superbee717 Posted September 6, 2013 Report Share Posted September 6, 2013 sorry to bring this subject up again but I need some good advice. ive bought titan wheels off 2007 titan. I have a 73 620 pick up with drum brakes all around. ive read post where I only need spacers and ive read that you need to bore wheels to 4in or turn the hubs . i would like to know is . if i bore wheels is there still going to be a issue with tire rubbing on inside without spacers? and is that the reason for running spacers? i was just going to bore wheels to make sure the tires don't rub fender lip/ outside of tire. i will be taking ratsuns community advice on running the 225/40-r18 on the titan wheel. i haven't bought tires or bored wheels yet. also im having a hell of a time trying to find the router bit to bore wheels. been to lowes , home depot , ace and another local hardware store and haven't found the right one yet. any advice is much appreciated. thank you Quote Link to comment
thisismatt Posted September 6, 2013 Report Share Posted September 6, 2013 You should be able to find the rabbeting bit at a local tool supply shop or woodworking shop. I would ask for a "half by half rabbeting bit" with a 1/2 inch shank. I highly suggest a 1/2 inch setup, as swinging an 1-1/2" diameter rabbeting bit with a 1/4" shank is pretty dangerous. Obviously you need a router with a 1/2" collet, though. It would also be wise to use a variable speed router. 1 Quote Link to comment
mhub91 Posted September 6, 2013 Report Share Posted September 6, 2013 PM'd a guy who, I think, has done this. He might come here and help you. Quote Link to comment
Eagle_Adam Posted September 6, 2013 Report Share Posted September 6, 2013 With all drum brakes you won't need to do anything, bolt em on. Space them if desired. Quote Link to comment
Eagle_Adam Posted September 6, 2013 Report Share Posted September 6, 2013 Mine are 255/40/18 if I remover right All the info is in my build thread 1 Quote Link to comment
superbee717 Posted September 6, 2013 Author Report Share Posted September 6, 2013 thank you (THIS IS MAT) I think your right 1/4 shank seems pretty dangerous to me too. thank you (eagle adam ) for advice that using spacers is an option. I guess im going to the used tire shop an have a tire mounted and do a test fit. thanks again ill post pics later. Quote Link to comment
]2eDeYe Posted September 6, 2013 Report Share Posted September 6, 2013 Just an FYI, Adams is not a drum brake truck. :) The spacers are used to clear the nubs on the hub, they can be ground off. Or you can run the spacers. Or you can turn the hubs down to remove the nubs. Or you can router the wheels. After all those or's I feel like I should be paddling. :lol: 1 Quote Link to comment
superbee717 Posted September 6, 2013 Author Report Share Posted September 6, 2013 thanks j2edeye so if I run spacers will there still be enough room for tires to clear edge of fenders when I lower truck? that's my main concern ? im probally gonna run 225 40 r18 tires unless you say I can run a wider tire without rubbing issues. and I understand its only 1/4in spacer but sometimes that 1/4in can make or break you.and im sure you know because im looking to get the same stance you have on your truck.sweet lookin ride thanks again Quote Link to comment
]2eDeYe Posted September 9, 2013 Report Share Posted September 9, 2013 I have 1/4 spacers on my 77. Depending on how low you are, you may have to fold up the lips on the bed and the front fenders a little.I'm about as low as you can get without a c notch and cutting off the bump stop mounts in the front and that is all I have done. Wider tires will rub if you are as low as I am. Quote Link to comment
superbee717 Posted September 9, 2013 Author Report Share Posted September 9, 2013 thanks j2edeye I want it bout as low as yours . I want the fenders to hang about 1in or 2 below tires. thanks for the info. Im definitely going with 225/40r18 tires and I think im just gonna bore rims to give me a 1/4in more clearance on outside of tire. you've been a great help. now I feel comfortable about going ahead and getting my tires and boring wheels. hopefully ill be installing them this weekend. thanks alot man. ratsun rules Quote Link to comment
superbee717 Posted October 21, 2013 Author Report Share Posted October 21, 2013 well did not bore wheels out . ground off the tabs on front hubs instead. theyre bolted on. no spacers. now its time to see how low i can go. 1 Quote Link to comment
GRpufnstuf Posted October 22, 2013 Report Share Posted October 22, 2013 Where's the pic?!?(s) Make that truck LOAR Have you read thru a few posts about lowering? Are you going to turn your torsions a notch? And extend you shock mounts? What's you plan for the rear? Blocks, flp a leaf, pull a leaf, 720 springs? Quote Link to comment
jrock4224 Posted November 13, 2013 Report Share Posted November 13, 2013 not a 620 but still very low and fyi your fender hanging a inch or more past the rim will make u like me ... the left turn only crew.......I have a lot of rubbing on turning ut I make it work for the lows... Quote Link to comment
jrock4224 Posted November 13, 2013 Report Share Posted November 13, 2013 215 35 is on the green truck ... Quote Link to comment
jrock4224 Posted November 13, 2013 Report Share Posted November 13, 2013 I'm about as low as you can get without a c notch and cutting off the bump stop mounts in the front and that is all I have done. Wider tires will rub if you are as low as I am. and I have done all these things to my frame which is similar to early 620 frames Quote Link to comment
jrock4224 Posted November 13, 2013 Report Share Posted November 13, 2013 oh yeah those neon green wheels look ghey ... who would ever coat those for u a hideous color like that ...jesus .... need attention much adam .... :w00t: Quote Link to comment
Eagle_Adam Posted November 13, 2013 Report Share Posted November 13, 2013 yes.... yes i do and if you want the number of the D-bag that did my powder coating id gladly pass it on. Hes actually pretty damn good at what he does ;) 1 Quote Link to comment
Fat510 Posted November 13, 2013 Report Share Posted November 13, 2013 Does anybody have titans on a 720? I would like to see what they look like Quote Link to comment
Eagle_Adam Posted November 13, 2013 Report Share Posted November 13, 2013 https://www.google.com/search?q=titans+on+a+nissan+720&source=lnms&tbm=isch&sa=X&ei=wf-DUtuoD6PiiALA6YHYBA&ved=0CAkQ_AUoAQ&biw=1163&bih=853#q=titan+rims+on+a+nissan+720&tbm=isch&imgdii=_ Quote Link to comment
jrock4224 Posted November 14, 2013 Report Share Posted November 14, 2013 lol he posted a google search for u ..... I seen lots(720 on titans) I like them .. may run a set on the drift truck in the back of my head .... don't call the number he gives u, that guy is a raging ass hat .... his powder work sucks too ....fucking prick that powder guy is http://community.ratsun.net/topic/57608-jrocks-powdercoating-of-ratsun-projects-and-shit-thread/ Quote Link to comment
Fat510 Posted November 14, 2013 Report Share Posted November 14, 2013 That search doesn't help lol Quote Link to comment
Eagle_Adam Posted November 14, 2013 Report Share Posted November 14, 2013 That search doesn't help lol then your not looking, click it and the 2nd img result shown is a 720 KC on 5 spoke titans....... Quote Link to comment
Fat510 Posted November 14, 2013 Report Share Posted November 14, 2013 Yeah, I saw it but I don't have a kingcab, I got a regular cab short bed which doesn't give the same vibe as a kingcab Quote Link to comment
Eagle_Adam Posted November 14, 2013 Report Share Posted November 14, 2013 use your imagination....... or Google it yourself.... :ninja: Quote Link to comment
Fat510 Posted November 14, 2013 Report Share Posted November 14, 2013 Thanks Adam, that was helpful lol *rolleyes* Quote Link to comment
