Ranman72 Posted March 24, 2014 Author Report Share Posted March 24, 2014 not sure about buffing it might just leave it as is eventually it will get painted Quote Link to comment
68Datsun510 Posted March 24, 2014 Report Share Posted March 24, 2014 The new tank looked like it had a lot of debris in it as well, did you clean it out?!?!? Quote Link to comment
MicroMachinery Posted March 24, 2014 Report Share Posted March 24, 2014 not sure about buffing it might just leave it as is eventually it will get painted noooooooo 1 Quote Link to comment
Ranman72 Posted March 25, 2014 Author Report Share Posted March 25, 2014 The new tank looked like it had a lot of debris in it as well, did you clean it out?!?!? gonna put about a gallon of fresh fuel in it swish it around a bit and drain it looked to be a little dusty inside 1 Quote Link to comment
Ranman72 Posted March 29, 2014 Author Report Share Posted March 29, 2014 got home late but got some work done new water pump on tried to install thermostat but with all the spare gaskets I have that is one I did not (TOMORROW) installed a good old school fuel pump put about a gallon and a half in the tank to clean the bottom out will drain tomorrow finished all the new fuel lines and new filter installed intake /exhaust manifold and hooked up the throttle cable (no pics) 1 Quote Link to comment
Ranman72 Posted March 30, 2014 Author Report Share Posted March 30, 2014 next issue bolt in thermostat is stripped out thank goodness for perma coils and new stuff is great when it works water pump wrong one on the face where the pulley and fan goes out with the new in with the old Quote Link to comment
Ranman72 Posted March 31, 2014 Author Report Share Posted March 31, 2014 got more done today to many parts to get them all on but it runs Jackie painted and installed the cowl vents I got a;ll the fuel lines hooked up 1.5 gallons drained and 4 gallons in and the car would run then die (no fuel) fuel filter would fill slowly when it was not running then run for a bit and die pulled the lines tried to blow through with my mouth and it was restricted so I clamped the hose on my blower end put vise grips on the blower lever and went to the back of the car at the fuel line from the tank very little air coming out of it with 135psi going in shoved a piece of wire about 2 inches into the line and poof out came the clog hooked everything back up and she runs great the timing was off about 15 degrees in the video [/url] [url=http://i1132.photobucket.com/albums/m563/ranman68/photobucket-2294-1396243410679_zpsa0345332.mp4] click pic for video http://s1132.photobucket.com/user/ranman68/media/photobucket-2294-1396243410679_zpsa0345332.mp4.html?sort=3&o=3 [/ [/u next is drive shaft rear brakes new master cylinder new front rotors and pads clutch master and slave and more RL] 1 Quote Link to comment
njoz1200ute Posted March 31, 2014 Report Share Posted March 31, 2014 Keep up the good work :thumbup: Quote Link to comment
Ranman72 Posted April 6, 2014 Author Report Share Posted April 6, 2014 went to put the 1200 driveshaft in and the rear flange was to small for the third member flange the housing looked to be changed to a 150 and should have had a 2mm spacer to line things up but didnt so we put a 1200 145 third member in then went to replace the wheel cylinders and they were the wrong ones a little more research and found out we have a 77/78 b210 150 diff and housing so we need to re install the 150 third member and re order brakes and wheel cylinders got new zx front wheel bearings and got the rear plastics installed Jackie did some of the plastics with our friend Camerons help will add some pics sunday 1 Quote Link to comment
68Datsun510 Posted April 7, 2014 Report Share Posted April 7, 2014 And i did nothing but eat Quote Link to comment
Laecaon Posted April 7, 2014 Report Share Posted April 7, 2014 Are the lug nut holes on those wheels messed up? I had a set I painted identically to those ones, and they went to the keeper. I got them from a S13 autocrosser, but he used acorn nuts. Royally messed up the holes. I took my dremel and tried to make the holes round again. Quote Link to comment
68Datsun510 Posted April 7, 2014 Report Share Posted April 7, 2014 They all seem to be fine, and spin true Quote Link to comment
Ranman72 Posted April 7, 2014 Author Report Share Posted April 7, 2014 Are the lug nut holes on those wheels messed up? I had a set I painted identically to those ones, and they went to the keeper. I got them from a S13 autocrosser, but he used acorn nuts. Royally messed up the holes. I took my dremel and tried to make the holes round again. these are your old rims they left the keepers on one of his builds I dont remember the name of the car but it was blue the guy changed rims and sold these to me but james actually picked them up from the guy because he was going there to do some work for him they seem to spin true Quote Link to comment
ggzilla Posted April 7, 2014 Report Share Posted April 7, 2014 That is the 3.7 rear end. Will make the 1200 accelerate slow. I like 4.11s. 1 Quote Link to comment
Laecaon Posted April 7, 2014 Report Share Posted April 7, 2014 well it appears the paint is holding up well. They always spun fine for me. Just a few of the lug nuts had an "interference" fit to their holes. Quote Link to comment
Ranman72 Posted April 7, 2014 Author Report Share Posted April 7, 2014 my friend Cody came and helped me both days this weekend THANKS CODY we had many obstacles first it seemed someone had put a h150 diff into a 1200 housing without the 2mm spacer so we put a 145 pumpkin into the housing when I went to install the new wheel cylinders they were not the right ones I thought rock auto sent me the wrong ones but further observation showed the rear end was a 78 b210 h150 so the wheel cylinders and brakes I bought wont fit my friend Grayson donated a b210 drive shaft so I had the correct flange and input shaft THANKS GRAYSON we bought new correct wheel cylinders and brake shoes and all is good now Cody installed new zx wheel bearings/ seals/ rotors and brake pads I did a quick tape measure alignment cuz it was all jacked up STILL NEEDS A GOOD ALIGNMENT AND SOME NEW FRONT END PARTS car runs all gears are good rear end sounds good friggin water pump is leaking though so a new one was ordered we installed studs into the b210 housing h150 diff is 3.70 gear h145 was 3.90 this clutch line fitting was hard to get to so custom wrench gear oil installed Thanks Cody dirty calipers new rotors and bump steer spacers looking good finally she runs good click the last pic for a video the factory tach works but speedo is jacked if the 370 is to much gear I will swap it out later or go bigger motor :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: 2 Quote Link to comment
Ranman72 Posted April 7, 2014 Author Report Share Posted April 7, 2014 also Jackie installed the door panels with a little help [/u new rear rubber brake line L] Quote Link to comment
Ranman72 Posted April 7, 2014 Author Report Share Posted April 7, 2014 That is the 3.7 rear end. Will make the 1200 accelerate slow. I like 4.11s. we will see how bad it is and go from there swap rear end or bigger motor hmmmm she wants to keep the 1200 motor for now so we will see Quote Link to comment
TENDRIL Posted April 11, 2014 Report Share Posted April 11, 2014 sounds very smooth !! :thumbup: Quote Link to comment
68Datsun510 Posted April 12, 2014 Report Share Posted April 12, 2014 It runs amazingly well Quote Link to comment
Ranman72 Posted April 12, 2014 Author Report Share Posted April 12, 2014 got more new parts but quick upload to photobucket on my phone is not working new rear drums speedo cable water pump but the correct one also with a cast impeller and waiting for idler arm bushing still pics when I figure it out 1 Quote Link to comment
Ranman72 Posted April 12, 2014 Author Report Share Posted April 12, 2014 installed the drivers seat tonight 86 Mr2 seats 3 hours later and I dont remember it being this difficult the last time I think I was more meticulous this time modified mounts cut, shaved, oval holes, and cut one off and re weld [ ]http://i1132.photobucket.com/albums/m563/ranman68/IMG_20140411_193023_259_zpsqzlyv3l8.jpg[/img] Jackie removed the radiator and water pump for the second time for the correct new water pump no pics you have seen this before 2 Quote Link to comment
ggzilla Posted April 12, 2014 Report Share Posted April 12, 2014 What brake rotors are on that 1200? Quote Link to comment
Ranman72 Posted April 12, 2014 Author Report Share Posted April 12, 2014 What brake rotors are on that 1200? 280zx struts and brakes 1 Quote Link to comment
68Datsun510 Posted April 13, 2014 Report Share Posted April 13, 2014 Big ass brakes :-) Quote Link to comment
