Wire down..
Hey all,
I was pulling out of a parking spot this afternoon and I heard a loud, scary noise. I got out to check what I had hit, but discovered that this green and white "combo-wire" underneath my car. Strangley, it seemed like one end had been cut (or pinched) and the other end had been pulled from the car. I have noticed the wire before when changing my oil, but I do not know what it runs to or from. I did notice that it runs almost the entirety of my vehicle. After I found the wire, immediately checked all of my lights, signals, etc., and everything seemed in working order. I had to move my car across campus to a different lot, so I drove it there and everything seemed okay with the car. I own a repair manual for my vehicle (though I do not have it with me), and I found that green wires run to signal systems and white wires run to charging systems. This information was somewhat useful, but I still do not know exactly what the wires run to and from. Does anyone know what the wire connects to? And will my car be OK to drive to the mechanic tomorrow?
Attached are links to pictures of the combo wire, and below is some information that may be useful.
1981 Datsun 510 Wagon
The "combo-wire" is approximately 4.5 feet in length.
I looked underneath both the hood and the car itself, but I cannot find any sign of the rest of the wire.
Thank you in advance,
Isaac
Links to images:
https://imageshack.com/i/pnEyudKAj
https://imageshack.com/i/poNcK0Rlj
  • Replies 9
This probably doesn't help too much but that doesn't look like factory wiring to me....
It's the twist that bothers me... in the wiring harnesses I've seen they have all have been straight..
seeing that reminded me of A trick I was taught while doing alarms... we would secure the alarm harness and use a drill to spin wires together to look like that, depending on what wires needed to go where...
Looks like leftovers to me... but that's really just my opinion....
