H165 Rear Disk Brake Brackets
blackmarkit
Hey Folks I made a set of H165 disk brake brakets for a buddies 610 wagon. I was wondering if anyone else would be interested in some. These brackets would be used on 610 wagons, 710 cars and wagons. Price would be $75 plus shipping.
9B3CE992-277E-4266-9A91-4B39053DDF8F_zps
D8EEDA02-23F5-43EC-93E5-99D1B120BC2E_zps
  • Replies 36
Are you sure it's H-165 and not H-190?
Up to July '73 all goons were H-165 diff. (this is just a few months)
From August '73 through to June '74 (the '74 model year) only the automatic goons had them.
From Aug '74 ('75 model year) on all goons had the H-190 diff.
All years and models of 710s had H-165 diffs.
Look very nice. I also have the zx rotors and calipers. hmmmmm.... Probably need 14" rims?
Yeah probably do need 14" rims. He is running 280zx turbo wheels. I should have as many sets as you guys want made by the end of next week.
You won't need 14s. I have these brakes on my 1200 and 13" wheels fit just fine.
I just noticed ,, can you not use parking brake,,  or is that a optical illusion?
The calipers shown have the ebrake built into the caliper.
A spring squeezes piston to rotor.
Look at the goofy handle thing to the inside of the caliper.
The 280zx uses parking brake cables that pull diagonally towards the front of the car. The 710 sedan /goon and the 610 goon use a horizontal linkage across the back of the differential that pull directly inwards to the center of the car. I looked at this last summer. The zx rear disc parking brake isn't perfect but could very likely be modified to work..
I Used The Stock E-Brake Cable From The Same 280ZX
And A 710 E-Brake Handle
The Stock 610 Handle Is The Same As The Trucks
710 Cable Is The Right Size
Stock 610 Cable Is Too Long
However You Cannot Use The 710 E-Brake Handle
If You Have A Swapped Transmission
Otherwise It Will Hit The Shifter In 2nd 4th Gear
You Will Need To Modify The Handle
