uberkevin Posted April 25, 2015 Report Share Posted April 25, 2015 Mike.. A little confused about what your doing here. 1 Quote Link to comment
datzenmike Posted April 25, 2015 Author Report Share Posted April 25, 2015 That's the main oil gallery coming from the oil filter. It runs from the front to the back of the block. There is a hole up to the block deck where it enters the head to lubricate the valve train (the oil pressure sender is on this line) and 5 holes down to the crankshaft main bearing webs to lube the main and rod bearings. Both ends are sealed with expandable plugs at each end. Only way to clean this gallery out is by remove the plugs. A rifle cleaning brush can then be pushed right through to clean. Tapping and screwing in plugs is a good way to seal them up when done. I suppose the next time I tear the engine down these plugs just unscrew for cleaning. (very unlikely) 2 Quote Link to comment
uberkevin Posted April 25, 2015 Report Share Posted April 25, 2015 Okay okay is see.. My z22 I got for my Lz I got from a running truck so I didn't really worry to much about oil gunk.. But cool! Still no turbo huh?? Haha 1 Quote Link to comment
datzenmike Posted April 25, 2015 Author Report Share Posted April 25, 2015 I still deny I'm going for a turbo. I have something else in mind but we'll see. I remember using a pressure washer on the block when I got it home from Doug's. Probably lots of water and crap were forced in the oil filter holes so I want that cleaned out. Quote Link to comment
datzenmike Posted May 10, 2015 Author Report Share Posted May 10, 2015 Got very little done on this with Canby coming up soon. Managed to use a rifle cleaning brush on the main gallery and flushed everything out with brake cleaner. There was almost nothing in there but now I know. Next will be sealing those plugs into the block. 1 Quote Link to comment
datzenmike Posted December 17, 2015 Author Report Share Posted December 17, 2015 Went to a local 'yard' and there was a KA24E the fire dept practiced on. Asked how much for the head bolts. $30 I said FU new they are, and besides they are torque to yield non reusable. $25. FU I'll give you #10. No deal.I argued with him for 20 min. to waste his asshole time. No they are in the crusher and worth $0.031/2 Got M10 X 110 which are too long but for a milled head with 0.020" gasket is perfect, as washers have to be added anyway. The Black one is an L head bolt used just for matching the thread size. It's 0.35" thick. The plated ones are grade 10 and 0.385" thick. $31 fuck you Powerhouse Autowreckers. 2 Quote Link to comment
FricFrac Posted December 17, 2015 Report Share Posted December 17, 2015 ^^^ Which is why I rarely bother with wreaking yards here on the Island. That being said RCU in Sooke is very good to deal with. Post on the VI 240SX Facebook page and I'm sure one of the drifters will be able to help you out. 1 Quote Link to comment
datzenmike Posted December 17, 2015 Author Report Share Posted December 17, 2015 The KA bolts were just to get me by mocking everything up. $30 for used 'torque to yield' is insanely steep in my books. Anyway I have what I need thanks. The funny thing is that sometimes they are crazy the other way... $75 for a 100 amp alternator from a 2002 Altima plus the two rear disc brake calipers. Did not know about the VI 240sx but then again I don't do f/b. 1 Quote Link to comment
FricFrac Posted December 17, 2015 Report Share Posted December 17, 2015 True but you also didn't use to do Internet forums and now here you are. Just another resource.... and place to waste a lot of time :) Quote Link to comment
datzenmike Posted December 17, 2015 Author Report Share Posted December 17, 2015 True that. 1 Quote Link to comment
