Looking for a 6-bolt flywheel
Specifically, I need a flywheel from any CAR L20b (not truck), or the flywheel from the 80/81 200sx (Z20e).
So... 6-bolt flywheel, that'll mate up to a 200mm pressure plate.
I'm in the Lacey/Olympia area. Let me know what you want for it, either cash or parts. I might have something you want.
  • Replies 18
Specifically, I'd like a roadster flywheel, as that'll mate up appropriately with my roadster clutch assembly, but apparently I can use a flywheel from any CAR L20b (not truck), as well as the flywheel from the 80/81 200sx (Z20e).
The Roadster flywheel is no good for you it won't fit the Lseries engines BUT the 200mm clutch and PP will. If you have an L20B flywheel from a car it should slso fit the 200mm clutch.
Don't forget that the flywheel is needed for storing energy needed to get the car moving from a start. Lightened wheels are great for racing where there are few stops and frees up a small amount of power usually used to spin the heavy flywheel up to speed along with the car. Is used on a DD and/or around town, more gas and clutch slipping will be needed at stops and there is a tendency to easily stall. How much can you live with?
I have a aluminum flywheel and it drives great in my truck. No stalling or nothing. The only thing I did not like was that the "pins" Didn't line up correctly. I installed the clutch with out being perfectly aligned. I'm going to take it off and try too see if a machine shop can align my clutch with the flywheel and put on those 3 "pins" that it needs. Or just take it off and use the stock one...
I had a dozen or so bad teeth on the ring gear of the flex plate of my first 510. I was able to weld the teeth back up and shape them with a 4" grinder. No problems after that. Just thought I'd add that as an option if someone just can' get a flywheel.
