djpapo Posted October 31, 2013 Report Share Posted October 31, 2013 ok heres my dilemma i have 1973 620 short bed i got a 5 speed transmission of a 1978 280z not a short tale so as u all know the driveshaft on my 620 is now too long so i got the front part of the driveshaft of a 720 king cab it fits the transmission n it is a bit shorter then the one the came on my 620 but I'm still a inch or a bit more too long can anyone help or give me n idea on what too do i want this baby out on the road already pls thank u Quote Link to comment
datzenmike Posted October 31, 2013 Report Share Posted October 31, 2013 You really need the front half of the driveshaft from a '78-'79 620, not a 720. Quote Link to comment
djpapo Posted October 31, 2013 Author Report Share Posted October 31, 2013 i knew it damn it i knew it knew hahaha thank u datzenmike Quote Link to comment
]2eDeYe Posted October 31, 2013 Report Share Posted October 31, 2013 Welcome, looks like a nice truck. You should be able to get either the 720 or the 620 shaft shortened by a driveshaft place if you are having troubles finding the piece you need. :) Quote Link to comment
datzenmike Posted October 31, 2013 Report Share Posted October 31, 2013 Good point, it may be cheaper in the end. Also keep an eye out for a pre '78 grill. Once you see it you'll know why. Quote Link to comment
djpapo Posted October 31, 2013 Author Report Share Posted October 31, 2013 thank u guys one more question how can i get the right measurements to get the driveshaft shorten ? n i think ive seen the grill ur talking about but only online lol Quote Link to comment
datzenmike Posted October 31, 2013 Report Share Posted October 31, 2013 Good question. Ask the shop who's doing it what they want. Usually it's measired center of U joint to center of U joint. Take yours apart, remove both U joints and compare side by side or take both to the shop. Quote Link to comment
jvb5577 Posted October 31, 2013 Report Share Posted October 31, 2013 Good point, it may be cheaper in the end. Also keep an eye out for a pre '78 grill. Once you see it you'll know why. Is this the one with the rings that protrude out around the headlights? Like this? As for the driveshaft I have one off a '79 620 for sale. It would be the correct size you need. Let me know if you want to do that route instead. I live in Tracy, CA so not too far from you. Also have a collection of parts so if you need anything else let me know. 1 Quote Link to comment
K_trip Posted October 31, 2013 Report Share Posted October 31, 2013 - removed - Quote Link to comment
flatcat19 Posted October 31, 2013 Report Share Posted October 31, 2013 Needs more low and less offset. Quote Link to comment
91hrdbdy Posted October 31, 2013 Report Share Posted October 31, 2013 those wheels look familiar?? Quote Link to comment
laotsu Posted October 31, 2013 Report Share Posted October 31, 2013 you sure you want a Z-car tranny in a truck? Wayno says he kept burning his out and finally started building L series truck five speeds. I guess an LZ23 is more than the L20b though. Quote Link to comment
flatcat19 Posted October 31, 2013 Report Share Posted October 31, 2013 you sure you want a Z-car tranny in a truck? Wayno says he kept burning his out and finally started building L series truck five speeds. I guess an LZ23 is more than the L20b though. Wayno also uses his stuff as a work horse. Not as a regular driver. Post pics of Zcar trans to verify what it is. Quote Link to comment
datsunaholic Posted October 31, 2013 Report Share Posted October 31, 2013 Z car transmissions are identical to truck transmissions, except in gear ratio. So there's no difference in strength. In fact in '77-78 the only difference was the speedometer drive cog- even the ratios were the same. Now, using a dogleg (car transmission) would be a different issue. Those are the weak ones. I've blown up 2 of them, and I don't even drive them hard. Quote Link to comment
laotsu Posted October 31, 2013 Report Share Posted October 31, 2013 Z car transmissions are identical to truck transmissions, except in gear ratio. So there's no difference in strength. In fact in '77-78 the only difference was the speedometer drive cog- even the ratios were the same. Now, using a dogleg (car transmission) would be a different issue. Those are the weak ones. I've blown up 2 of them, and I don't even drive them hard. that's good to know. Quote Link to comment
