Sastis Posted October 10, 2016 Report Share Posted October 10, 2016 when I got it. how she sit engine bay I need help putting this back together figure out the lights how she sit, it's low. Need to unlow it. Help!!! Quote Link to comment
banzai510(hainz) Posted October 10, 2016 Report Share Posted October 10, 2016 turn the battery around so the positive don't slide into the hood and short out the rear lights I would find the full rear harness and just plug it in. you have point ignition? cause I don't see a ballast resisitor. which would be needed otherwise youll short out points and misfire. if electric you might be OK. Quote Link to comment
Sastis Posted October 10, 2016 Author Report Share Posted October 10, 2016 turn the battery around so the positive don't slide into the hood and short out the rear lights I would find the full rear harness and just plug it in. you have point ignition? cause I don't see a ballast resisitor. which would be needed otherwise youll short out points and misfire. if electric you might be OK. front side lights are on, going to figure out the back. Will report back Quote Link to comment
flatcat19 Posted October 10, 2016 Report Share Posted October 10, 2016 Matchbox dizzy, check. Quote Link to comment
hobbes_the_cat Posted October 10, 2016 Report Share Posted October 10, 2016 Keep it low. :) looks like it has a few mods. What's it have for suspension? I see camber plates. Quote Link to comment
datzenmike Posted October 10, 2016 Report Share Posted October 10, 2016 Matchbox dizzy, check. Yes, but has to have matchbox coil too. Probably does. Keep it low. :) looks like it has a few mods. What's it have for suspension? I see camber plates. and why are they so far out side to side????? and I see rear camber happening. Quote Link to comment
hobospyder Posted October 11, 2016 Report Share Posted October 11, 2016 Hey, nice I want those wheels if you replace them.... I think Quote Link to comment
Sastis Posted October 11, 2016 Author Report Share Posted October 11, 2016 Yes, but has to have matchbox coil too. Probably does. and why are they so far out side to side????? and I see rear camber happening. dp racing adjustable coilovers. Rears cut spring I'm not sure Mike. Help?? Hey, nice I want those wheels if you replace them.... I think trade me the bumperettes ;D All side and back lights work, high beam doesn't. Any suggestions guys. Quote Link to comment
hobospyder Posted October 11, 2016 Report Share Posted October 11, 2016 trade me the bumperettes ;D yeah i do like those, and the bumperettes are staying with little miss sorry, i have plans others might disapprove of :rofl: also, high beams, do your low beams turn off when trying to turn on the highs and then come back on? if so i would say check for a relay and make sure it's working right, if the lows straight up turn off and nothing when the highs are supposed to be on i'm thinking your contacts might be bad on your switch Quote Link to comment
hobospyder Posted October 11, 2016 Report Share Posted October 11, 2016 also i have a single c-pillar vent, don't know what side it goes on but i have one Quote Link to comment
DatMo Posted October 11, 2016 Report Share Posted October 11, 2016 Looks fun. Kinda wish I had a four door too. Quote Link to comment
Sastis Posted October 11, 2016 Author Report Share Posted October 11, 2016 yeah i do like those, and the bumperettes are staying with little miss sorry, i have plans others might disapprove of :rofl: also, high beams, do your low beams turn off when trying to turn on the highs and then come back on? if so i would say check for a relay and make sure it's working right, if the lows straight up turn off and nothing when the highs are supposed to be on i'm thinking your contacts might be bad on your switch low beam stay on when I try to turn high beams on. No high beam at all. I'll recheck the wire tomorrow. How much for the c pillar? :D L18 with 210 head. Should I just throw a l20b in there or do a lz engine? Quote Link to comment
flatcat19 Posted October 11, 2016 Report Share Posted October 11, 2016 I know a guy looking for an L18 crank. Quote Link to comment
hobospyder Posted October 11, 2016 Report Share Posted October 11, 2016 still???? holy balls man Quote Link to comment
Sastis Posted October 11, 2016 Author Report Share Posted October 11, 2016 I know a guy looking for an L18 crank. there is a free l18 on Craigslist. I'll get buuuut I have no more space. 1 Quote Link to comment
hobospyder Posted October 11, 2016 Report Share Posted October 11, 2016 there is a free l18 on Craigslist. I'll get buuuut I have no more space. grab it and drive it to sedro woolley, i'll put the crank with his master cylinder Quote Link to comment
Sastis Posted October 11, 2016 Author Report Share Posted October 11, 2016 grab it and drive it to sedro woolley, i'll put the crank with his master cylinder work graveyard shift at Fred Meyer Quote Link to comment
hobospyder Posted October 11, 2016 Report Share Posted October 11, 2016 shit you have more daylight time than i do, if you missed some sleep. i have a friend that does that, haven't seen her since i hit first shift Quote Link to comment
flatcat19 Posted October 11, 2016 Report Share Posted October 11, 2016 Send hobo the link. He'd love to grab it for me to help shut me up. Any other ratsunites able to handle this? Quote Link to comment
hobospyder Posted October 11, 2016 Report Share Posted October 11, 2016 Don't send hobo the link, he's supposed to be sleeping Quote Link to comment
hobospyder Posted October 11, 2016 Report Share Posted October 11, 2016 Also i sent it to gato already. Quote Link to comment
flatcat19 Posted October 11, 2016 Report Share Posted October 11, 2016 Whoever grabs it can keep the C/C head for themselves. I only want the crank. Quote Link to comment
edekalil Posted October 11, 2016 Report Share Posted October 11, 2016 when I got it. how she sit engine bay I need help putting this back together figure out the lights how she sit, it's low. Need to unlow it. Help!!! Nice car, I like it. Quote Link to comment
banzai510(hainz) Posted October 11, 2016 Report Share Posted October 11, 2016 no high beam? but still low beam when you pull stalk back for Highbeam? Do you hear a relay click near the fuse box/ strut? if not . then the turn signal switch might not be putting a ground on the relay. or the aftermarket steering wheel don't have the arm ground correct. that car is straight. hope you take care of it Quote Link to comment
Sastis Posted October 11, 2016 Author Report Share Posted October 11, 2016 no high beam? but still low beam when you pull stalk back for Highbeam? Do you hear a relay click near the fuse box/ strut? if not . then the turn signal switch might not be putting a ground on the relay. or the aftermarket steering wheel don't have the arm ground correct. that car is straight. hope you take care of it no click, when I pop it in high beam. I look under the dash I see 2 silver flasher and 1 small flasher. What is the correct screw size for the steering column. Quote Link to comment
