Draker Posted May 8, 2015 Report Share Posted May 8, 2015 Sorry to hear about the noise... You'll be able to remove it a lot quicker the second time around. Although it's never fun doing it twice.. Looks great though. You put a lot of time into it! 4 Quote Link to comment
Gradyfest Posted May 8, 2015 Author Report Share Posted May 8, 2015 s1172.photobucket.com/user/ShaneG/media/image_zpsazluvtup.jpg.html][/url] 2 Quote Link to comment
Gradyfest Posted May 8, 2015 Author Report Share Posted May 8, 2015 Pics are probably crazy out of order, but you can put it together in your mind... 1 Quote Link to comment
Gradyfest Posted May 8, 2015 Author Report Share Posted May 8, 2015 Will take out and solder it the right way later. 2 Quote Link to comment
Gradyfest Posted May 8, 2015 Author Report Share Posted May 8, 2015 Finally some finished photos. It was late and there not great though. I have not not put on all the skid and splash plates yet. I hope you all like oics as much as me! 3 Quote Link to comment
Gradyfest Posted May 8, 2015 Author Report Share Posted May 8, 2015 All that work and still a bearing noise... You can see why I'm disheartened... 2 Quote Link to comment
Draker Posted May 8, 2015 Report Share Posted May 8, 2015 I assure you.. we've all been there. It sucks.. You'll knock it out twice as fast. 3 Quote Link to comment
84720FourWheel Posted May 9, 2015 Report Share Posted May 9, 2015 You replaced the throw out, correct? But since the noise occurs when the clutch is engaged leads me to believe that it's in the transmission. Get a mechanics stethoscope and leave her running up on a lift, search for the area where the sound is loudest. I'd say it's the lower cluster bearing as that is the common failure point, but the low mileage makes be doubt that. I'd really want to make sure that I've got the culprit pinned before tearing back into it. Nice job on the t-case, I need to do that eventually, the shift rod seal leaks on mine. I'm confused about what the companion shaft wrench was for. 3 Quote Link to comment
KiloTango1200 Posted May 17, 2015 Report Share Posted May 17, 2015 Great documentation. Sorry for the setback. It happens to everyone. But the 2nd time is 3 times faster. 2 Quote Link to comment
Gradyfest Posted May 29, 2015 Author Report Share Posted May 29, 2015 Thanks guys. I'm still hesitant on pulling the motor and have to fit the the time in. But while it's in the drive way I thought I'd fix the exhaust leak at the manifold. It's making it not fun to drive. I'm in the middle of pulling the intake and exhaust manifold bolts off right now. What a pain in the ass! Some of these bolts seem impossible. The 12mm swivel socket has been the hero of the day so far. 1 Quote Link to comment
Gradyfest Posted May 29, 2015 Author Report Share Posted May 29, 2015 So I got as far as this. The intake is ready to come off but is connected by this EGR tube to the exhaust manifold. Both of these bungs are pretty corroded and I'm having trouble getting them loose. What a pain in the ass. I'm heading in town to get a line wrench for it. I'm not 100% on the size though. Wish I had a caliper... 1 Quote Link to comment
84720FourWheel Posted May 29, 2015 Report Share Posted May 29, 2015 Better pick up a bunch of pblaster 1 Quote Link to comment
Gradyfest Posted May 29, 2015 Author Report Share Posted May 29, 2015 I have it soaking now, I don't think I'm going to get this done tonight. I figured out that the lower bolt is a 24 mm. But my local Lowe's and O'Reillys don't carry a 24mm flare wrench. I guess I buy one online, or see if there is a snow balls chance in hell I can find this EGR tube and just cut it for now. 1 Quote Link to comment
