Eriks Posted July 30, 2013 Report Share Posted July 30, 2013 Hi all, I'm considering buying a set of 15x7 with +25 offset and 195/50-15. It seems to be a common package on the 510s. Yet it is important to me that the tires do not in any circumstance touch the fenders. Should I stop worrying and go for the 15x7, or should I look at a set of 15x6 instead ? Appreciate your advices on this, thanks !! Quote Link to comment
flatcat19 Posted July 30, 2013 Report Share Posted July 30, 2013 Didn't know they made it in a 6" wide. Maybe buy a fender roller and some 15x7 wheels? EDIT: They do make a 15x6. But if the 7" worked for everyone else-why question it? Quote Link to comment
Dime Dave Posted July 30, 2013 Report Share Posted July 30, 2013 Yes the 15x7 +25 with a 195/50 tire will work on a stock 510 front strut, but you will need spacers with 280ZX struts. If you look at the advised rim widths from most tire manufactures, the 7" rim is too wide for a 195/50-15 tire. For me I would be following their advice rather than use what is popular. I'd look for a 15x6 + 24 offset if you are using195/50-15 tires. Those will fit a 510 without rolling the fenders. Here is one of my customers, 195/50-15 on 15x6 +24 VTO Retro 4's. I asked him about fender to tire clearance (stock lip, not rolled). He said it was just over 1/2". Quote Link to comment
banzai510(hainz) Posted July 30, 2013 Report Share Posted July 30, 2013 One of your countrymen(Norway) has Rota RBs on his 510. He has stock struts and uses the +25mm offset. fit perfect 195/50 15s. NO strut/bumpsteer spacer can be used as it will hit/rub the steering ilder arm or something. I myself have 195 45 15 Nexen(korean) tires and they clear the strut and fenders fine. One could put 205 in back no proplem tidemansen@hotmail.com Yngve Tidemansen Quote Link to comment
Eriks Posted July 30, 2013 Author Report Share Posted July 30, 2013 Thanks, rolling fender is not attractive, so it sounds like 15x6 +25 is a good option when not messing with the fenders. Thanks again !! Quote Link to comment
Eriks Posted July 30, 2013 Author Report Share Posted July 30, 2013 One of your countrymen(Norway) has Rota RBs on his 510. He has stock struts and uses the +25mm offset. fit perfect 195/50 15s. NO strut/bumpsteer spacer can be used as it will hit/rub the steering ilder arm or something. I myself have 195 45 15 Nexen(korean) tires and they clear the strut and fenders fine. One could put 205 in back no proplem tidemansen@hotmail.com Yngve Tidemansen Yngve, are the Rota RB's to your friend 15x6 or 15x7 ? What about your own rims ? Thanks :) Quote Link to comment
Eriks Posted August 24, 2013 Author Report Share Posted August 24, 2013 Went for the 15x6. Here they are. I'm happy with the choice. 1 Quote Link to comment
reese Posted September 10, 2013 Report Share Posted September 10, 2013 I am interested in the 15x6 Rota RB also with 195/50 tires for my 1969 wagon with ZX struts that is lowered 2". What is required for this set up, longer studs or spacers? or is this a direct bolt on. Has anyone used this on a wagon, any clearance issues on the rear? I am also looking for a no rub tire combo. Thanks. Quote Link to comment
banzai510(hainz) Posted September 10, 2013 Report Share Posted September 10, 2013 Didnt know they had a 15x6 I know 15x7 +25s fit a stock 510 struts 195/50 or 195/45 will be fine up front Reese 15x6 might be enought to clear the 280zx struts. I know on the 15x7 I think +15 or 12 will clear but most pick 0 offset on those but dont know if it clears the rear fneder on a wagon stock hubcaps on a slammed car look good myself!!!!!!!!!!!!!! Quote Link to comment
Dime Dave Posted September 12, 2013 Report Share Posted September 12, 2013 The 8mm spacer FutoFab sells was specifically sized to work with 280ZX struts and 15x6+24 wheels w/195/50-15 tires. FutoFab Spacer & Stud Page Quote Link to comment
reese Posted September 13, 2013 Report Share Posted September 13, 2013 Hainz, with ZX struts, brakes and bump steer spacers I know my sweet 13 wheels and hub caps ain't gonna fit. I am thinking about ZX six spokes now do those clear with bs spacers? Quote Link to comment
flatcat19 Posted September 13, 2013 Report Share Posted September 13, 2013 Why wouldn't ZX wheels clear ZX struts without modification? Quote Link to comment
reese Posted September 14, 2013 Report Share Posted September 14, 2013 Because of the addition of bump steer spacers as stated twice... Quote Link to comment
Rocketmann88 Posted September 14, 2013 Report Share Posted September 14, 2013 Ok I'm still a bit confused. I've been doing research for some time but I can seem to fit the answers for my application. Here is what I have to work with: Stock 510 struts Lowered about 2 inches bump steers spacer Stock fenders My goal it to have 195/50/15 tires on a 15x6 or 15x7 rim. The question is which rim and offset will fit this application with the bumpsteer spacers? I'm ok with rolling the fenders, but would like to avoid it if possible. Cutting the fenders is not an option. I would greatly appreciate some help with getting my 510 back on the road. Quote Link to comment
flatcat19 Posted September 14, 2013 Report Share Posted September 14, 2013 When you guys say bump steer spacers, do you mean roll center adapters? RCAs will not mess anything up. What they do is just set the lower control arm flat as if the car was never lowered. Quote Link to comment
izzo Posted September 14, 2013 Report Share Posted September 14, 2013 When you guys say bump steer spacers, do you mean roll center adapters? RCAs will not mess anything up. What they do is just set the lower control arm flat as if the car was never lowered. Bump steer = RCA. Call it bump steer cuz when you hit a bump the car steers on its own :rofl: Quote Link to comment
flatcat19 Posted September 14, 2013 Report Share Posted September 14, 2013 lol @izzo Quote Link to comment
Laecaon Posted September 14, 2013 Report Share Posted September 14, 2013 When you guys say bump steer spacers, do you mean roll center adapters? RCAs will not mess anything up. What they do is just set the lower control arm flat as if the car was never lowered. More commonly, Roll center adjuster... not adapter... eh... RCAs can mess up plenty. Stupidly, the tire shop had placed wheel weights on the inside lip of my rims (15x7 et5). That coupled with my 1" RCAs made it so my tie rod ends clipped the wheel weights every revolution. Without the RCA the tie rod would have fit inside the rim. I have learned the Datsun community calls them Bump Steer Spacers, as they are trying to correct bump steer, not roll centers. Everyone else calls them Roll Center Adjusters, and that is what companies like TechnoToy call them. Quote Link to comment
banzai510(hainz) Posted September 14, 2013 Report Share Posted September 14, 2013 MY bumpsteer spacers, the sterring knuckle at the end would gently hit the rim (15x7 Rota RB with 25mm offset). I took them off. I dont think stock rims would hit this but ona 280zxstrut expert myself. but if you tried already then Im mistaken Quote Link to comment
flatcat19 Posted September 14, 2013 Report Share Posted September 14, 2013 I had no idea. Good to know that arent as function on our cars. Quote Link to comment
Rocketmann88 Posted September 16, 2013 Report Share Posted September 16, 2013 I want to have 195/50/15 (front) and 205/50/15 (back) on my car. I'm think of getting a 15x6 20mm (front) and 15x7 25mm set up. It sounds like I will have to remove the bump spacers to have the fronts clear the rim. I wonder how much I handling I would lose if I removed them? I think the 205/50/15 should be able to clear the rears? Quote Link to comment
banzai510(hainz) Posted September 16, 2013 Report Share Posted September 16, 2013 195/50/15 tires will clear a 15x7 Rota stock 510 strut +25mm fine but no more. Rear you can 205 EZ Quote Link to comment
Laecaon Posted September 17, 2013 Report Share Posted September 17, 2013 Yea, I would run a 195/50/15 all day long on a 15x7. My tires are even warrantyable on the 15x7s. You may not have to remove the RCA. I did not. I simply demanded the tire shop to use stick on wheel weights. Quote Link to comment
datsunfreak Posted September 17, 2013 Report Share Posted September 17, 2013 Point of clarification: If you are concerned about clearance, it's generally tires rubbing on the body, isn't it? That means tire size should matter more than wheel size? A 195/50-15 on a 15x6 versus a 195/50-15 on a 15x7 should have similar clearance (with the 6" wheel having slightly more), or at least close enough that it won't matter? The only way I can see it being an issue is if the car is slammed and there's a chance the wheel (and/or the part of the tire sidewall just above the bead) may hit the body. Quote Link to comment
datsunfreak Posted September 17, 2013 Report Share Posted September 17, 2013 rolling fender is not attractive This makes me sad. :crying: Quote Link to comment
