datson4life Posted December 23, 2013 Report Share Posted December 23, 2013 finishing the swap and took a couple days to figure out why it wasnt starting, there is good spark in every cylinder, the injectors are spraying like champions, and the timing is good, so finally started today, the only way it starts is if i pinch fuel line before fuel rail with vise grips, anybody have had that issue or know whats up with that? do i need a regulator before fuel rail? im running a walbro 255 inline fuel pump Quote Link to comment
H5WAGON Posted December 23, 2013 Report Share Posted December 23, 2013 Pressure reg. on rail? Faulty? Quote Link to comment
datzenmike Posted December 23, 2013 Report Share Posted December 23, 2013 Should be tank pump fuel rail injectors fuel rail regulatior return line to tank Is the regulator on backwards? The out line from the regulator should be the only thing returning to the tank. Quote Link to comment
datson4life Posted December 23, 2013 Author Report Share Posted December 23, 2013 Yes tgere is a regulator at end of fuel rail, for my return line i ran lines to smog canister pipes, but i put the lines together at canister, ditching the canister, I will start by replacing fuel rail regulator Quote Link to comment
datzenmike Posted December 23, 2013 Report Share Posted December 23, 2013 Your return fuel line goes to the canister???? What canister? It should be connected to a return line to tank. Do you mean the gas tank vent line??? over on the driver's side??? I don't think this is a good idea. Quote Link to comment
datson4life Posted December 23, 2013 Author Report Share Posted December 23, 2013 No, i ditched the cannister but used the old lines from it as return line, which leads to an inlet on top of fuel tank. Thats no a good return line? Quote Link to comment
kelowg Posted December 23, 2013 Report Share Posted December 23, 2013 Find yourself fuel press guage to see whats goin on. Quote Link to comment
datson4life Posted December 23, 2013 Author Report Share Posted December 23, 2013 There is alot of fuel pressure, got a couple gas leaks, so i eitger got too much resistance in my return line or my regulator on fuel rail is bad Quote Link to comment
datson4life Posted December 23, 2013 Author Report Share Posted December 23, 2013 Or i ran return line to tank vent Quote Link to comment
datzenmike Posted December 23, 2013 Report Share Posted December 23, 2013 Not sure if good or bad. On the 521, the gas tank cap is sealed. (air tight) The vent line from the tank (under certain conditions) allow air back into the tank to replace the fuel that is removed when driving. It also allows excess fumes out to be captured and burned by the motor when running. Using for a return line might collapse the tank. Quote Link to comment
datson4life Posted December 23, 2013 Author Report Share Posted December 23, 2013 What do u mean collapse the tank? Quote Link to comment
datzenmike Posted December 23, 2013 Report Share Posted December 23, 2013 Well as you use the gas in the tank it forms a vacuum. Normally the vent allow air in to replace the fuel removed. I suppose a vented gas cap would work. Quote Link to comment
kelowg Posted December 24, 2013 Report Share Posted December 24, 2013 U could ghetto rig hose from reg to the gas fill and see if it runs like that. Could pull return line loose at tank and see if gas is getting thru. Quote Link to comment
datson4life Posted December 24, 2013 Author Report Share Posted December 24, 2013 Yea plenty of gas is getting thru, it a trip cause now sometimes it starts without pinching fuel line, booooo Quote Link to comment
MikeRL411 Posted December 24, 2013 Report Share Posted December 24, 2013 What do u mean collapse the tank? Open a bottle of water in a plane at 20 thousand feet. Reseal it tightly. Watch what happens as the plane lands! Quote Link to comment
Icehouse Posted December 24, 2013 Report Share Posted December 24, 2013 Your injectors are partial seized. smack the injector caps with the back side of your screw driver while your trying to start it. Should free them up. 1 Quote Link to comment
datson4life Posted December 24, 2013 Author Report Share Posted December 24, 2013 It been starting right up no issues so far, icehouse i love u for that can am box Quote Link to comment
Icehouse Posted December 24, 2013 Report Share Posted December 24, 2013 It been starting right up no issues so far, icehouse i love u for that can am box Thanks :) Quote Link to comment
BlackBird620 Posted December 25, 2013 Report Share Posted December 25, 2013 It been starting right up no issues so far, icehouse i love u for that can am box Sounds like they freed up on their own Quote Link to comment
datson4life Posted December 25, 2013 Author Report Share Posted December 25, 2013 Never heard of partial seized injector issue. It makes sense tho, has it happened to u guys? I pulled the whole rail out at one point and they all sprayed Quote Link to comment
