ratsun73 Posted July 18, 2013 Author Report Share Posted July 18, 2013 this is the start of our new shop. so...excited!!!!!!!! :hyper: Quote Link to comment
ratsun73 Posted July 18, 2013 Author Report Share Posted July 18, 2013 my other toy! Quote Link to comment
Boxcar Posted July 18, 2013 Report Share Posted July 18, 2013 This should help. The tranny you should have is the General Motors TH400 three-speed automatic with a bellhousing pattern unique to the AMC engines. It is the only transmition offerd for the Quadratrack.The tailshaft is the only other nonstandard GM part - it's a 10-spline shaft that sticks out a good foot from the rear of the housing. This shaft drives the sun gear in the reduction housing, or the drive coupler in the units without low range. The coarse nature of the 10-spline shaft wears on itself and the sun gear, causing a loud bang when it's shifted into Reverse. The aluminum adapter between the transmission and the transfer case is also a transmission mount and a tailshaft support. Notice the large ball-type bearing in the adapter, which is much stronger than the current offerings of bushings or small needle bearings. The transmission pattern is standard TH400, which means a Chevy or a Buick/Olds/Pontiac TH400 can be adapted to the case using factory parts; only the output shaft of the transmission needs to be switched to the Quadra-Trac style. Lack of maintenance is what gives the Quadra-Trac its undeserved reputation. The aluminum case is plenty strong until a bad chain or other debris gets lodged between the case and the drive sprocket, which will cause the unit to literally explode. The chain is the only item, other than the fluid, normally replaced during service. As the chain wears from use, it stretches to the point of actually jumping over the sprockets during heavy acceleration. To check the tension of the chain, insert a screwdriver in the chain-inspection hole at the bottom of the case after the fluid is drained. Push up on the bottom of the chain to see how loose it is; if there's more than a half inch of slop, the chain should be replaced. The low-range sun gear and mainshaft suffer from the same 10-spline blues as the transmission output shaft. In this view, the trans shaft enters the sun gear from the left. It wears out the sun gear, which in turn wears out the mainshaft sticking out to the right. At this point, things can get expensive. At press time, the mainshaft (PN J8122705) goes for $138 at your local Jeep dealer, and the sun gear (PN J81227708) has been discontinued. The optional reduction unit offers a 2.57:1 ratio for low range and bolts onto the back of the case in place of the cover plate, drive hub, and sleeve. This photo shows two reduction units and the different styles of shifters. The unit on the right is actuated by a cable that ran from under the dash in fullsize Jeeps from 1973 to 1975. The lever and solid-linkage design shown on the left was used in all low-range-equipped vehicles from 1976 to 1979. The lever sticks up from the floor in front of the driver seat to the left of the transmission hump. EDrive shifter parts The vacuum shifter (A) receives engine vacuum from a glovebox-mounted vacuum switch labeled "Emergency Drive." Rotating the switch applies vacuum to one of two nipples on the shifter, causing the rod to move in or out. The attached fork ( B) slides a collar on the output shaft, which locks the center differential. The control diaphragm is no longer available from Jeep, but both Crown Automotive and MileMarker stock them. Inside the reduction unit is a simple four-pinion planetary reduction setup, very similar to many late-model transfer cases. A few Torrington bearings and a large ball bearing in the rear are all that will wear out, and proper maintenance can keep those parts in good working order. Disassembly is straightforward and consists mainly of removing snap rings and a few bolts. The reduction housing has its own oil supply and needs to be filled and drained separately from the rest of the case. When the shift cover is off, you can extract the small spring that secures the vacuum shifter in the case. Note the square rubber ring that seals the cover. The same sealing method is used to seal the two case halves together. A complete gasket and seal kit is available from Crown Automotive through your local Jeep shop. Many mechanics prefer to use RTV instead of the rubber sealing rings, but either method is acceptable. The small E-clips that hold the aluminum shift fork on the shaft must be taken out prior to removal of the aluminum shift fork. Without the vacuum control, the differential can't be locked, or if the case hasn't been converted to part-time, it can't be shifted into four-wheel drive. A broken vacuum control is a common problem on the trail, but first it must be determined if vacuum is even getting to the control. A hand vacuum pump is handy for applying vacuum to the control, but the vehicle usually needs to be moving a bit so the gear teeth can be lined up for the shifter to function. If you need to replace your vacuum shifter, you need to watch out for spring-loaded detent balls that could sail through the air. Here, the spring has been reinserted and the ball is about to be put back. A small screwdriver can be used to depress the ball and the spring as the rod is slid over to retain them. It's a good idea to have a small magnet handy in case you drop the ball into the shift-fork cavity. If the transfer case is going to be removed from the vehicle, the driveshafts, speedometer cable, vacuum lines, exhaust bracket, and transmission mounts must be removed. For a chain replacement or a part-time kit installation, only the rear half needs to be taken off. You can separate the case halves by removing the case bolts. Unfortunately, this shift indicator switch is in the way of one of the bolts and must also be removed. Rugged simplicity is evident when the case is apart. The drive hub on the right is one piece, and the differential unit on the left is a bolt-together unit. The drivechain rides between the sprockets, which are supported on large, caged, needle bearings. If you're replacing the chain, simply clean the parts, put on a new chain, and bolt it back together. A ratcheting sound during acceleration is often the chain hopping over the sprockets, but the differential should be inspected before the chain is condemned. When the differential is taken apart, you can see the side gears nestled into the cone gear with the clutch plates on the backside. The preloaded plates force the tapered cone into the taper on the diff housing (much like an Auburn axle differential), creating the limited-slip bias. These pieces were never available separately from any manufacturer, including Jeep, because the differential had to be purchased as an assembly. Good used differentials still command a premium price. A common yet often overlooked Quadra-Trac malady is the inner splines stripping inside the differential. Here, the side gear shows splines in good condition, but all the cone gear splines have been worn away by the front output shaft (arrow). The output shaft is harder and never wears, but the stripped splines cause a ratcheting sound on acceleration and will eventually keep the vehicle from moving unless the Quadra-Trac's differential is locked. If the differential is in good shape, simply clean and lube the clutches and cones with TCL-1 fluid and reassemble it. Note that the case holes are offset to ensure proper assembly. The roll pin (arrow) holds the spider gear cross-shaft in place and must not be left out, which is what almost happened here. The differential clutches can get sticky due to old or improper lube, and also from lack of operation. You can usually eliminate this slip-stick condition by driving in a few figure eights or by changing the fluid. The Quadra-Trac system needs a special formulation of oil to allow proper friction between the cones and plates of the differential. TCL-1 from Crown Automotive is a duplicate of the factory formula and comes in quart bottles. Two bottles are more than enough to fill a Quadra-Trac that has the reduction unit installed. Also remember that there are two separate fill plugs for the case and the reduction unit, and each must be filled separately. The fluid is very susceptible to water contamination and should always be changed after water running or once a year in humid environs. If the differential is trashed or a part-time conversion is for you, MileMarker makes a kit that replaces the differential assembly. A direct-replacement sprocket and a new rear output shaft come in kit form with simple instructions. The kit is also available with a smaller sprocket (right), which, when coupled with a different chain, equates to a 16 percent overdrive for rigs with low axle gears that need better mileage. The rear of the case also needs to be taken apart for the new output shaft installation, but simple handtools are all that's needed. After the conversion kit is installed, regular ATF can be used instead of the TCL-1. The stern "Emergency Drive" label has kept quite a few drivers from using the unfamiliar glovebox switch. If you convert the Quadra-Trac to part-time, the kit includes a sticker to put over this label. The sticker states "two-wheel drive" on the left side and "four-wheel drive" on the right. In addition to the vacuum switch, the locking hubs must be engaged for four-wheel drive to work. Even though most of the hard parts are discontinued, most Quadra-Trac service items are available. Crown Automotive sent us a new Morse chain (not a cheap import), front and rear output ball bearings, all four caged needle bearings for the sprockets, a plastic thrust washer, and a new vacuum-control diaphragm. The company also supplies the complete gasket and seal kit, the shift position indicator switch, and the important TCL-1 fluid. Jeep still services the indicator switch, the drivechain, the vacuum-control switch in the glovebox, the knob, and the plastic wear pads on the shift fork. When you replace the chain, align the sprockets precisely in their bores for it all to slip together. If you have three hands, it makes for an easier time, especially if you're under the rig putting the sprockets and chain in the front half of the case. After the case is clean and has a new gasket (or RTV silicone), slap the halves back together and tighten the bolts. Because the case is aluminum, be careful not to cross-thread the fasteners, and torque them with a torque wrench to spec. The reduction unit can be installed along with all the other peripherals, then filled with the correct fluid for your application. Preventative maintenance will keep your Quadra-Trac functioning for many more years to come. 1 Quote Link to comment
Boxcar Posted July 18, 2013 Report Share Posted July 18, 2013 The early '70s were the years of full-time four-wheel drive - a time before gas crisis and performance reductions caused by emissions-control mandates. Dodge, GM, and Ford trucks were fitted with the New Process 203 full-time unit that used an open-center differential and a heavy cast-iron case. But American Motors had a different solution for full-time 4x4s: a lightweight aluminum transfer case from Borg-Warner. Unlike the NP203, AMC's Borg-Warner 1339 Quadra-Trac transfer case included a clutch-pack limited-slip center differential for superior full-time performance, yet like the 203, the differential could be locked to provide equal power output to the front and rear for true four-wheel-drive performance. However, the Quadra-Trac was available without low-range gearing - the gear-reduction unit was an option that was bolted onto the backside of the case. The Quadra-Trac was an option for '73-'79 Wagoneers, Cherokees, and J-series pickups, and it was available in the CJ-7 from 1976 to 1979. In 1980, a new NP207 case was introduced. The 207 was nothing like the Borg-Warner 1339, but fullsize Jeeps still carried the name Quadra-Trac on the body, and the sales literature and owner's manual called it Quadra-Trac as well. Newer Grand Cherokees also use the Quadra-Trac name, even though today's transfer case is not even related to the original design. However, many of the '73-'79 versions are still on (and off) the road. And many uninformed people continue to denigrate the original Quadra-Trac because they don't know how it works. Even though it's a chaindriven, vacuum-actuated case with an optional low range, it has been used successfully by racers for years. Rich Severson of Flamingo Racing ran a stock Quadra-Trac in a CJ-7 for five winning seasons without a single failure. Severson notes that maintenance included only a thorough cleaning and replacement of the special fluid and occasional replacement of the chain. For on-road drivers and trail riders, the Quadra-Trac can even be converted to part-time operation with a kit from MileMarker. Only four areas of the Quadra-Trac case usually cause problems: the low-range reduction unit mainshaft and sun gear, the vacuum-operated shifting mechanism, the limited-slip differential, and the normal wear of the drivechain. Most repairs can be accomplished without removing the entire case - simply remove the reduction unit, then separate the main case halves, leaving the front half in the vehicle. This allows you to access everything but the adapter bearing and seals and the front output bearing and seals, which only occasionally present problems, and don't forget that only a special fluid is to be used in the Quadra-Trac for proper operation of the differential. This section added byJubilee Jeeps I can't account for the accuracy of the JP article, but feel it is pretty good information. The mentioned use of NP207 by AMC Jeep is not correct for FSJs. The model number is actually NP219 that was also called QuadraTrac. The part time transfer case also offered beginning in 1980 is a NP208. The NP207 was actually used in XJs for 1986-87 behind the GM 2.8 litre V6. They are smaller in comparison to the the QuadraTracs, both BW1339 and NP219. I have done just about everything to Jeep BW 1339 QuadraTracs including replacing chains, repairing shifter mechanisms, installing Milemarker part time conversion kits and rebuilding the differential with good used parts from other units. When rebuilding the differential, it is important to use the same three thrust washers from each side of the donor if you can. They are slightly cone shaped and can vary in angle from one unit to another depending on the amount of wear. Often one or more of them will be scored, but can sometimes be smoothed out with light sand paper, emery cloth and some elbow grease. They should have uniform smooth finish. I have tried using a mix of washers from different differentials and they just don't seem to last. These are referred to as clutch plates by Rick Péwé in the JP article. Use the right fluid! Chrysler/Jeep is no longer selling QuadraTrac Fluid. It was over priced anyway. The cheaper solution TCL-1 by Crown Automotive from a Crown dealer (BJs Offroad). It is also possible to mix your own by using a quality limited slip differential fluid with 30W non-detergent motor oil. I prefer the real thing when I can get it cheaper. Two years ago I bought 24 quarts of Mopar Quadratrac fluid for $68 shipped to my door! When using a Quadratrac with part time conversion, ATF is the recommended lubricant. - January 2011 - These items are no longer available for the Borg Warner QuadraTrac:Morse brand replacement chains. MileMarker brand vacuum shifter for the Edrive. For QTs that have been converted to part time, the vacuum shifter selects 2wd/4wd. Here are a couple things I have found in the retainer spring hole for the vacuum shifter on some of our QuadraTracs. The threaded rod on the left was in our 76 Cherokee. I made the one on the right to replace the broken spring (pictured) in our 77 Wagoneer and later found a good spring to use from another spare case we picked up. The penny is for size comparison: Case Sprocket or Differential: Here is a cutaway drawing of the QuadraTrac with Mile Marker conversion taken from the MileMarker part time conversion kit. It gives a good view of the shifter and shaft retainer spring. It is common to see the spring missing, bent, broken or replaced by a rod of the same length. Breakdown of QT Componentsw/o Low Range Unit: Breakdown of the Low Range Unit: Vacuum Diagram: Transmission Mount Diagram: Torque Specs Other Helpful QT Links Hear a klunk in there? Description of "Stick-Slip":http://www.ifsja.org/tech/tcase/slipstik.html Frank in Norway has developed a custom manual shifter to replace the stock vacumn shifter on his 77 Wagoneer. Nice design work! check the link for more details. Ethan Brady on R&R details of one of a kind Quadratrac in a M715:http://www.bigscaryjeep.com/QT RnR.html Peter Matusov on the MileMarker 16% part time conversion:http://www.t-r-j.com/Auto/QT/quadratrac.htm Sources for PartsBJs Offroad Mile Marker ConversionsWillys.NET QT DifferentialsRigid SteelAllstate 4WD The image below shows what comes with a MileMarker part time conversion kit without overdrive option. The hub is smaller for the 16% overdrive and requires a shorter chain. 9/30/03 Quote from JC Jones of CFSJA List "My opinion: The BW 1339 Transfer case is the best full time transfer case ever designed - hands down. The 1339 was actually a military prototype that was put into civilian production. Awesome design, very dependable (when correctly cared for), awesome function, etc. Even the offset design is wonderful, allows a clear path for obstacle clearance without worrying about slamming a differential. It has great low range gearing, can handle an incredible amount of torque and HP. The chain is larger than nearly any other transfer case chain - equating to a much stronger chain driven case overall. Let's face it, the people with QT problems are dealing with a very old transfer case, in most cases never rebuilt, probably never had the fluid changed (read: neglected), and with very high mileage pulling around a very heavy vehicle. They are quiet, have much better gearing than most stock gear driven cases, have the ability to lock to provide for all the functionality of a part time case, really don't draw gas mileage down very much in comparison to the advantages you have with full time. My QT's have gotten me around in situations where a part time case would have left me with wheels spinning." This is Krista getting the drive shafts hooked back up after the complete overhaul we did on her 77 Wagoneer QuadraTrac in July 2003: Quote Link to comment
Boxcar Posted July 18, 2013 Report Share Posted July 18, 2013 I know this is a bunch of info to digest. But if you are going to run the Quadra trac you will need it. Looks like you have you're work cut out for you. Keep us posted. Quote Link to comment
ratsun73 Posted July 18, 2013 Author Report Share Posted July 18, 2013 wow. this makes me want to sell the whole engine trans tranny combo and fine a dana 20 t-case and hook up the t case to my 4 speed. Quote Link to comment
ratsun73 Posted July 19, 2013 Author Report Share Posted July 19, 2013 so my best idea so far is to cut he dastun frame and the jeep frame at 6feet, which is just behind the trans crossmember, and slide the cut off datsun frame into the slightly larger jeep frame. what do you think, is this a good idea or totally stupid? Quote Link to comment
]2eDeYe Posted July 19, 2013 Report Share Posted July 19, 2013 I would just pick one of the frames.I think the easiest would be to swap the cab onto the Wagoneer frame if using the V8. If you are running the L series then I would swap the axles and springs onto the Datsun frame. Don't get overwhelmed by the information overload. If the Jeep drivetrain is functional you'll have plenty of time to learn about it, while enjoying building the truck, as well as when it's driving. :) 1 Quote Link to comment
ratsun73 Posted July 19, 2013 Author Report Share Posted July 19, 2013 thanks for the inspiration :console: , we are starting to put up our shop today so i will have a flat area to work n it. im gong to put the datsun parts on the jeep frame. :thumbup: 1 Quote Link to comment
Boxcar Posted July 20, 2013 Report Share Posted July 20, 2013 You know what? That's a good plan.... I have a TON of Jeep parts in the loft. Mostly hi pro engine stuff. 401 cranks, rods, pistons, cams fly wheel ,etc. I even have a 600 Carter square boar. If you ever find you're self in this neck of the woods. You can have all of it. All nice stuff ( clean ) I'm anal retentive about grease. Just tired of tripping over it. Call it my donation to the cause. I have decided to take a different tack with my builds . Won't need any of it. 1 Quote Link to comment
]2eDeYe Posted July 20, 2013 Report Share Posted July 20, 2013 Nice boxcar. :)This thing will rip when it's done. Quote Link to comment
ratsun73 Posted July 20, 2013 Author Report Share Posted July 20, 2013 thanks for the offer i'm still not sure what i really want to do any thing with the quadra track and the ht 400. if i can find a different trans and t case i will get back to you, will a turbo 350 trans fit? and if i can find one of those what transfer case is the best option? my plan right now is to swap the l 16 in the datsun for an l18 or l 20, if i can find a new l 16 head i might have it ported and put a intake on it, i already have a pretty nice weber and i might have a link to a dana 20 t case let me know what is the best option. i will definitely take the stuff for the jeep motor if i decide to go with the stock jeep drivetrain. again thanks for the great offer!!!!!!!!!!!!! :hyper: i will have the decision made by tomorrow morning, right now i am overwhelmed. :blink: :wacko: Quote Link to comment
ratsun73 Posted July 20, 2013 Author Report Share Posted July 20, 2013 another thing to consider is that this will be my daily drive to high school and i'm not sure i want to pay for gas on a v8. :geek: Quote Link to comment
ratsun73 Posted July 21, 2013 Author Report Share Posted July 21, 2013 sorry to be so undecided. i did some more measuring and thinking, im going to start cutting the jeep apart tonight Quote Link to comment
Boxcar Posted July 21, 2013 Report Share Posted July 21, 2013 I do have a rebuild able L-18 But I'm saving it for a 510 project. I think an L-20B or KA might be a better idea. Torque is king when prepping a wheeler. If you plan on a Datsun motor and need an automatic you want the Datsun / Borg Warner 3 speed from the early L motors. Same length as the drop pan and the dog leg. Mate it to the divorced D-20 or better yet a D-18 to match you're rear off set..... Gotta love gear drives..... As to using a turbo 300 . It would be tough. Won't fit any jeep engine . Advance adapters used to make an adapter for the Datsun but not for many years... You have passenger side drop running gear. Most current 4x4 drives are driver or centered . Keep that in mind. Tell ya what. When you get the body off the frame . Pressure wash the shit out of it ( The frame ) . Take detailed pics of the frame and suspension set up . Post them up and we can be more helpfull..... Meanwhile I will call a friend who has several D-18's . I will se if I can grab one. No promises.... I also found this: http://portland.craigslist.org/grg/pts/3940751413.html And this http://portland.craigslist.org/mlt/pts/3935450643.html etc. http://seattle.craigslist.org/tac/pts/3943758769.html http://seattle.craigslist.org/tac/pts/3942419360.html http://seattle.craigslist.org/skc/pts/3938424382.html 1 Quote Link to comment
ratsun73 Posted July 21, 2013 Author Report Share Posted July 21, 2013 would the transfer case be to replace the quadra tech? I think i will use the jeep running gear if i can get the motor to turn over, it does not have a key so i need to figure out how to hot wire. Quote Link to comment
]2eDeYe Posted July 21, 2013 Report Share Posted July 21, 2013 Hot wire from the positive side of the battery to the positive side of the coil. You can jump the starter solenoid, should be on the passenger fender well. Jump the battery side to the red (in the pic) wires post and it should turn the starter. Pump the pedal twice to seth the choke and get some fuel down the barrels. You can a Dana 44 behind that TH400 with the right tail pieces just have to keep an eye out. The TH400 is probably better the the 350 off road. Quote Link to comment
Boxcar Posted July 22, 2013 Report Share Posted July 22, 2013 Yes. It is to replace the Quadra trac. It will also be necessary if you decide to run a Datsun engine. Just so you understand. The TH-400 in you're Jeep is not a Chevy pattern tranny. But is an AMC ( bolt ) pattern tranny. Not the same. The TH-350 was never an AMC option. The D-18 or the D-20 will bolt up to the TH - 400 . The 18 will work better due to the offset requirements caused by the Quadra Trac. They both run the Texas pattern adapter. While I am a huge fan of the AMC engines. The AMC power train is never going to get any better than 10 - 12 MPG.... I'm 53 years old and don't feel the crunch at the pump as you will at 16 - 17 years old.... I know you plan on driving this rig to school. By the way...... This is a new piece of info you didn't mention earlier.... For this reason alone, you may want to re think you're decision to run the 360. JMHO. Quote Link to comment
]2eDeYe Posted July 22, 2013 Report Share Posted July 22, 2013 My jeep got 8 mpg, just so ya know :lol: But is was worth every penny for the torque that was on hand. ;) Quote Link to comment
ratsun73 Posted July 22, 2013 Author Report Share Posted July 22, 2013 so i cut the roof of the jeep just to get a better look at the inside and noticed some fist sized holes in the floor, this prompted some looking at the frame i decided the frame is too rusted for it to be able to handle the rigors of off road use. there for i will be building the only 1973 4x4 datsun in the county. i might consider finding a new rear axle to replace the rear offset. i will being calling my contact about the dana 20 t case and 1 set of wrangler springs for the back now that i decided what i am really doing i was considering building a 4 link for flex. what do you guys think? :thumbup: i hope to find a l18 datsun engine but if i can't i will find a new head for the l 16, i will clean the Weber and paint the motor. i think i will paint the frame black the body rusolium brilliant blue with dark gray highlights. i hope to eventually be able to afford a winch. Quote Link to comment
Boxcar Posted July 22, 2013 Report Share Posted July 22, 2013 Why not run an L-20B ????? Quote Link to comment
ratsun73 Posted July 23, 2013 Author Report Share Posted July 23, 2013 thats a better idea, if i can find one that will run for under $250 then once i can afford it i will buy it. if you happen to find a contact for a person with a t-case i will be happy to talk to them. the first thing i need are some tires and wheels. Quote Link to comment
]2eDeYe Posted July 23, 2013 Report Share Posted July 23, 2013 I know where one is at, but it is in gold bar. http://seattle.craigslist.org/sno/pts/3916333046.html I met this guy and told him about ratsun. He is deaf so communication takes a bit of patience. Tell him the guy with the big green 4x4 sent ya. :) Quote Link to comment
ratsun73 Posted July 23, 2013 Author Report Share Posted July 23, 2013 gold bar is like 4 hours away it will take some major sweet talking to get my dad to drive that far. Quote Link to comment
