Smaller. Better. Slower. Lower.
Posting this is just a little overdue.
New project time. Ready?
  • Replies 66
This slot will be reserved for wants/needs.
This post will be updated a lot as I go.
Needs:
Battery tray repair
Matching locks
Carbs rebuilt
Radiator
Install engine/x-member
Wants:
Short 5 speed
Wheels w/proper lugnuts
200sx rear end
Build new engine
Proper bumpers
Tail light finisher that's not cracked
Needs:
MOARLOWS
Adding 400lbs of engine/trans will lower this thing a bit more.
It already has great stance. Just needs weight and wheels.
L20B............ 285
FS5W71B...... 70
About right....355
On stock struts that should lower about 1.75"
Wrong motor. Mike.
Close.
L18. SUs.
Still don't have a trans yet.
Looking for a short 5 speed.
Sitting on stock struts/cut springs.
Previous owner; Not me.
He said it was great though.
Wrong motor. Mike.
Close.
L18. SUs.
Screw the dogleg. Get a zx and make it fit. Tougher and plenty of replacements latter if needed.
I'll get a pic later but the ebrake would sit right over the shifter.
Longs are def. easier to source.
I've actually been looking for the short 2WD 720 trans.
I agree . Get a short 71B so the shifter comes out in the 210 factory location. Its tougher and easier to find.
71B is the strong one. That can live behind an L20B. The dogleg often wears out behind a 2-liter because it is a smaller 63 mm transmission.
That's the 720 trans then.
As far as I know it came in the 85-86 2WD regular cab 720.
