charolastra Posted October 20, 2016 Report Share Posted October 20, 2016 Hello I have a question, can I run a weber dcom on any datsun engine? And what's the difference on dcoe and dcom carbs? Some people says it's the new version of dcoe, some guys told me dcom carbs are for alfas, and another european cars and i can't run them on a datsun engine. Im fucking confused right now Thanks for the help Quote Link to comment
kelowg Posted October 20, 2016 Report Share Posted October 20, 2016 http://www.weberperformance.com.au/information.php?info_id=26. Down the page a bit and lots of other good info 1 Quote Link to comment
G-Duax Posted October 20, 2016 Report Share Posted October 20, 2016 Good to know..... There was a guy out of Italy selling the DCOMs on eBay, and I always figured I could get around any design differences, but I know that it may be a problem for some people. From the site: "40 DCOM - Some online sellers claim that these are the "latest" design from Weber. Quite simply, they will not work properly on any engine apart from the Alfa Romeo they were designed for. They are an emissions style carburettor and also use a completely different pump jet design. In fact they use a diaphragm for the pump circuit similar to that used on the Dellorto carburettor. Having attempted and spoken with numerous customers, you may obtain the 40 DCOM carburettor cheap, but you will spend three times more trying to get it to even resemble working." Personally, that sounds like bull shit sales talk to me, by someone wanting to push his inventory over a good deal someone found somewhere else. Jets are jets, floats are floats, acceleration circuits are acceleration circuits. If you are going to pay someone to change jets until your car runs correctly on any carb, it's going to cost you more...... than if you pick up a book, learn how these carbs work, and do the job yourself. Half the enjoyment of these old cars is the task of making them run the way you want them to. If you want a Datsun to just drive around to look cool, or hipster, just go buy a dodge mini-van. You will enjoy life a lot more........ Quote Link to comment
demo243 Posted October 22, 2016 Report Share Posted October 22, 2016 I had a pair of dcom s on my l20b mounted on a mikuni manifold. Quote Link to comment
demo243 Posted October 22, 2016 Report Share Posted October 22, 2016 Didn't have a problem with em, but I never dealt with re jetting them , I've heard it can be harder to get jets... But also heard they are the same. I was told the diaphragm pump was actually better I got rebuild kits for them from Pierce manifolds I actually still have them and need to sell em. One has a broken mounting ear... But the other is good. Just a needs a rebuild, but I've got two fresh rebuild kits 1 Quote Link to comment
G-Duax Posted October 22, 2016 Report Share Posted October 22, 2016 Please note, I have revised my earlier post. Thanks demo for waking me up from the 'the world will end if you don't buy the exact part that everyone else is using' coma..... Common problem with forums..... 1 Quote Link to comment
demo243 Posted October 22, 2016 Report Share Posted October 22, 2016 Sometimes you just gotta be different or run what you got. Funny thing is I brought my dcom to an alpha specific repair shop and they didn't know anything about em Quote Link to comment
banzai510(hainz) Posted October 22, 2016 Report Share Posted October 22, 2016 be honest how is the carb going to know when a piston moving down sucking up air is different from a Alfa Romero than a Datsun. Unless its full of hoses for emissions which I think could still be made to work. 1 Quote Link to comment
Ron1200 Posted November 14, 2016 Report Share Posted November 14, 2016 Search and ye will be enlightened.... The first one is here on the Ratsun forum and it has lots of pics. Weber carb guys DCOE/DCOM jets and misc. Q's? "I have dual DCOM 40's , pretty much DCOEs with upgraded pump system" Difference between DCOM and DCOE carbs? "WEBER 40 DCOE: float in brass and pump system has integrated return. WEBER 40 DCOM: float in plastic and exterior return pumps. Fuel regulation is identical" Weber OEs and OM differences "I've been digging out jets and chokes from the DCOEs that I got for use in my DCOMs. I thought I'd share some of what I'm finding now that I have both side by side. The jets, chokes, tubes and gaskets are all interchangeable. However the carriers are different. The OMs on the right in the pic show an O ring for the idle jet carrier and the OE has two sets of threads. For the main assembly the carrier itself is the air corrector and would have to be drilled out to be able to use air correctors from the OE style.On the pic of the bottom of the carbs you can see the big difference in the OM has a mechanical accelerator pump and the OE has jets for this circuit. I also noticed that the OM has a lock down for the venturies where the OE uses the air horns to lock it all in place.The top view shows alot of changes. The OM fuel inlet is on the top and has a filter on the banjo bolt. OE is on the side and has a separate top mount for the filter all by itself. The OM also has both metered and direct vacuum ports and no accelerator jets." Quote Link to comment
