Bunny's 1200 coupe
Ranman72
  • Replies 121
the brakes work great  first test drive today
tie rod ends are so close to the rims after the bump steer spacers they rub the wheel weights  time for tape or swap the struts from side to side
new water pump was an L series one so off with the old and on with the old  A KNOWN NON LEAKING ONE
both seats are in
rear view mirror
and my old wood shift knob
all interior panels done
no carpet yet
IMG_20140412_211244_367_zps2zdeyj5f.jpg[/url
]IMG_20140412_211348_062_zpsvwpidgek.jpg[/u
RL]
  • Like 4
Did you see the link for the headlight wires i posted?
yes thank you
I was wondering if the ones on Egay for 23 were the right ones also
Give Tognotti's a call they probably have them. I just built mine for the B210 using some relays and some wire, probably cost like $10 and 30 mins.
the coolant splitter looked pretty good so I brazed the seam at the t and it is not leaking any more
took the car for a 15 mile test run
it runs great seemed a little slower then expected
got back and checked for full throttle
the stock pedal stopper was stopping the throttle about 3/4 of the way open
put the stopper all the way down and now we have full throttle
no more leak
also put a new speedo cable in at it seems to have fixed the speedo problem
first trip to the gas station in over 5 years
not sure how accurate this was it felt like 65
when we got back Jackie drove about 4 miles of the test run
a little tire rub on the coil over strut perch
fixed rub
another speed pic
I am happy with the front end ride height if I can get the drivers side to stop rubbing
I forgot the sway bar was not connected on the passenger side hopefully it will stop the rub on right hand turns
does anyone know what this tag is for looks original and is hanging behind the grill by a fine wire
[url=http://s1132.photobucket.com/user/ranman68/media/IMG_20140413_180615_943_zps2p9muimt.jpg.html
Could be where it had front end damage repaired way back in the day or something.
SO COOL THOUGH, damn fine looking car, cant wait to see it!
still needs your torque wrench on the front wheel bearings
15 mile test drive click pic for video
[url=http://i1132.photobucket.com/albums/m563/ranman68/VID_20140413_184753_525_zpsgzl9ywhg.mp4]th_VID_20140413_184753_525_zpsgzl9ywhg.j[/u
RL]
another video when slotobucket decides to show it
You didnt adjust the bearings further after i installed them? They were far from adjusted "for driving"...
nope needs to be done I thought you had them safe but needed fine tune OOPS
<p><p>&lt;p&gt;well another 12 hour day on the car<br />
the licence plate lights are done<br />
the back bumper installed<br />
the dash removed and a better top was installed also painted the metal part of the frame with black enamel<br />
Jackie cleaned the new dash pad with some cool stuff, made it look real good<br />
got all the dash lights working and the front blinkers working<br />
all the gauges are working except the gas gauge it works when you put 9 volts to it so I have to figure out the problem</p>
IMG_20140420_133821_741_zpszacogefn.jpgIMG_20140420_141016_281_zpsxxfsuw0k.jpgIMG_20140420_141016_281_zpsxxfsuw0k.jpgIMG_20140420_141043_182_zpstp2unepi.jpgIMG_20140420_141055_148_zpstk5pkf9d.jpgIMG_20140420_141111_520_zpstuy9pubb.jpgIMG_20140420_142957_126_zpscdwgjlzz.jpgIMG_20140420_142957_126_zpscdwgjlzz.jpgIMG_20140420_145106_752_zpsypwqjvki.jpgIMG_20140420_191149_445_zpspggcnqff.jpgIMG_20140420_191154_774_zpstyl2hyyf.jpgIMG_20140420_212040_425_zpsi51cfles.jpgIMG_20140420_212116_575_zpsfeil5cf0.jpgIMG_20140420_212059_407_zpseotq0umc.jpgIMG_20140420_212133_835_zpsz2kj0wep.jpgIMG_20140420_212538_162_zpsce60upmj.jpg
  • Like 3
three times trying to fix the double posts so they stay
SORRY
oh yea we are attempting to order another water pump as the used one is leaking slightly
also got new shifter bushings and nos lower radiator hoses and the metal splitter fitting for the heater that was leaking
pics later
http://m.ebay.com/itm/400210783756?nav=SEARCH
New water pump, looks like it is the cast impeller, and priced right.
thanks I think I have the right one coming now
1st pump o'reilly it wasw the later style and takes a different pulley and a spacer
second one ordered from rock auto said it was for a 1200 turns out it is an l series
third one from rock auto and alot of research should be the early style and correct
got my fingers crossed
