ratsun73 Posted August 6, 2013 Author Report Share Posted August 6, 2013 ok thanks Quote Link to comment
ratsun73 Posted August 12, 2013 Author Report Share Posted August 12, 2013 will the calipers fit under the 15 inch rims? i found a minor crack the the housing of the front axle so i will need to weld that. also is my rear axle normal because it has 3 drilled, uncovered holes in the outer tube. i am jest waiting on a trailer then expect regular up dates, i hove been busy putting on a roof for my neighbor. :hmm: Quote Link to comment
]2eDeYe Posted August 12, 2013 Report Share Posted August 12, 2013 The wagoner came stock with 15" wheels :) Quote Link to comment
ratsun73 Posted August 13, 2013 Author Report Share Posted August 13, 2013 ok should be in the shop by thursday Quote Link to comment
ratsun73 Posted August 17, 2013 Author Report Share Posted August 17, 2013 dad said i could drive the subaru to high school so i am reconsidering the 360. beet super busy on the new shop so not much time to work an the project. going to try to start the 360. Quote Link to comment
]2eDeYe Posted August 17, 2013 Report Share Posted August 17, 2013 360 is a great motor if you can afford the gasoline required to run it :) Quote Link to comment
ratsun73 Posted August 18, 2013 Author Report Share Posted August 18, 2013 no kidding, how do i adjust the points on the dizzy? Quote Link to comment
Boxcar Posted August 18, 2013 Report Share Posted August 18, 2013 https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCsQFjAA&url=http%3A%2F%2Fwww.glenngoodspeed.com%2Fvolvo%2FPOINTS.HTM&ei=Bs0QUtPVEMKCyAHmqIFo&usg=AFQjCNHy3VKwrYg_OV8on9PalaY7_Ap-yg&sig2=zZYZYdxDy1GW1dht5rsOpw This is an artical by a Volvo owner. The process is the same. And the info is good. You're points are Delco. Not Bosch. You can also ask you're Grand Father to show you how. It's a simple thing to do . Used to be the first thing any kid lirned about engine maintanance. Now it's kind of a lost art. Quote Link to comment
ratsun73 Posted August 19, 2013 Author Report Share Posted August 19, 2013 figured it out and now the engine is running!!!i have done points before but this setup was a bit different. Quote Link to comment
]2eDeYe Posted August 20, 2013 Report Share Posted August 20, 2013 Dual points? Quote Link to comment
ratsun73 Posted August 20, 2013 Author Report Share Posted August 20, 2013 no but the adjustment screw was in the back behind the dizzy and in front of the head. figured it out and it is now running!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :devil: :rofl: :thumbup: :D :wub: :wub: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: 1 Quote Link to comment
Boxcar Posted August 21, 2013 Report Share Posted August 21, 2013 It's ALIVE !!!!!!!!!!!!!!!! 1 Quote Link to comment
ratsun73 Posted August 21, 2013 Author Report Share Posted August 21, 2013 yes it is i will post the vid i have soon, after i adjust the timing.for now here are some picts of stuff. Quote Link to comment
ratsun73 Posted August 21, 2013 Author Report Share Posted August 21, 2013 some picts of my $100 tires and wheels 1 Quote Link to comment
ratsun73 Posted August 21, 2013 Author Report Share Posted August 21, 2013 my dad gave me some axle stuff!!!!!!!!!!!!!!!!!!! Quote Link to comment
ratsun73 Posted August 21, 2013 Author Report Share Posted August 21, 2013 got the truck up to where i can work on it lots of picks coming when stuff gets less hectic. Quote Link to comment
ratsun73 Posted August 21, 2013 Author Report Share Posted August 21, 2013 vid is loading on photobucket coming soon. first time adjusting ANYTHING on a v8 :fu: not so bad for the first time! 1 Quote Link to comment
ratsun73 Posted August 22, 2013 Author Report Share Posted August 22, 2013 also weirdly enough the l16 has dual points? :confused: Quote Link to comment
]2eDeYe Posted August 22, 2013 Report Share Posted August 22, 2013 That's normal. You can upgrade the ignition system in that 360 fairly easily. I used the later motorcraft system, but it isn't super reliable. You can get a GM HEI style system that is a much better system all around. If you doo, keep the points stuff around as spares. Quote Link to comment
ratsun73 Posted August 22, 2013 Author Report Share Posted August 22, 2013 thinking i might design a custom fuel injection system for the l16. Quote Link to comment
ratsun73 Posted August 25, 2013 Author Report Share Posted August 25, 2013 so i can get a 231t case but will it work? Quote Link to comment
]2eDeYe Posted August 27, 2013 Report Share Posted August 27, 2013 Not sure if that will bolt up to your transmission or not. You'll have to do a bit of research on that one. Quote Link to comment
ratsun73 Posted August 29, 2013 Author Report Share Posted August 29, 2013 the 231 is a 23 spline which will not work. :crying: so i need a different one. Quote Link to comment
ratsun73 Posted September 2, 2013 Author Report Share Posted September 2, 2013 FINALY some progress, got the back axle off and the new on on. had to grind of the shock mounts because they were in the way of the u bolts, so i will need to re weld them. 1 Quote Link to comment
ratsun73 Posted September 6, 2013 Author Report Share Posted September 6, 2013 will probably put the 2 inch lift blocks on the back and build some 3 to 4 inch lift shackles to go with the front spring over conversion. hopefully i will also be able to find some new rear datsun springs for the front because the jeep ones are to stiff. Quote Link to comment
