joeyk803c Posted October 2, 2014 Report Share Posted October 2, 2014 So I live in CA... next to a dumb broad on welfare... well I bought a sander to sand down the cracking bondo on my truck. The neighbor comes over and says I can't do it. Anybody else have this issue? I'm searching, but so far haven't seen anything saying I can't sand my truck down in the driveway. I was finished doing what I needed to do, so it wasn't a big deal ya know... what is she going to bitch about next? Quote Link to comment
Son_of_a_Datsun_Guy Posted October 2, 2014 Report Share Posted October 2, 2014 Nothing illegal about using power tools in your driveway, not even anything toxic in bondo that I know of to stop you from sanding it off. 1 Quote Link to comment
MikeRL411 Posted October 2, 2014 Report Share Posted October 2, 2014 So I live in CA... next to a dumb broad on welfare... well I bought a sander to sand down the cracking bondo on my truck. The neighbor comes over and says I can't do it. Anybody else have this issue? I'm searching, but so far haven't seen anything saying I can't sand my truck down in the driveway. I was finished doing what I needed to do, so it wasn't a big deal ya know... what is she going to bitch about next? As long as you confine your sanding to daylight hours and not between say 8PM and 6AM you should be in the clear. Yhe only other thing would require her to get a fully calibrated sound meter and proove that on her property you exceeded some OSHA decible level. Same problem of proof when your neighbor has very loud parties at 10PM. Just throw a lit pack of firecrackers over the fence and forget about calling the cops. 1 Quote Link to comment
MikeRL411 Posted October 2, 2014 Report Share Posted October 2, 2014 Nothing illegal about using power tools in your driveway, not even anything toxic in bondo that I know of to stop you from sanding it off. Except for the dust nuiscence. Watch the wind direction! Quote Link to comment
joeyk803c Posted October 2, 2014 Author Report Share Posted October 2, 2014 No wind (well hardly any), all the dust ended up on my driveway/truck. She had the gall to walk right into the dust, then bitch me out for sanding down the paint on my truck. Quote Link to comment
datzenmike Posted October 2, 2014 Report Share Posted October 2, 2014 If it's your home or you are renting and as long as there is no home owners association that doesn't allow work outside your garage.... fly at 'er. If there's a problem mention the guy she's been living with while on welfare. If she says 'what guy I'm not living with anyone.' Say well I hope welfare figures that out.... eventually. Does she have kids? Even better. 1 Quote Link to comment
joeyk803c Posted October 2, 2014 Author Report Share Posted October 2, 2014 My brother has called Welfare/section 8. Told the manager of the property upfront what's going on a few weeks ago and nothing. I'll continue to work on it friday. If she says something, I'll call her out. Thanks for all the help. Quote Link to comment
MicroMachinery Posted October 2, 2014 Report Share Posted October 2, 2014 Next time she walks into your driveway, pretend like you're going to pull "it" out.. 1 Quote Link to comment
tr8er Posted October 2, 2014 Report Share Posted October 2, 2014 If say, be courteous. She likely sees the thing much different from us. Tell her you don't think you are doing anything in violation, but understand that noise can be a bother. Ask her if there are particular times that are better than others for you to work. Like when Jerry Springer is not on. And you will try to respect it. And in return, she needs to respect that if you are working, it is because you need to work, and the time you chose was considered. Then kick her in the teeth and pee on her! Alpha 5 Quote Link to comment
bananahamuck Posted October 2, 2014 Report Share Posted October 2, 2014 If say, be courteous. She likely sees the thing much different from us. Tell her you don't think you are doing anything in violation, but understand that noise can be a bother. Ask her if there are particular times that are better than others for you to work. Like when Jerry Springer is not on. And you will try to respect it. And in return, she needs to respect that if you are working, it is because you need to work, and the time you chose was considered. Then kick her in the teeth and pee on her! Alpha I think she would be more attentive to what your telling her if you started out by kicking her in the teeth,,, and working back from there. Quote Link to comment
joeyk803c Posted October 2, 2014 Author Report Share Posted October 2, 2014 She came over and started ranting on "you can't be doing that here... its not the place..." Then tells me her baby has been congested since I've started sanding the truck... I had sanded it for 15 minutes. I'm going to park it on the other side of the driveway, away from her house and continue sanding. If she bitches, I'll give her the finger. Quote Link to comment
hobospyder Posted October 2, 2014 Report Share Posted October 2, 2014 Yeah as long as you're on your property and there's no hoa and you aren't causing a noise nuisance or air pollution you're fine. Tell her to call the cops and they'll tell her the same thing I'm sure. I've heard of it happening before at least. Just don't get caught painting without proper filtration, that'll get you a major fine Quote Link to comment
tr8er Posted October 2, 2014 Report Share Posted October 2, 2014 Even sanding. Get a vaccuum and hook it up to your sander. Makes much cleaner. I do this without neighbors . Quote Link to comment
joeyk803c Posted October 2, 2014 Author Report Share Posted October 2, 2014 It's just a 7" rotary sander from HF. No vacuum hookup (I wish). I won't be painting it in my driveway, just sanding down the old paint so I can body work it and then send it off for paint. Considering there is a house behind hers that just had all the concrete ripped up, I doubt the dust from me is causing any harm. I'll sand down so much, then vacuum up the dust and then proceed again. Quote Link to comment
uberkevin Posted October 2, 2014 Report Share Posted October 2, 2014 Tell her she can't wash her car in her drive way. If she has one. "It's not the place" they build business for that shit. Do what you what man. Fuck her. Ha. Thats your place and you've got the right to do what you feel you need done. I don't think she knows what she's talking about. Quote Link to comment
tr8er Posted October 2, 2014 Report Share Posted October 2, 2014 Good nuff. I do recommend a sander with vac port next time. Not for the neighbors, it's just pretty sweet to not have all the cleanup. Quote Link to comment
shacks510 Posted October 2, 2014 Report Share Posted October 2, 2014 Give her the Ratsun salute. 1 Quote Link to comment
smoke Posted October 2, 2014 Report Share Posted October 2, 2014 If say, be courteous. She likely sees the thing much different from us. Tell her you don't think you are doing anything in violation, but understand that noise can be a bother. Ask her if there are particular times that are better than others for you to work. Like when Jerry Springer is not on. And you will try to respect it. And in return, she needs to respect that if you are working, it is because you need to work, and the time you chose was considered. Then kick her in the teeth and pee on her! Alpha I start off all potential controversy with peeing on the person. All of a sudden...the sanding will not seem like that big of a deal. Quote Link to comment
shacks510 Posted October 2, 2014 Report Share Posted October 2, 2014 FHRITP Took me a second :p 1 Quote Link to comment
datzenmike Posted October 2, 2014 Report Share Posted October 2, 2014 I start off all potential controversy with peeing on the person. All of a sudden...the sanding will not seem like that big of a deal. That's right. When I get a headache I just hit my thumb with a hammer. Quote Link to comment
joeyk803c Posted October 2, 2014 Author Report Share Posted October 2, 2014 Yeah next time I will. Just grabbed it because I was in a buying mode, not thinking mode. I'll resume sanding tomorrow, have more chipping/cracking bondo I need to sand down and fix. Quote Link to comment
hobospyder Posted October 3, 2014 Report Share Posted October 3, 2014 That's right. When I get a headache I just hit my thumb with a hammer.hey your head won't hurt Quote Link to comment
Dantheman Posted October 3, 2014 Report Share Posted October 3, 2014 There are laws on the volume of paint to be legally sprayed per day with out being in a confined spay booth. The volume is well higher than what you will be using. Call some one doing bumper repairs in your area and ask them about the laws. As far as the dust issue, you can use aircraft stripper and put the crap you scrape off on her door step. Quote Link to comment
joeyk803c Posted October 5, 2014 Author Report Share Posted October 5, 2014 I'm not spraying paint, well maybe some primer. Dumb bitch started complaining because I sprayed some primer... then she told me to "not do what I am thinking. I know what you're thinking, and you better not do what you're thinking" Then she started bitching me out because I was spraying some paint stripper onto the top of my cab. The shit comes out in a liquid foam like texture! How are her kids getting sick from that shit? they are 50 feet away! Quote Link to comment
