nerdistmonk Posted June 29, 2013 Author Report Share Posted June 29, 2013 So far heres the parts I got: *Oil pump spindle *1981? datsun z22 distributor I tried to put it on but it does not fit, the bolt holes dont match up and there is a gap so idk. Quote Link to comment
HRH Posted June 30, 2013 Report Share Posted June 30, 2013 I may be able to shed some light on this. From what I've seen, Z24i timing covers do not use a pedestal. The distributor just bolts on, as I've found on my 87 chump truck. A carbed Z24s should still use a pedestal. I don't know if you'll be able to use the i timing cover. I think you'll need to swap it out for an S timing cover. The KAZ24 in my red hardbody is an S block/timing cover. Quote Link to comment
nerdistmonk Posted June 30, 2013 Author Report Share Posted June 30, 2013 (the intake coil/icm doesnt work and hasnt for many years, the truck was rigged to run on the exhaust coil before i bought it, when i tried to restore the intake side back to proper working order it caught on fire..no pics of that one nor my reaction to it sorry, so at this point forward that ecu is my sworn enemy and i must defeat it) I wished i knew why that ignition module burned (or the old one for that matter). Quote Link to comment
nerdistmonk Posted June 30, 2013 Author Report Share Posted June 30, 2013 Well some more news, me and datzenmike compared pictures and apparently all im missing is a small plate that bolts to the timing cover, as soon as i can coerce him into sending it to me i can get this baby buttoned up. Well other than the classic "i need more power scotty!" as i dont know where the best spot to get the power sources i need. 1 Quote Link to comment
HRH Posted June 30, 2013 Report Share Posted June 30, 2013 I had to go back and look at my pics. Wish I didn't have so many. My old build thread is nude of pictures since dropping my website. Here's what I did on the KAZ24. Don't know if it will help or not. Think I had the pedestal lathed down into that bushing you see. Quote Link to comment
nerdistmonk Posted June 30, 2013 Author Report Share Posted June 30, 2013 Thanks for the pics, me and mike figured it out, it seems the junkyard i ordered the part from unbolted the dist from the plate instead of from the engine thusly sending me a dist missing one of the adjustment plates. Problem solved basically, just got get mike to send me the plate though. I also think i figured my wiring nightmare out, it seems all the 12v+ wiring from the coils is clean and DOES NOT need the computer to get power, instead the computer mearly switches the ground wires to all this stuff on and off as needed, or at least that what the schematics seem to show. So ill just reuse all the wiring minus the ground wires (ill run new ones to the body) and bam im in like a dirty shirt. Quote Link to comment
nerdistmonk Posted June 30, 2013 Author Report Share Posted June 30, 2013 Decided i should create a signiture to put on my profile 1 Quote Link to comment
nerdistmonk Posted July 1, 2013 Author Report Share Posted July 1, 2013 Well noticed that i have a lovely scrape on the side of my truck. I think it was my fault though got a bit close to bushes a few weeks ago on my way out. meh just hit it with some rattlecan to cover it up. Quote Link to comment
datzenmike Posted July 1, 2013 Report Share Posted July 1, 2013 Yeah this thingy... Quote Link to comment
nerdistmonk Posted July 1, 2013 Author Report Share Posted July 1, 2013 now if datzenmike would send ol' nerdy that thingy i would be a happy man. Quote Link to comment
nerdistmonk Posted July 1, 2013 Author Report Share Posted July 1, 2013 I put my complete throttlebody unit for sale in the classifieds, if it dont sell ill save it back and bundle it with coils and the ecu as a complete kit. Quote Link to comment
datzenmike Posted July 1, 2013 Report Share Posted July 1, 2013 Canada Day everything shut. Quote Link to comment
nerdistmonk Posted July 1, 2013 Author Report Share Posted July 1, 2013 ah ok, its cool. thanks again mike Quote Link to comment
nerdistmonk Posted July 1, 2013 Author Report Share Posted July 1, 2013 Ok just got done changing out a bad stabilizer bar link, both were bad (broken in half), i had did one back in february it had took 2 people to do it (someone holding up the stabilizer bar with a crowbar, and a guy to actually insert the link) This time on this one i was on my own, i took the crowbar and after some trial/error and denting my shock absorber, i managed to find the sweet spot so i could use my knee to lift the stabilizer bar and use my hands to install the link Quote Link to comment
nerdistmonk Posted July 2, 2013 Author Report Share Posted July 2, 2013 is there a secret japanese secret to freeing the spare tire from underneith the truck, im soaked it in pb plaster, whacked it with a mallet for 30 minutes straight and that sucker isnt budging. Quote Link to comment
]2eDeYe Posted July 2, 2013 Report Share Posted July 2, 2013 I assume you are using the jack handle to lower it? Quote Link to comment
nerdistmonk Posted July 2, 2013 Author Report Share Posted July 2, 2013 I assume you are using the jack handle to lower it? um idk how to lower it apparently, it has a round dingleberry in the middle and it well doesnt do anything, so i hit with a mallet and it still did nothing, i just figured the tire was fused to the truck bed. lol next year i need to strip the truck down to the frame and por15 that sucker. Quote Link to comment
nerdistmonk Posted July 3, 2013 Author Report Share Posted July 3, 2013 Ok so heres my maintenance log, from january 18th till now, everything no matter how minor is listed here. ###1986 Nissan Hardbody D21, Long Bed, 4-CYL Z24 Engine, 5-speed/RWD###79 Jeep CJ FUEL FILTER, 1981 Datsun z22 Distributor@224,430 MilesPlugs, Wires, Oil change/filter, air filter, fuel filter, injector cleaner, 2 lugnuts, new muffler@224,430 MilesCarburetor Conversion, Fuel Pump, Fuel Lines, Vacuum Lines, Wiring, Cleaned engine compartment, lube, fuel reg, *** Deletion,@224,600 MilesIgnition Rebuild, new wiring, transmission oil/rear oil changed, new stereo, tires, hubcap,@224,754 MilesNew Dist Cap, New Dist Rotor, New Coil@225,000New exterior graphics@225,318Carb Tuned, clutch bled@225,454Oil pan gasket, Valve cover gasket, front end lube, antirust rear end, coolant system flush, exhaust system rebuilt, oil change,@225,500clutch hydros rebuild, clutch damper removal, antirust rear fenderwells@225,516New shocks (front/back), Stabilizer bar link drivers side@225,707Brakes Bled (frt), New front brake hoses, Front wheel bearings repacked (inner/outer), exhaust welded@225,954Partial Body Restoration@226,672Bucket Seat Conversion, New Fuel Pump, Rigged Fix for throttle,@226,850New Carb Gaskets, New Oil Pump Gasket, New Distributor Gasket, New Vac Caps, Manual Choke Installed, removed scrap @226,954New stabilizer bar link pass side, lube 1 Quote Link to comment
HRH Posted July 4, 2013 Report Share Posted July 4, 2013 There is a long extension that probably isn't with the truck. It's a bar and has a "T" through the end. That fits in the round dingus and it lowers or raises the tire. It's a chain pulley is what it is. Get a half inch thick piece of round metal and weld a pin through it laterally. Quote Link to comment
nerdistmonk Posted July 4, 2013 Author Report Share Posted July 4, 2013 ill check behind the seat(s) and look at the manual for the truck, everything the truck had when it was sold is still with it (including all the receipts and paperwork). I had a factory jack back there i believe so a bar for the tire may be there too, never know. truck cost $7,300 in january 1986, he spent extra on the pinstripes (yucko), underbody rust protection and a very long warranty, and i also got the heavy duty package (glad i noticed that before i bought brake shoes) apparently it got a new motor in 1987 (kind of hard to tell with all this faded paperwork), dont ask me what kind of magic could happen to cause a truck to need a new z24 barely a year after it was bought. i also got all this japanese paperwork and some strange computer punch cards and such, and a mirror tag with a number on it. Figure ill keep it all for laughs, go into the stealership and ask if my warranty is still valid :) Quote Link to comment
Mirrorimg Posted July 4, 2013 Report Share Posted July 4, 2013 That's a heap of maintenance. Better be running like a sewing machine! Quote Link to comment
nerdistmonk Posted July 4, 2013 Author Report Share Posted July 4, 2013 That's a heap of maintenance. Better be running like a sewing machine! for the most part it does, im sure it will be even better once i get its 8 plug ignition back to proper working order. Got some questions for whoever can answer them though: 1) Anyone got a picture of their z22 motor showing what position their dist is set to, i time my engine by ear and i would like to have a starting point so i dont have the engine over-advanced. 2)A picture of the wiring coming from the z22 dist to the coils would be awesome also. Another ironic thing, of all the gasket material ive used for my carb and other things......cardboard....cardboard ftw..... Quote Link to comment
HRH Posted July 4, 2013 Report Share Posted July 4, 2013 You need to get a timing light to set the distributor. You can hook up a dwell/tach/rpm meter for the rpm if you don't have a gauge. It will be ten times easier than trying to set by ear or feel. Wait a minute, you just said you used cardboard for the carb gasket material? That will cause a problem. Might not right away, but it will cause a problem. I would highly suggest you go down and get some sheet gasket material from the auto parts store of your choice and redo those gaskets. Gasket paper is much more dense than cardboard and will resist gasoline contamination. Cardboard will not and fairly soon you will have a vacuum leak. Also, in case you have, don't use any sealant on carb gaskets. Install dry. Quote Link to comment
nerdistmonk Posted July 4, 2013 Author Report Share Posted July 4, 2013 Ive tried every gasket material known to man, they all leak and fail, also when i said cardboard i meant the 1/8" thick gasket cardboard. i got a brand new timing light but dont use it, if i dont get an image of someone elses z22 engine or something so i can have a starting point ill just wing it, ill dial it to an approximation of where the old one was set then go from there. Quote Link to comment
