jovial_cynic Posted September 30, 2008 Report Share Posted September 30, 2008 Specifically, I need a flywheel from any CAR L20b (not truck), or the flywheel from the 80/81 200sx (Z20e). So... 6-bolt flywheel, that'll mate up to a 200mm pressure plate. I'm in the Lacey/Olympia area. Let me know what you want for it, either cash or parts. I might have something you want. Link to comment
tdaaj Posted September 30, 2008 Report Share Posted September 30, 2008 i've got one in a 710 wagon but i'll have to pull the engine first. Link to comment
jovial_cynic Posted September 30, 2008 Author Report Share Posted September 30, 2008 ah, cool. Let me know. I'm not in a terrible hurry, since I'm still able to rock the car in gear to engage the flywheel when I hit that flat spot. :D Link to comment
datzenmike Posted September 30, 2008 Report Share Posted September 30, 2008 Specifically, I'd like a roadster flywheel, as that'll mate up appropriately with my roadster clutch assembly, but apparently I can use a flywheel from any CAR L20b (not truck), as well as the flywheel from the 80/81 200sx (Z20e). So... 6-bolt flywheel, that'll mate up to a 200mm pressure plate. I'm in the Lacey/Olympia area. Let me know what you want for it, either cash or parts. I might have something you want. The Roadster flywheel is no good for you it won't fit the Lseries engines BUT the 200mm clutch and PP will. If you have an L20B flywheel from a car it should slso fit the 200mm clutch. Link to comment
hang_510 Posted September 30, 2008 Report Share Posted September 30, 2008 i have one avail, but youll have to ship also. Link to comment
jovial_cynic Posted September 30, 2008 Author Report Share Posted September 30, 2008 The Roadster flywheel is no good for you it won't fit the Lseries engines BUT the 200mm clutch and PP will. If you have an L20B flywheel from a car it should slso fit the 200mm clutch. Thanks - fixed the original post. Hang_510 - how much total, including shipping? Link to comment
hollywoodca Posted October 3, 2008 Report Share Posted October 3, 2008 have an alumiun 6 bolt flywheel and lots of other parts. give a call at 604-306-5647 or e-mail at merrittspeedway@shaw.ca Link to comment
jovial_cynic Posted October 3, 2008 Author Report Share Posted October 3, 2008 how much for the aluminum flywheel? Link to comment
datzenmike Posted October 3, 2008 Report Share Posted October 3, 2008 Don't forget that the flywheel is needed for storing energy needed to get the car moving from a start. Lightened wheels are great for racing where there are few stops and frees up a small amount of power usually used to spin the heavy flywheel up to speed along with the car. Is used on a DD and/or around town, more gas and clutch slipping will be needed at stops and there is a tendency to easily stall. How much can you live with? Link to comment
jovial_cynic Posted October 3, 2008 Author Report Share Posted October 3, 2008 datzenmike - oh, i know. i've recently given that some thought. I was just curious about the price. I've got a big grumbly cam on my engine as it is, and I think that a light flywheel would really decrease drivability. again - just curious. Link to comment
SHADY280 Posted October 4, 2008 Report Share Posted October 4, 2008 email sent for the aluminum flywhell. i need one for my z racecar Link to comment
motavated Posted October 4, 2008 Report Share Posted October 4, 2008 I have a aluminum flywheel and it drives great in my truck. No stalling or nothing. The only thing I did not like was that the "pins" Didn't line up correctly. I installed the clutch with out being perfectly aligned. I'm going to take it off and try too see if a machine shop can align my clutch with the flywheel and put on those 3 "pins" that it needs. Or just take it off and use the stock one... Link to comment
motavated Posted October 4, 2008 Report Share Posted October 4, 2008 have an alumiun 6 bolt flywheel and lots of other parts. give a call at 604-306-5647 or e-mail at merrittspeedway@shaw.ca Btw what type of flywheel do you have "brand"? Link to comment
hollywoodca Posted October 4, 2008 Report Share Posted October 4, 2008 I have one and selling it for 150.00 in good shape thanks Keith 604-306-5647 Link to comment
SHADY280 Posted October 5, 2008 Report Share Posted October 5, 2008 hey sent email, but it comes back bunged up, maybe ill phone, price is good, and your in my area, so no shipping then. Link to comment
jovial_cynic Posted October 5, 2008 Author Report Share Posted October 5, 2008 I've got a new ring-gear coming in, folks - keep this thread open for whoever else is looking for a flywheel. I don't need one at this point. Link to comment
mklotz70 Posted October 5, 2008 Report Share Posted October 5, 2008 I had a dozen or so bad teeth on the ring gear of the flex plate of my first 510. I was able to weld the teeth back up and shape them with a 4" grinder. No problems after that. Just thought I'd add that as an option if someone just can' get a flywheel. Link to comment
SHADY280 Posted October 6, 2008 Report Share Posted October 6, 2008 keith phoned and message left. Link to comment
