djwarp Posted September 12, 2015 Author Report Share Posted September 12, 2015 So i have a question for all of you i have a 3in drop on my truck I’ve notice theres no shocks in the front of the truck making my truck bounce every where after a bump what do y’all think i should buy what kinda of strut idk if the original will fit since i have a 3in drop. 1 Quote Link to comment
datzenmike Posted September 12, 2015 Report Share Posted September 12, 2015 You physically have NO shock absorbers? OR the front is just bouncy and the shocks that are on it are not doing much. You don't have struts on a 521. A strut is usually both a coil spring and a shock absorber in one, and is also a stressed part of the steering. The 521 has a torsion bar which is just a different kind of spring and a separate and reasonably easy to replace shock absorber. 1 Quote Link to comment
datson4life Posted September 12, 2015 Report Share Posted September 12, 2015 I heard ford pinto shocks work for front on lowered 521, i heard so im not 100% 1 Quote Link to comment
datson4life Posted September 12, 2015 Report Share Posted September 12, 2015 Also part number djm1115 1 Quote Link to comment
flatcat19 Posted September 12, 2015 Report Share Posted September 12, 2015 Pinto fronts; 620 rears. Both are shorter bodied shocks. ------------------------------------- KYB Gas-A-Just Rear Shocks - KG4605A - Same product in CarQuest box 1844257KYB Gas-A-Just Pinto Front Shocks - KG4511 1 Quote Link to comment
djwarp Posted September 12, 2015 Author Report Share Posted September 12, 2015 there are no shock observers they guy who sold it to me took them out 1 Quote Link to comment
mhub91 Posted September 12, 2015 Report Share Posted September 12, 2015 lol wow 1 Quote Link to comment
datzenmike Posted September 12, 2015 Report Share Posted September 12, 2015 Pinto shocks fit but are only marginally shorter. If I had shocks I wouldn't bother but if you have none at all, get them rather than those for a 620. The problem with a lowered vehicle is there is less room for the suspension to travel and 'absorb' bumps. It bottoms out and then you are bouncing on the air in the tires like a basketball. On severely lowered vehicles the tire IS your suspension. Mr. warp, on the lower control arms farther just inward toward the center of the vehicle from where the bottom end of the shock mounts, is a metal pad. Just above it is a large rubber stopper or bump stop on the frame. It's there just to cushion the parts if there was a severe compression of the suspension. To get a little more travel, this rubber can be trimmed but only slightly. 1 Quote Link to comment
banzai510(hainz) Posted September 12, 2015 Report Share Posted September 12, 2015 let get back the the orginal ? is this truck running ??????? just buy some cheap 521 shocks and remove the rubber block its a 12mm bolt 1 Quote Link to comment
djwarp Posted September 12, 2015 Author Report Share Posted September 12, 2015 let get back the the orginal ? is this truck running ??????? just buy some cheap 521 shocks and remove the rubber block its a 12mm bolt yea the truck is running i just added some sea foam to clean the engine and i notice the radiator has a crack so i sealed it waiting to get paid to buy a new one drove it the other day seems good. 1 Quote Link to comment
banzai510(hainz) Posted September 13, 2015 Report Share Posted September 13, 2015 that's great!!!!!!!!! got got to lets us now what you did and fix before you come up with next issue. 2 Quote Link to comment
djwarp Posted September 14, 2015 Author Report Share Posted September 14, 2015 i just put the new thermo housing in adjusted the carb it was idling really high and waiting to order the new radiator 1 Quote Link to comment
banzai510(hainz) Posted September 14, 2015 Report Share Posted September 14, 2015 adjusted the carb it was idling really high ???? well fix that. Lots of write ups on adjusted these. YOu even have a timming light? 1 Quote Link to comment
Phixius Posted September 14, 2015 Report Share Posted September 14, 2015 get 01-04 xterra shocks. no mods needed like the pinto. 1 Quote Link to comment
djwarp Posted September 17, 2015 Author Report Share Posted September 17, 2015 adjusted the carb it was idling really high ???? well fix that. Lots of write ups on adjusted these. YOu even have a timming light? I do have a timing light get 01-04 xterra shocks. no mods needed like the pinto. i bought those 1 Quote Link to comment
djwarp Posted September 21, 2015 Author Report Share Posted September 21, 2015 So i have a question i just finish putting on the new radiator and i turn the truck on i hear this very high whistling sound coming out of the carb ... anyone might know what this might be? 1 Quote Link to comment
TENDRIL Posted September 21, 2015 Report Share Posted September 21, 2015 carb gasket failed? on my weber this happened once, bad gasket, also will probably cause a high idle 1 Quote Link to comment
djwarp Posted September 21, 2015 Author Report Share Posted September 21, 2015 carb gasket failed? on my weber this happened once, bad gasket, also will probably cause a high idle ill check that out thanks. 1 Quote Link to comment
datzenmike Posted September 21, 2015 Report Share Posted September 21, 2015 Vacuum line hose off or loose. 1 Quote Link to comment
banzai510(hainz) Posted September 22, 2015 Report Share Posted September 22, 2015 if cheap carb adapter this can crack and cause no idle 2 Quote Link to comment
djwarp Posted September 24, 2015 Author Report Share Posted September 24, 2015 i fixed the sound it was the fuel line it was cracked I also the new shocks on so the one it had on was garbage it wasn’t doing nothing and on the driver side there was one missing ... also noticed that my oil pan was leaking so i just drained the oil today removing the pan this weekend and replacing the gasket. just an update for those who care lol 1 Quote Link to comment
TENDRIL Posted September 24, 2015 Report Share Posted September 24, 2015 if i remember correctly the oil pan gasket isnt the easiest to do, i think the best way is to un bolt the motor mounts and lift the engine 2-4 more in. 1 Quote Link to comment
datson4life Posted September 24, 2015 Report Share Posted September 24, 2015 i fixed the sound it was the fuel line it was cracked I also the new shocks on so the one it had on was garbage it wasn’t doing nothing and on the driver side there was one missing ... also noticed that my oil pan was leaking so i just drained the oil today removing the pan this weekend and replacing the gasket. just an update for those who care lol I care! But i dont think ive seen a pic of the whole truck 2 Quote Link to comment
TENDRIL Posted September 24, 2015 Report Share Posted September 24, 2015 yea we care ! well some of us! mostly because we want to see em on the road again! and i agree more pics 1 Quote Link to comment
banzai510(hainz) Posted September 24, 2015 Report Share Posted September 24, 2015 make sure its not the oil sender leaking making it look like a oil pan gasket. This is harder than one thinks!!!!!!! to get under the pick up inside the oil pan 1 Quote Link to comment
