MicroMachinery Posted December 23, 2015 Report Share Posted December 23, 2015 Its your car; you can put whatever you want in it. For all the headache and heartache, however, I don't think a GM 2.8 would give you much more power than an L20b... Not to mention how much less reliable it would be. 1 Quote Link to comment
tr8er Posted December 23, 2015 Report Share Posted December 23, 2015 Mostly for looks... Quote Link to comment
MicroMachinery Posted December 23, 2015 Report Share Posted December 23, 2015 Definitely not for ease of installation. Quote Link to comment
logiccreations Posted December 23, 2015 Author Report Share Posted December 23, 2015 this is the engine i have Quote Link to comment
MicroMachinery Posted December 23, 2015 Report Share Posted December 23, 2015 Nothing wrong with that one. It's even red(faster). Quote Link to comment
flatcat19 Posted December 23, 2015 Report Share Posted December 23, 2015 i have one im looking for more power LZ the damned thing. Gobs of power. Way less $. So much easier than anything else you're wanting. Quote Link to comment
logiccreations Posted December 23, 2015 Author Report Share Posted December 23, 2015 how do i do that? ... also how do i change the title of the tread... ya i painted it Quote Link to comment
datzenmike Posted December 23, 2015 Report Share Posted December 23, 2015 this is the engine i have First ....how did you get to -20 in Oregon? You're in the heart of the PNW and full of Datsuns. Place an ad in the classifieds for one. Get one running and fix yours. Zero compression is virtually impossible on 3 cylinders. how do i do that? ... also how do i change the title of the tread... ya i painted it Go pack to your first post and hit the EDIT button at the middle bottom underneath it. Then select Use Full Editor. This will bring up the title that you can now edit. Quote Link to comment
flatcat19 Posted December 23, 2015 Report Share Posted December 23, 2015 Z22 short block. L20B everything else. Quote Link to comment
logiccreations Posted December 23, 2015 Author Report Share Posted December 23, 2015 weather, it gets really cold sometimes Quote Link to comment
TENDRIL Posted December 23, 2015 Report Share Posted December 23, 2015 is the turbo ford 2.3 isnt that a good motor? Quote Link to comment
logiccreations Posted December 23, 2015 Author Report Share Posted December 23, 2015 lets just mark any ford engine off my list Quote Link to comment
Draker Posted December 23, 2015 Report Share Posted December 23, 2015 weather, it gets really cold sometimes Out in Burns... I bet it gets REALLY cold. 1 Quote Link to comment
KoHeartsGPA Posted December 24, 2015 Report Share Posted December 24, 2015 Out in Burns... I bet it gets REALLY cold. And HOT This thread is criminal. Quote Link to comment
logiccreations Posted December 24, 2015 Author Report Share Posted December 24, 2015 whys that? Quote Link to comment
logiccreations Posted February 16, 2016 Author Report Share Posted February 16, 2016 so i rebuilt it but the distributor doesnt spin with the engine or at all for that matter along with no spark which led to the discovery of the distributor problem Quote Link to comment
datzenmike Posted February 16, 2016 Report Share Posted February 16, 2016 Then take the distributor off and look at the top of the drive spindle down inside. Crank the engine over. Is the spindle turning???? Quote Link to comment
logiccreations Posted February 16, 2016 Author Report Share Posted February 16, 2016 no i did that Quote Link to comment
datzenmike Posted February 16, 2016 Report Share Posted February 16, 2016 No the spindle is not turning? Then you forgot to install the worm gear on the crank or the woodruf key that locks it to the crank snout. 1 Quote Link to comment
logiccreations Posted February 16, 2016 Author Report Share Posted February 16, 2016 well something is holding it up in there it doesnt spin. but the engine cranks fine, no noises and such Quote Link to comment
datzenmike Posted February 16, 2016 Report Share Posted February 16, 2016 The oil pump holds it up in there. Unbolt the pump and let the spindle drop out. Look up inside for the drive worm gear. Maybe set to TDC just in case. If it's there, reach up with screwdriver and try to spin it on the crank. Quote Link to comment
logiccreations Posted February 16, 2016 Author Report Share Posted February 16, 2016 i grabbed the spindle with pliers and tried to spin it but it wont. and will pull it apart tomarow Quote Link to comment
KoHeartsGPA Posted February 16, 2016 Report Share Posted February 16, 2016 No the spindle is not turning? Then you forgot to install the worm gear on the crank or the woodruf key that locks it to the crank snout. My money is on ^ Check that, bud! Quote Link to comment
datzenmike Posted February 16, 2016 Report Share Posted February 16, 2016 The sprocket and the worm gear are locked to the crank by woodruf keys. They are half moon shape. 1 Quote Link to comment
logiccreations Posted February 16, 2016 Author Report Share Posted February 16, 2016 all on there i must have just not gotten it lined up or something? Quote Link to comment
