Lozer Posted March 28, 2016 Report Share Posted March 28, 2016 Hey all, I picked up a dime from our FB page and it came with a set of Su's they look to be 44mm inlets so im thinking early z su's but im not sure as the fuel line and overflow don't look quite right. Anyhow after a bit of tuning they are pretty rich with the adjuster nut turned all the way up. need to know what they are so i can order needles. Quote Link to comment
flatcat19 Posted March 28, 2016 Report Share Posted March 28, 2016 1.) That is not OUR facebook page. 2.) How many bolts are holding the carb on to the manifold? 1 Quote Link to comment
Lozer Posted March 28, 2016 Author Report Share Posted March 28, 2016 2 bolts are holding each carb to the manifold. But the carbs have 4 bolt holes each. Quote Link to comment
Doctor510 Posted March 28, 2016 Report Share Posted March 28, 2016 They are the SSS version, 38mm What "needles" are you looking for, the jet needle or the needle and seat float valve? Make sure that the jets are not sticking in the "down" position after using the choke. 1 Quote Link to comment
datzenmike Posted March 28, 2016 Report Share Posted March 28, 2016 Z car and Fairlady roadster were 4 bolt while the L16/18SSS were two bolt mounting as evidenced by the two bolt SSS intake. Z car SUs were 46mm?.... 1.81" Roadster 40mm? ............ 1.57" The SSS were 38mm....... 1.49".... anyone? 2 Quote Link to comment
Lozer Posted March 28, 2016 Author Report Share Posted March 28, 2016 thanks guys. I understand the measurements are taken from the butterfly side, but what are the measurements for those same carbs on the inlet/ air filter side? Quote Link to comment
Draker Posted March 28, 2016 Report Share Posted March 28, 2016 http://ztherapy.com/technical_stuff/spotterguides/510/510_su.htm http://ztherapy.com/technical_stuff/spotterguides/zcar/240spotter.htm http://ztherapy.com/technical_stuff/spotterguides/roadster/main.htm http://ztherapy.com/products/volvo/VolvoSubIndex.htm 2 Quote Link to comment
Draker Posted March 28, 2016 Report Share Posted March 28, 2016 For needles: http://ztherapy.com/products/masterprices/master_price_list.htm Quote Link to comment
docbainey Posted March 29, 2016 Report Share Posted March 29, 2016 Roadster was 46mm also, inlet side is around 43mm. 46s go really good on an L20, need tuned of course You can turn that thing into a screamer with some minor porting and a small cam! 1 Quote Link to comment
Lozer Posted March 30, 2016 Author Report Share Posted March 30, 2016 Draker thanks for those links. Confirmed they are roadster carbs. My wide band will be on for tuning. Now I've gotta see what cam I have with the u67 head and go from there. 1 Quote Link to comment
KoHeartsGPA Posted March 30, 2016 Report Share Posted March 30, 2016 Is there any stamp in that cam? U20?...is stock for the U67 head. 1 Quote Link to comment
datzenmike Posted March 30, 2016 Report Share Posted March 30, 2016 All L20B cams wee the same. .413" valve lift 248 duration (but I doubt this is at the usual 0.050" valve lift position most cam makers use 2 Quote Link to comment
Lozer Posted April 1, 2016 Author Report Share Posted April 1, 2016 I haven't measured lift yet but i did a quick valve adjustment and snapped some pics of the cam markings. No u20 but heres what i found and it doesn't appear to be a regrind. theres a bunch of marking on the back but i cant get in there to see it, i need a mirror. I dialed in the carbs and took it for a run and it seems fine no knocks or smells that are abnormal. Pulls ok for an l20 and has nice top end and i love the sound of the su's at WOT. Quote Link to comment
datzenmike Posted April 1, 2016 Report Share Posted April 1, 2016 Looks like L20B cam. Does not appear to be ground down and is stock. Measure across the lobe at highest and 90 degrees to that and subtract. Should be close to 0.276" Quote Link to comment
