datzenmike Posted December 23, 2016 Report Share Posted December 23, 2016 Get a door switch from another 720!!!! Try wrecking yards. Or find one cheap and but for the parts, (fuse box, relays, wiring harness, FP relay etc) You can't buy these things, now. Fill master reservoir and open bleeder on the slave. Pump all that black shit through and flush it out with fresh brake fluid. Easy and cheap. You can wire the fuel pump to anything that shuts off with the ignition. The point of the relay is the fuel pump shuts off if the engine stops.... like in an accident... where there may be a fire. This is why there is an alternator and oil pressure input. Oil pressure and alternator input KEEP the pump running. Starter is another input. Pump will pump when starter is engaged. Pump should turn on with the ignition, probably on a timer for XX seconds. If starter not used or engine started it shuts off. 1 Quote Link to comment
la_leo Posted December 23, 2016 Author Report Share Posted December 23, 2016 Get a door switch from another 720!!!! Try wrecking yards. Or find one cheap and but for the parts, (fuse box, relays, wiring harness, FP relay etc) You can't buy these things, now. Fill master reservoir and open bleeder on the slave. Pump all that black shit through and flush it out with fresh brake fluid. Easy and cheap. You can wire the fuel pump to anything that shuts off with the ignition. The point of the relay is the fuel pump shuts off if the engine stops.... like in an accident... where there may be a fire. This is why there is an alternator and oil pressure input. Oil pressure and alternator input KEEP the pump running. Starter is another input. Pump will pump when starter is engaged. Pump should turn on with the ignition, probably on a timer for XX seconds. If starter not used or engine started it shuts off. pumps been working good. I don't want to run it until I get the power steering line changed. It just soaks everything through the pinhole leak. I'm going to replace the clutch master and slave cylinder, already got them ordered. My clutch has zero pressure. I'll probably rebuild the old ones and keep them. 1 Quote Link to comment
la_leo Posted December 23, 2016 Author Report Share Posted December 23, 2016 Get a door switch from another 720!!!! Try wrecking yards. Or find one cheap and but for the parts, (fuse box, relays, wiring harness, FP relay etc) You can't buy these things, now. Fill master reservoir and open bleeder on the slave. Pump all that black shit through and flush it out with fresh brake fluid. Easy and cheap. You can wire the fuel pump to anything that shuts off with the ignition. The point of the relay is the fuel pump shuts off if the engine stops.... like in an accident... where there may be a fire. This is why there is an alternator and oil pressure input. Oil pressure and alternator input KEEP the pump running. Starter is another input. Pump will pump when starter is engaged. Pump should turn on with the ignition, probably on a timer for XX seconds. If starter not used or engine started it shuts off. any idea what those two wires are under the coolant jug? 1 Quote Link to comment
Charlie69 Posted December 24, 2016 Report Share Posted December 24, 2016 Those door switches were used in several model cars also. You can tell by the location and the 3 wires. Quote Link to comment
la_leo Posted December 25, 2016 Author Report Share Posted December 25, 2016 Those door switches were used in several model cars also. You can tell by the location and the 3 wires. I ordered the single wire. I'll make something work. 1 Quote Link to comment
la_leo Posted December 26, 2016 Author Report Share Posted December 26, 2016 This week I will be doing the following: Bringing the bed to get new metal welded in. Pressure wash the frame and undercoat it. Replace the gas tank, power steering line, battery, clutch master and slave cylinder, O2 sensor. reset the sensor light, fix a few chewed on wires, and clean in the interior plastic parts. I also need to see whats up with my gauges and fuel pump working intermittently. Hopefully I can actually getting it rolling on it's own power this week! 1 Quote Link to comment
la_leo Posted December 27, 2016 Author Report Share Posted December 27, 2016 Amazing what powerful degreasers can clean! Disgusting seats abs door panels back to blue. 2 Quote Link to comment
la_leo Posted December 27, 2016 Author Report Share Posted December 27, 2016 Pressure washed the back half of the frame. Some fresh rust reformer. Next I'll undercoat 1 Quote Link to comment
la_leo Posted December 28, 2016 Author Report Share Posted December 28, 2016 There was a rubber lime coming off the front chunk just hanging. There is a hard line on the frAme underneath the radiator. The line had nothing attached to it. I assume it's a vacuum hard line. Since I couldn't see any other the the hose hooked too, I attached it to the metal hard line. Any body able to confirm this? Also on the rear axle there is a vent tube on the top on the driver's side. Looks like a vacuum hose goes on it but there is no hose there. 1 Quote Link to comment
DrvnDrvr Posted December 28, 2016 Report Share Posted December 28, 2016 Those lines are vent hoses for the differentials. I believe they end up going to the charcoal canister. 1 Quote Link to comment
la_leo Posted December 28, 2016 Author Report Share Posted December 28, 2016 Those lines are vent hoses for the differentials. I believe they end up going to the charcoal canister. charcoal canister? That's weird. Thanks. 1 Quote Link to comment
DrvnDrvr Posted December 28, 2016 Report Share Posted December 28, 2016 The air and fluid expand and contract as it heats and cools. . I believe the tranny has that hose too. After scouring the FSM I can find no mention of them other than being vent tubes. No mention of where they go. 1 Quote Link to comment
Lockleaf Posted December 28, 2016 Report Share Posted December 28, 2016 They just go out to ambient air, high on the body. They allow gases to escape, but also are high enough to prevent water from entering them. Run them where ever you like. 2 Quote Link to comment
la_leo Posted December 28, 2016 Author Report Share Posted December 28, 2016 Appreciate it 1 Quote Link to comment
Charlie69 Posted December 28, 2016 Report Share Posted December 28, 2016 I ordered the single wire. I'll make something work. The three wires have to do with the time delay that keeps the dome light on for a few seconds after closing the door. Quote Link to comment
la_leo Posted December 28, 2016 Author Report Share Posted December 28, 2016 What a day. I fought it, but was able to pull off the power steering pressure hose. The new one looked right, but it just doesn't fit. I looked closer and the bends are definitely off or possibly it got damaged, and might be a little too long. It's for the 85 720 4x4 AC delco part number 36-369650. Can anyone confirm this? I'll probably run it to our hydraulic hose shop and let them look at the old and new. Also a coolant leAK has developed from the new lower hose I put on. It was a cut to fit molded hose. Definitely not fitting like the oem one. But the part number us correct. I re tightened the clamp at the water outlet. 1 Quote Link to comment
Lockleaf Posted December 28, 2016 Report Share Posted December 28, 2016 Yeah, that part number cross references to oreilly p/n 91546, which fits 83-86 Nissan 720 4x4. 1 Quote Link to comment
la_leo Posted December 29, 2016 Author Report Share Posted December 29, 2016 I don't know then. On rock auto there looks like there are two different hoses with different bends. One like I have and another 1 Quote Link to comment
Lockleaf Posted December 29, 2016 Report Share Posted December 29, 2016 Pressure and return? 2wd and 4wd? 1 Quote Link to comment
la_leo Posted December 29, 2016 Author Report Share Posted December 29, 2016 Pressure and return? 2wd and 4wd? . just the pressure. 4x4 1 Quote Link to comment
Lockleaf Posted December 29, 2016 Report Share Posted December 29, 2016 I meant possibilities to account for the different shape you saw on rock auto is all. 1 Quote Link to comment
la_leo Posted December 29, 2016 Author Report Share Posted December 29, 2016 Damn thing must have got bent during shipping. Didn't notice it at first. I'll get it bent back and try again 1 Quote Link to comment
la_leo Posted December 29, 2016 Author Report Share Posted December 29, 2016 DOES THIS LOOK CORRECTLY INSTALLED? 1 Quote Link to comment
