74datto Posted June 5, 2007 Report Share Posted June 5, 2007 has anyone ever installed a set of hooker headers on a 1974 620 with an L18 Quote Link to comment
Z-train Posted June 6, 2007 Report Share Posted June 6, 2007 Whadda ya need to know? Quote Link to comment
nismopu Posted June 6, 2007 Report Share Posted June 6, 2007 im sorry i hate to be a technical nit pick but this is by far my biggest pet peeve. It is a header(singular) and not a v8 which takes headers(plural), lol. Anyway, my limited experience with this header is that my friend could never get his to seal correctly and ran like to or three custom gaskets under its surface. peace. Quote Link to comment
datzenmike Posted June 7, 2007 Report Share Posted June 7, 2007 Some thoughts on header: + they are nice and loud. - they are loud. + cool looking - they soon become rusty, ugly and leak and you stop opening your hood. + they add 10-15 horsepower - finding out that you maybe have 5 extra horses but you have to go to 6,500 RPMs to find them. - convincing yourself that the $100+ you paid was worth half the weekend spent removing a perfectly good and functional manifold, cutting a perfectly good exhaust pipe, removing the torsion bar and loosening the motor mount to install, removing the mounting bolts three times before you finally get the intake air leak sealed, and hoping that it will last at least a few years, or long enough for you to end this failed relationship with some dignity, get out the Saws-All and begin a trial separation, and finally move on. Quote Link to comment
Guest DatsuNoob Posted July 9, 2007 Report Share Posted July 9, 2007 Yes, I've wrestled one onto an L20b before. Let me start off by saying... IT WAS A BITCH!!! Removing the torsion bar for this project will not be necessary, however removing the radiator is a must. After you remove it, unbolt your motor mounts, and slide the motor and trans forward just before the driveline falls out of the slip yoke. This will allow you to cram 10lbs of shit into a 5lb bag. The header, if its a long type(if it's a shorty, dont bother doing all previously said steps) will sit very tight to the tranny and miss the torsion bar by 1/8". I think it would be a good idea to pad the torsion bar with a small chunk of header wrap or heat tape unless you like the clanging noise when you start your engine. I wish I'd've wrapped my header, they get way hotter than the old stovepipe exhaust manifold. Good luck! :D Quote Link to comment
Bleach Posted July 9, 2007 Report Share Posted July 9, 2007 In my straight six L-series I installed headers. I would agree that they were much louder and I noticed no improvement in power. I think I got lucky and my header never rusted up. I had it on there for 6 years and probably 80K miles. I don't recomend it on engines that are not built up for larger intake first. Ported manifolds/dual webers, ported intake, big cam, all that comes first. Quote Link to comment
]2eDeYe Posted July 9, 2007 Report Share Posted July 9, 2007 Removing the torsion bar is pretty simple If you wrap that header you'd be replacing it in a year or so. Quote Link to comment
culowdragger72 Posted July 21, 2007 Report Share Posted July 21, 2007 i put a shorty header on my 521, i had to notch part of the crossmember. i did got alot more power on the low end, my engine revs alot higher. sounds good with a 2" pipe and turbo muffler exit before axle. Quote Link to comment
lynchfourtwenty Posted July 22, 2007 Report Share Posted July 22, 2007 dont know what one i got.. i like it.. and yes i know its ugly but it was on there when i got it and i've had no problems (yet) Quote Link to comment
