.yahoo.co.jp/jp/auction/q1054666752 Datsun 510 Bluebird 1800SSS 2-door coupe Car body parts removal Restoration base No documents Person who can pick up comment It is in a state where it has been pulled up as it was left in the farm barn. Currently, only the tires are inflated and rolled. Since there are no documents for the first year registration, the deadline for vehicle inspection has been entered. I don't know the implementation line, but I put the numbers of the meter integration system as they are. Since the vehicle inspection expired in July 1994, the number has been returned and the deleted documents have been lost. Please consider it as a parts picker or a race car base because you cannot contact the final owner. The body has rust holes at the tip of the bonnet and the bottom of the fender, but overall I think it is still better. There is no key. The interior has some tears in the driver's seat, but I think the condition is good overall. Especially the lining of the door is still covered with vinyl. Regarding delivery, please make arrangements by the highest bidder. We cannot answer questions such as shipping costs. If you are really considering purchasing, you can check the current company if the date and time match, but please refrain from chilling. Thank you. No documents... Sad : ( Quote Link to comment
carterb Posted June 15, 2022 Author Report Share Posted June 15, 2022 9 hours ago, RandyWanger said: This one: 60k good money Wow! 1 Quote Link to comment
carterb Posted June 20, 2022 Author Report Share Posted June 20, 2022 Silver 1971 Bluebird DX 4dr 2,500,000 Yen to start, 3,500,000 Yen BIN https://page.auctions.yahoo.co.jp/jp/auction/u1055102122 comment Since it was canceled before, it will be relisted. It is Bluebird 510. I searched for and purchased a good body from the beginning. The grade is deluxe. I bought and put the engine with L18 set to 2L. The mission is 5th speed of DR30. The car body was almost unpainted with sheet metal, but the left and right steps were rusted, so I repaired the steps at a famous restore shop in the north of Saitama prefecture for 600,000 yen. (Cut about 10 x 10 cm) It was expensive because it was in a proper place ... The exterior was not so good 15 years ago, so I am using an all-pen. (There are about 4 places where putty is putty, and other than that, the paint is reprocessed when the car is new.) After that, it is stored in the garage to prevent it from getting wet in the rain. However, there are scratches on the exterior. Small-sized paint floats appeared on the underside of the left and right rear fenders. I rode it before the Great East Japan Earthquake, but due to lack of gasoline at that time, I haven't moved it since I pulled it out, so please treat it as immovable. Maintenance is required before riding. I went to the event from Saitama to Hamamatsu once, but it ran well. Since it is an old car, only those who can understand it are requested. Since we are busy with checking the current car, we may not be able to meet your request, but we will do our best. Also, since it is a grade that does not have a tachometer, we will give you an octopus for the autometer. Quote Link to comment
carterb Posted June 20, 2022 Author Report Share Posted June 20, 2022 Silver 1970 1400GL Bluebird 4dr 1,303,000 Yen at the moment https://page.auctions.yahoo.co.jp/jp/auction/1055098463 comment Thank you for visiting. This is the final model of N510 Dat Sun. This time, it is in a full tank because it has undergone a continuous vehicle inspection. Since it is an old car, there are many rust and peeling, so if you are looking for a perfect restore product , please refrain from bidding. Currently, we have contracted multiple spaces on the left and right to store a monthly multi-storey car park that is not exposed to rain and wind. I ride about 50km once a week, but I don't feel any problems. There are countless modifications and replacements, so please consider only a part of the description. 【Used parts】 ■ Institutional system ・ Niki single cab bimetal auto choke ・ Distributor pointless ■ Undercarriage ・ Longchamp XR-4 deep rim: 1980s (F-6J × 13, R-6.5J × 13) Rare item with almost no scratches ・ Front harmonic drive / Made by Techno Toy Tuning (US, CA) * Shock: KONI dial adjustment type ・ Rear harmonic drive * Shock: TRD dial adjustment type ■ Exterior ・ 1969 front grille & tail light ・ Hakosuka type chinspo ■ Electrical system ・ Low beam: Stanley (bulb: LED) ・ High beam: KOITO (bulb: halogen) ・ 70's and 80's Car Component / Pioneer Lonesome Carboy ・ VIPER security * Door lock, trunk electric actuator, keyless (recently ineffective) ・ CD changer at that time (FM / AM possible) ・ Firefly light ・ Autogauge tachometer ・ Triple meter ■ Others ・ One-off processing tension rod (dynamo part) ・ Underwater flower shift knob [Recent maintenance history] * All replacements are new and will be installed in 2021. ・ Headlight bezel genuine new replacement ・ Front & rear bumper repro new replacement ・ Front fender marker genuine new replacement ・ Tie rod end new replacement ・ Replacement of new ball joints ・ Replacement of new front suspension bushes ・ Radiator restoration and restoration repair (similar to new) ・ New starter replacement ・ Alternator rebuild replacement ・ Replacement of new fuel pump ・ Replacement of new master back ・ Replacement of new clutch ・ Replacement of front and rear hub bearings ・ Brake master cylinder O / H: New inner replacement ・ Clutch cylinder O / H: New inner replacement ・ Release cylinder O / H: Inner & hose new replacement ・ Replacement of front and rear brake hoses ・ Replacement of front and brake pads ・ Replacement of front brake disc and piston seal ・ Rear brake lining new replacement ・ Rear brake ・ Wheel cylinder O / H: Cup & dust boots New replacement ・ Voltage regulator new replacement ・ Replacement of new heater capacitor ・ Carburetor O / H [Stock parts delivered separately] * All will be new. There are many things that are no longer available. Genuine new weather strips are especially rare. ・ Aisin Seiki Co., Ltd. Asco Clutch (NS-507) ・ DAIKIN Manufacturing clutch cover ASSY (7BL) ・ PIT WORK air element (AY120-NS016) ・ PIT WORK fuel filter (AY505-NS006) ・ OshiKawa Gasket Full Kit (10101-U1025) ・ Nissan genuine rocker cover gasket (13270-W5810) ・ Nissan genuine engine gasket full set (A0101-W212E) ・ Nissan genuine front cover gasket (32112-08U01) ・ Nissan genuine contact point set (22415-89901) ・ Nissan genuine drive shaft bolt (39628-E4100) ・ Nissan genuine drive shaft band x 4 (39659-21050, 39658-21050) ・ Nissan genuine drive shaft boots x 2 (39655-21002) ・ Nissan genuine weather strip front (72610-21001) ・ Nissan genuine weather strip rear (79710-21001) ・ KEYSTER carburetor overhaul kit (K11-4532N) ・ Union Sangyo Oil Filter x 2 (C-241) ・ KONI damping adjustment attachment x 4 ・ Musashi Oil Seal Industry Oil Seal x 4 (43232-21000, N2121) ・ Ohno rubber tie rod end boots x 5 (DC-2111) ・ Akebono Brake Industry Pad Parts Kit Clip R (PPK-01-01) ・ For one MK Kashiyama brake shoe (Z 1119-10) ・ ACRE SUPER FIGHTER Brake pad for 1 unit (001) ・ KOYO hub bearing x 4 (HI-CAPLM11749R) ・ KOYO hub bearing x 1 (RCT4067L1) ・ NTN hub bearing x 4 (6206LU) ・ GMB, TOYO universal joint x 6 (GUN-29, TN-127) ・ NGK spark plug x 4 (7311 BP5ES-11) ・ Mitsuboshi fan belt x 2 (MPMF-1360, MPMF-1350) ・ NWB wiper blade x 2 (GR56-YA2G) -In addition, there are many new products such as genuine Nissan hoses and small parts of drive shafts. We will also give you the genuine shift knob, genuine steering, and genuine shock that have been attached since the new car. Payment will be the highest bid + monthly automobile tax + recycling fee. Pick-up is possible for both self-propelled and loaded vehicles. In the case of land transportation, we will make a reservation here to prevent troubles. The land transportation company uses land transportation ZERO, so sorry to trouble you, but please search for the shipping fee from the HP. For consultations such as prompt decision, please write your e-mail address in the question column and send it. We will send you an email privately. Thank you for your cooperation. Quote Link to comment
carterb Posted June 20, 2022 Author Report Share Posted June 20, 2022 white 1971 1400GL Bluebird 4dr 2,300,000 Yen to start https://page.auctions.yahoo.co.jp/jp/auction/e1055125236 Bluebird 510 N510 GL Vehicle Inspection Reiwa Until May 6th, unknown running 4th speed 1400cc Solex 40 Taco Shinon Sridat San Hakosuka Kenmeri Dat Sun 510 Bluebird Distance unknown. Until the beginning of May 6th, the vehicle inspection order. Grade GL 1400cc Solex 40 Unknown Takoashi Unknown Muffler Vehicle inspection volume compatible. Alternator rebuild. Former owner of aluminum two-layer radiator , maintenance history 3 years ago, rust removal and cleaning inside the fuel tank. Brake overhaul 3 years ago. Front and rear harmonic drive unknown non-slidef. The carbon bonnet is tattered. Roll Bar Dat Sun Bucket Seat Replica Datsun Competition Handle There is no emblem of the horn pad at that time. Those who want wheels Separately 150,000 13 inch Mark III 7.5j A type 9j C type Rear tire Neova Almost new. The front tire is unknown. There is still a groove. Replace the mirror with a new replica cannonball mirror. Napoleon Bonakka mirror is not attached. The drive shaft is extremely banzai due to the defective part Shakotan . Therefore, there is vibration when speeding up to about 100 km. I think that it will be solved if you raise the vehicle height. Quote Link to comment
RandyWanger Posted June 21, 2022 Report Share Posted June 21, 2022 On 6/15/2022 at 8:26 PM, carterb said: Silver 1971 1800SSS Bluebird Coupe https://page.auctions.yahoo.co.jp/jp/auction/q1054666752 Datsun 510 Bluebird 1800SSS 2-door coupe Car body parts removal Restoration base No documents Person who can pick up comment It is in a state where it has been pulled up as it was left in the farm barn. Currently, only the tires are inflated and rolled. Since there are no documents for the first year registration, the deadline for vehicle inspection has been entered. I don't know the implementation line, but I put the numbers of the meter integration system as they are. Since the vehicle inspection expired in July 1994, the number has been returned and the deleted documents have been lost. Please consider it as a parts picker or a race car base because you cannot contact the final owner. The body has rust holes at the tip of the bonnet and the bottom of the fender, but overall I think it is still better. There is no key. The interior has some tears in the driver's seat, but I think the condition is good overall. Especially the lining of the door is still covered with vinyl. Regarding delivery, please make arrangements by the highest bidder. We cannot answer questions such as shipping costs. If you are really considering purchasing, you can check the current company if the date and time match, but please refrain from chilling. Thank you. No documents... Sad : ( Better condition than what mine was in! Mine also had no documents and is now fully road legal in the UK. If there's a will, there's a way. You just have to pay for the pleasure. Quote Link to comment
carterb Posted June 26, 2022 Author Report Share Posted June 26, 2022 Silver 1971 Bluebird 4dr DX 199,510 Yen https://page.auctions.yahoo.co.jp/jp/auction/d1055585595 Bluebird 510 1971 Deluxe Sedan It is a 1971 Bluebird 510 deluxe sedan dongara body. There are no documents. There are some rusts, but the body is in good condition. How about as a base for restoration and racing? As a bonus, we will give you a paper and an iron plate as a bonus. Please purchase the one who understands the meaning. Those who come to pick it up are welcome. It is possible to get a land transportation quote here as well, but please refrain from asking questions about land transportation charges as it will be arranged after purchase. Quote Link to comment
carterb Posted June 27, 2022 Author Report Share Posted June 27, 2022 Yellow 1969 1600SSS Bluebird Coupe 514,500 Yen at the moment https://page.auctions.yahoo.co.jp/jp/auction/f1055831672 Sold out ☆ Rare Nissan 510 Bluebird 1600 SSS Coupe 1969 Temporary erasure Restore base Old car Vintage DATSUN Documents available t will be a friend's proxy listing. At the time of the previous exhibition, it was an exhibition as a part removal without a book, but in response to the opinions and requests of the people who saw it at that time, it was worth the trouble of creating documents and I was able to temporarily delete it. .. Thank you very much. Below is a friend's talk. This time, due to the rebuilding of my house, I could not secure a storage place, so I put it up. It is a rare 510 Bluebird 1600 SSS coupe. The first year registration of vehicle verification is 1969. It seems to be the early model. The degree of originality is very high. It has been temporarily erased. You can re-register. Before that, it had a single number of Sai 5. Please restore and return to the street. At the time of acquisition, the body was in very good condition and it was running normally, but since it was left outdoors for nearly 10 years, there are many holes due to rust and corrosion. I regret that I should have kept it with chitin. At the time of listing, the engine started with a gasoline drip, but the clutch release cylinder seems to be useless and I can not run. The headlights and small lights were turned on by the battery jump, but other electrical components did not move. Please check the video of engine start. https://youtube.com/shorts/wU91C-zZnE8?feature=share The tires were flat on all four wheels, so I wore suitable tires for rolling. The brake is stuck on one side of the rear. The body is rusty and corroded. There are no cracks in the glass and lights. The interior is a little torn in the driver's seat and is generally dirty, but I don't think it's in bad condition. The carpet is tattered. Please check the video here as well. https://youtu.be/wczcmSmNXMc Please arrange the pick-up by the highest bidder. Confirmation of the current car is welcome. The vehicle is located in Nishi-ku, Saitama City. Quote Link to comment
carterb Posted June 28, 2022 Author Report Share Posted June 28, 2022 Yellow 1971 Bluebird 4dr 199,510 yen to start https://page.auctions.yahoo.co.jp/jp/auction/1055840938 Bluebird 510 1971 Deluxe Sedan It is a 1971 Bluebird 510 deluxe sedan dongara body. There are no documents. There are some places where it is rusted a little, but the condition of the body is good for the age. How about as a base for restoration and racing? As a bonus, we will give you a paper and an iron plate as a bonus. Please purchase the one who understands the meaning. Those who come to pick it up are welcome. It is possible to get a land transportation quote here as well, but please refrain from asking questions about land transportation charges as it will be arranged after purchase. Quote Link to comment
carterb Posted June 29, 2022 Author Report Share Posted June 29, 2022 Red bluebird 4dr 250,000 Yen to start https://page.auctions.yahoo.co.jp/jp/auction/g1055913830 DATSUN Bluebird 510 4-door body with documents Dat Sun Bluebird 510 4-door vehicle. The condition is as shown in the photo, with rust, corrosion, and mog. The vehicle is temporarily erased As you can see, it is not possible to run on its own, so please bid only for those who can come to pick it up (Is it necessary to have a unic?) If you wish, you can cut the necessary parts before shipping. 1 Quote Link to comment
carterb Posted June 29, 2022 Author Report Share Posted June 29, 2022 Green 1972 1600DX Bluebird 4dr 3,000,000 Yen https://page.auctions.yahoo.co.jp/jp/auction/k1056012923 Bluebird 510 Please ask any questions you may be interested in. If 13 inches is good, there are Hayashi and Watanabe. I'm looking for a fender cut, over fender car. Not everything is good. Only $22K USD. Someone bring this one stateside! Quote Link to comment
carterb Posted June 30, 2022 Author Report Share Posted June 30, 2022 (edited) Yellow 1969 1600SSS Bluebird Coupe - only 9,800 Yen at the moment! https://page.auctions.yahoo.co.jp/jp/auction/b1056071289 510 2-door SSS Bluebird Parts removal Documents available s30Z Hakosuka Kenmeri Old car It is a complete parts removal. I have the documents, but it's from another car. Please use the collection to the last. (Added at 9:36 on June 30, 2022) Remove the dash. (Added at 9:37 on June 30, 2022) Free shipping, but only for pick-up "I have the documents, but it's from another car. " <-- What does that even mean?! Thanks? Edited June 30, 2022 by carterb 2 Quote Link to comment
carterb Posted July 1, 2022 Author Report Share Posted July 1, 2022 White 1969 Bluebird 2dr 3,300,000 Yen https://page.auctions.yahoo.co.jp/jp/auction/x1056128980 Dat Sun Bluebird 510 2-door sedan 1969 Restoration in progress 27 years Garage storage ■ Comment We have verified the car and reported the loss to the police. Car verification copy Yes You can register the previous owner car shop . Horizontal bar meter in the previous term There is a dash crack, but there is a good spare. Is included. Body-related No rust, etc. Rottenness has been sheet metal. Weatherstrip-related New items are available. Is included. There is a spare bonnet and fender. Is included. The seat rear is beautiful without tearing. There is a good spare at the front desk. Is included. The bumper has rust on the front and back. Side air reflector re-plated. The wheels are Watanabe 4-spoke spares with American Racing his Libre 14 inches. In case of cancellation, please bear 20000 yen. Please use 3N. Quote Link to comment
RandyWanger Posted July 4, 2022 Report Share Posted July 4, 2022 On 6/30/2022 at 7:48 PM, carterb said: Yellow 1969 1600SSS Bluebird Coupe - only 9,800 Yen at the moment! https://page.auctions.yahoo.co.jp/jp/auction/b1056071289 510 2-door SSS Bluebird Parts removal "I have the documents, but it's from another car. " <-- What does that even mean?! Thanks? That rear badge could be saved. Quote Link to comment
carterb Posted July 4, 2022 Author Report Share Posted July 4, 2022 Green 1971 1600GL Bluebird 4dr 1,651,000 Yen at the moment https://page.auctions.yahoo.co.jp/jp/auction/n1056423831 510 Bluebird Modification point Muffler harmonic drive malfunction Fuel gauge does not stop moving left and right. The heat meter doesn't work anymore. The radiator has been overhauled and will stop running normally. Originally it was a one-owner single number. Interior door vinyl is attached. The seat is torn, but the others are in good condition. * Wheels, shift knobs, and steering wheel are genuine 1 Quote Link to comment
carterb Posted July 12, 2022 Author Report Share Posted July 12, 2022 Orange and white 1970 Bluebird coupe 2,800,000 Yen https://page.auctions.yahoo.co.jp/jp/auction/v1056835761 comment 45 Year 510 Bluebird SSS Coupe L20B specification of engine Z20 block combined with L4 head 2.1L Aluminum 3-layer radiator, etc. Front AE86 harmonic drive, rear manufacturer unknown harmonic drive Front pillow ball lower arm, tension rod Speedster MKⅡ F8J R9J Rear Def Subaru R180 Cusco LSD Meters Ramco and others Two front seats outside the company Exterior BRE type over fender front spoiler Unofficial Roll bar May end early I will add images, explanations, etc. (Added at 20:53 on July 9, 2022) Since it is a car that is more than 50 years old, we would like only those who have an understanding of old cars and those who are serious about it. Quote Link to comment
carterb Posted July 13, 2022 Author Report Share Posted July 13, 2022 Silver 1970 Datsun Bluebird Wagon 2,500,000 Yen https://page.auctions.yahoo.co.jp/jp/auction/b1056765767 It is a rare Bluebird van (model VN510) ☆ Please be sure to read the explanation to the end. ☆ This car Bluebird Van is a proxy exhibition of an acquaintance After it makes a successful bid, we will take responsibility until the end when dealing I will have it, so thank you. ☆ For payment of cars and exchange of transactions, If you are thinking of making a successful bid, purchasing, etc., please be sure to ask a question and confirm. ☆ Please note that we do not accept simple payments. In any case, please use 3N. ☆ I will explain the contents of the car. (Added at 14:56 on July 7, 2022) ☆ Explanation of vehicle specifications (equipment for remodeling) Suspension ☆ Is the front height adjustable, pillow upper, stabilizer external product? Is the T lot adjustable? ☆ The rear is a block and the vehicle height is lowered a little, is the shock adjustable externally? The description on the vehicle inspection is 139. Originally 144? I wonder if there is ☆ Is the engine 40 pie? , Genuine EX with heat resistant band, sports muffler type, taer bar (aluminum). ☆ Seats in the room, floor carpets in the room, repairs to see if inspection is necessary for non-cooler items. (Added at 15:43 on July 11, 2022) ☆ I'm sorry, but if you have a question that I feel is a chilly question, I will put it on the blacklist, so in that case I can not bid, ask questions, etc. be careful. ☆ I'm sorry, but I think that the SSS handle and the tire wheel may be different at the request of the person himself, in that case please confirm with a question and bid. ☆ It is a body condition. Looking through the floor mat in the room, I think that we are the same floor as the new car, and the side step Mimi is the same as the new car, I think that there is no putty finish, it is in good condition in this model year Also, the body has a little rust in some places, so please do not misunderstand it. This is our impression, so please refer to it. ☆ However, it seems that money is spent in various places. ☆ Rear glass (hatchback) It is thinly attached to the film and also to the side glass. ☆ Those who have a high evaluation rate will respond to cancellation of bids, refusal of transactions, answers to questions, etc. at our discretion. ・ Please note that only those who are serious about auctioning. 2 Quote Link to comment
carterb Posted July 18, 2022 Author Report Share Posted July 18, 2022 White 1968 Bluebird 2dr sedan 900,000 Yen https://page.auctions.yahoo.co.jp/jp/auction/v1057598081 1968 Datsun 510 Bluebird Coupe with documents for restoration It is an exhibition of Datsun 510 Bluebird. The engine is down and the parts are in a disassembled state. It has been temporarily deleted and the documents are complete. All the parts are shown in the picture. Please refer to the photo for details. If you have any questions, please call 080-9401-6070. Land transportation is possible for Kanto, Tohoku, and Koshinetsu at an extra charge. The payment amount will be "only the winning bid". If you make a successful bid, please contact us within 48 hours using the transaction navigation. Please pay within 4 days from the successful bid date and complete the collection within 1 week. If you have a vehicle inspection, please change your name within 4 weeks. There may be scratches, stains, or defects that are not described in the photos or explanations. Please make a decision after checking the current car. Also, due to the characteristics of the product, no claim and no return are required. Please consider bidding after understanding that it is second hand. We cannot accept cancellation of bids, cancellations after a successful bid, or returns. If there is a clear reason and the item is canceled after it makes a successful bid, a handling fee of 30,000 yen will be charged. 1 Quote Link to comment
carterb Posted July 25, 2022 Author Report Share Posted July 25, 2022 White 1971 Bluebird SSS coupe 3,500,000 Yen https://page.auctions.yahoo.co.jp/jp/auction/1058525677 Datsun Nissan 510 Bluebird 1800 Coupe SR20 S15E / g Cooler Power Steering Rack and Pinion Poncam 518z Turbine Unofficial Nice to meet you, this is a one-time listing. We would appreciate it if you could purchase a custom or modified car after understanding it. It is a vehicle that takes time and money for me. To be honest, I want to keep it as it is, but I decided to let go of it because of my personal circumstances. Since it is a crazy specification, please pass through if you are concerned about normal or original. We will answer questions as much as possible. "Sometimes we can't answer questions that are difficult to answer." It's been half a century since it was manufactured. I think that it is a beautiful individual although there is some rust such as the body stored indoors without running in the rain. "It's an individual opinion." The bonnet hinge opens forward using Hakosuka, and Cima's Balkan at that time chose a custom and popular Gleddy's one-off intercooler . Although it is a surge tank and a poncam, it is included. Accelerate dangerously when boosted! It is controlled by HKS VPRO, but it will be replaced by the rider, so please reset it. Also, it has been strengthened with a head gasket and OS super single with insurance, and it is heavy. The mission oil is normal, but since it has 15 6-speed power, the mission oil is protected by a hard Omega guy. Although it is not in the image, it is HKS EVC, Chinese 1DIN, but you can see the remote control lost DVD. The genuine meter did not move the octopus and the water temperature did not move, so I put in the new American meter, Dakota Digital. .. There is an error in the speedometer, but I don't know how to set it ... I'm riding with the error. Although it is an air conditioner, the main compressor is 15, but the suspension in the room is old and there may be leaks. The receiver tank has 12 mouths. It's like riding with 134 gas. The dat sun competition handle has power steering, and I dare to use a rack and pinion, so it's insanely light. The console is Hakosuka, and the seats are spoiled, but the Recaro SL door and trunk are smoothed. Is the battery of the remote control key useless? It may be a module because it is Chinese. The push start is left so that it can be returned to the original key. As for the brake, a genuine Nissan genuine product came from the manufacturer, so I wonder if it was about 80,000 with the Kenmeri GTR and the master cylinder with the master back. The tires are Chinese, but the wheels were the old Gold Watanabe 16-inch R type 8J9J? It has a deep rim. It is made to be quite aggressive with Tsuraichi. The tail also flows, and the rest is ... Please ask any questions. As I said at the beginning, please understand that it is unofficial with many basics, customs, and modifications. Please do not cancel, claim or return. Arrangement of delivery "Ship or land transportation" is requested by the purchaser. I will help you as much as possible. Please keep 50,000 yen until the name change is completed. We will set a prompt decision price, but those who are decided promptly will bear half the price of the ship. "It will be returned together with the deposit for the name change." Thank you for your understanding. "Please understand that there may be a lack of explanation such as forgetting to write due to overdoing. Then , although it is a short period, thank you. Quote Link to comment
carterb Posted August 26, 2022 Author Report Share Posted August 26, 2022 Green 1971 1800SSS Bluebird 4dr 400,999 at the moment https://page.auctions.yahoo.co.jp/jp/auction/f1061076726 Datsun 510 Bluebird 1800SSS 4 door sedan car body parts removal restore base no documents people who can pick up Currently, only the tires are inflated and rolling. Engine SR20DE, 71C for mission SR20DE, modified cross member, modified stabilizer Differential R180LSD, FR coilover, modified for F foot S130 I thought I would finish it with an SR20 carburetor, but gave up halfway through. It doesn't start the engine. Just put the engine and mission on. Original engine L18, 4-speed mission. It is for cross member L18. There is no F stabilizer. Missing muffler, other missing items I don't have the documents for the first year registration, so I don't know the actual driving, but the meter's total number is 47.239Km. No registration documents. Since we cannot contact the final owner, please think of it as parts removal or a race car base. The body has rust holes at the tip of the bonnet and at the bottom of the fender, so please judge the condition of the vehicle from the images. The bonnet, roof, and trunk are rust-proofed (appropriately). Interior is all in the image. There are missing sheets. I would like to pick it up directly. If you are really considering purchasing, the date and time If it matches, you can also check the current car, but please forgive the ridicule. Thank you. Quote Link to comment
carterb Posted August 26, 2022 Author Report Share Posted August 26, 2022 White 1972 1600SSS Bluebird 4dr 402,000 Yen at the moment https://page.auctions.yahoo.co.jp/jp/auction/q1061551814 1971 Datsun Bluebird P510 comment It is an exhibition of Datsun Bluebird P510. You can start the engine and run. It has been temporarily deleted, and the documents are complete. There are rust, corrosion holes, etc. See photos for details. If you have any questions, please ask. The payment amount will be "contract price + recycling deposit". Nationwide land transportation can be arranged at an additional charge. If you win the bid, please contact us within 48 hours in dealings Navi. Please complete the payment within 4 days from the date of the successful bid and complete the pick-up within 1 week. There may be scratches, dirt, or defects that are not described in the photos or description. Please make a judgment after checking the current car. Also, due to the characteristics of the product, please do not claim or return. Please consider bidding after understanding that it is a used item. We cannot respond to cancellation of bids, cancellation after a successful bid, or returns. If there is a clear reason for cancellation after a successful bid, we will charge a fee of 30,000 yen. In the case of vehicle inspection, please be sure to change the name within 4 weeks and notify us by fax/email. Quote Link to comment
carterb Posted August 26, 2022 Author Report Share Posted August 26, 2022 (edited) Silver 1970 1600SSS Bluebird Coupe 5,000,000 Yen https://page.auctions.yahoo.co.jp/jp/auction/c1061714697 bluebird 510 sss comment Modified points ・Hakosuka grill ・Roll bar ・Front spoiler ・One-off rear bumper (genuine also available) ・Wire tack ・Cab OER ・Reprint mark 2 ・Over fender ・RECARO semi -bake ・Fuel tank relocation ・Front one-off height adjustment ・Rear height adjustment kit・ Hiropane for Japan・One -off muffler (full straight)・Defective self-painting (dark metal gray) There was no engine trouble. The previous owner painted the engine room and interior of the car at the time of all pens. I think that there is no particular rust and the degree is relatively good. I don't have many opportunities to ride it, and I don't run more than 1000 kilometers a year . Stored indoors for 3 years from date of purchase. Edited August 26, 2022 by carterb Quote Link to comment
carterb Posted September 7, 2022 Author Report Share Posted September 7, 2022 Safari gold 1971 1800sss bluebird 4dr 5,000,000 yen https://www.goo-net.com/usedcar/spread/goo/19/700080347730220901001.html NissanBluebird 510 1800SSS solex octopus foot 5MT speedster aluminum car harmonic Quote Link to comment
carterb Posted September 7, 2022 Author Report Share Posted September 7, 2022 White 1969 1300DX bluebird 4dr 103,000 Yen at the moment https://page.auctions.yahoo.co.jp/jp/auction/f1061946104 Nissan Bluebird 510 parts removal etc. * document none comment Nissan 510 Bluebird DX4 door start NG no documents Year is unknown. ☆Engine When you inject brake cleaner into the carb, the engine starts for a moment. Does the tire stick slightly and the electrical components are okay? ☆ Exterior Rust, rot, scratches, etc. ☆Interior I personally think that it is in a beautiful state for the model year. There are no large noticeable scratches on the sheet, etc. *Please note that there is a possibility that the auction may be terminated early because other people are calling out. * Since there may be an oversight or lack of explanation on our part, we will respond to the extent that you can check the current vehicle and ask questions. * If shipping is in nearby prefectures, we can also deliver at an additional charge, so please contact us. * After a successful bid, I need your help by a no claim no return. Quote Link to comment
