Tristin Posted October 18, 2013 Report Share Posted October 18, 2013 Found shoes! 15x7 +20mm offset works ewing IIIs. Perfect. Pics? Are they the flat or concave versions? There have been about 4 variations on the IIIs. Quote Link to comment
Tristin Posted October 18, 2013 Report Share Posted October 18, 2013 Nice. Do they come with the centercaps? Quote Link to comment
RTB Posted October 18, 2013 Author Report Share Posted October 18, 2013 Indeed they do. How should i have spent lol... Quote Link to comment
Tristin Posted October 18, 2013 Report Share Posted October 18, 2013 Are they the chrome or gold caps? Golds are my personal favorites. IIIs are one of the few none SSRs Id run. Quote Link to comment
RTB Posted October 18, 2013 Author Report Share Posted October 18, 2013 black actually with a chrome W in the middle. I just want to see what others would pay for wheels like this to see if i did well or not lol. Quote Link to comment
Tristin Posted October 18, 2013 Report Share Posted October 18, 2013 black actually with a chrome W in the middle. I just want to see what others would pay for wheels like this to see if i did well or not lol. Any rash, bends, or chips in the lips? Any corrosion? Powdercoat or paint? I dont think Ive seen black caps... they may have been recoated for peeling chrome caps. That would help with a price on what I would pay. Quote Link to comment
RTB Posted October 18, 2013 Author Report Share Posted October 18, 2013 no bends,chips, or rash. no corrosion. Paint that may need to be redone if going super detailed but nothing bad at all. caps were probably painted to match the wheels. Quote Link to comment
Tristin Posted October 18, 2013 Report Share Posted October 18, 2013 Maybe something like $700-$800. Maybe a little less since the caps have to be fixed... I personally couldnt run with black caps. Quote Link to comment
RTB Posted October 18, 2013 Author Report Share Posted October 18, 2013 Ok I didn't do bad at all. I'm right in there. Quote Link to comment
Tristin Posted October 18, 2013 Report Share Posted October 18, 2013 Ok I didn't do bad at all. I'm right in there. Yeah its a mediocre size with a blah + offset and caps that need rechroming. But they dont come up for sale too often and its nice that you actually have caps. They are a vintage wheel and they are Works. So youre about that price. Quote Link to comment
edekalil Posted October 18, 2013 Report Share Posted October 18, 2013 Looks good. Quote Link to comment
Just Joel Posted October 18, 2013 Report Share Posted October 18, 2013 I've always like Ewing III's... nice B) Quote Link to comment
Colbino Posted October 18, 2013 Report Share Posted October 18, 2013 Your car is coming right along and looking noiceeee. Keep the pics coming! Quote Link to comment
RTB Posted December 16, 2013 Author Report Share Posted December 16, 2013 Got it back from paint. Starting to build my 2.2 stroker engine. Will upload more as I go along. What color to paint the block? Valve and front cover and chrome plated. 2 Quote Link to comment
edekalil Posted December 16, 2013 Report Share Posted December 16, 2013 Very nice. Quote Link to comment
RTB Posted December 17, 2013 Author Report Share Posted December 17, 2013 Ok I need engine help again. I would really like to use a Z22 crank, a l20 block, and 6 inch rods in my set up. Are there any pistons that would work with that set up that I would not have to modify or cost +500 dollars? preferably around 87mm bore size. Quote Link to comment
rusty12ver Posted December 17, 2013 Report Share Posted December 17, 2013 Ka pistons? Quote Link to comment
RTB Posted December 17, 2013 Author Report Share Posted December 17, 2013 yea thats what ive come to realize. l20 crank with a block bored out to 89mm with 6 inch rods and KA pistons. Pistons have to be cut though. Quote Link to comment
Ranman72 Posted December 31, 2013 Report Share Posted December 31, 2013 those works dont come up for sale very often any idea where you can buy the center caps thinking of putting these on my roadster but they are a little beat up Quote Link to comment
RTB Posted January 7, 2014 Author Report Share Posted January 7, 2014 Has anyone put BMW e36 seats in a 510? My seats are still in factory shape and I don't see the benefit of redoing them for 600 dollars each when I can buy almost new e36 seats for less than 400. Quote Link to comment
Kirden Posted January 17, 2014 Report Share Posted January 17, 2014 RTB I've looked into that LZ setup a lot. The best pistons I could find are skyhawk pistons. They still have to be milled but only somewhere around 0.5mm. They will then be flat tops so you would need to unshroud the valves if you're using a U67. With the right head work you could get the static 10.5:1 CR down to 9.5-9.7:1 or you could have the shop add a small dish in the top of each piston for the same results. The skyhawk pistons have the same pin daimeter, 1.5, 1.5, 3mm ring sizes and just over 29mm pin height. Also, depending on the brand you purchase, most are hypereutetic and you can find any ring composition you want through a lot of american companies. Just something to think about. Quote Link to comment
RTB Posted January 17, 2014 Author Report Share Posted January 17, 2014 Rex I've looked into that LZ setup a lot. The best pistons I could find are skyhawk pistons. They still have to be milled but only somewhere around 0.5mm. They will then be flat tops so you would need to unshroud the valves if you're using a U67. With the right head work you could get the static 10.5:1 CR down to 9.5-9.7:1 or you could have the shop add a small dish in the top of each piston for the same results. The skyhawk pistons have the same pin daimeter, 1.5, 1.5, 3mm ring sizes and just over 29mm pin height. Also, depending on the brand you purchase, most are hypereutetic and you can find any ring composition you want through a lot of american companies. Just something to think about. Actually I've found a 219 head so I'm going to use that with z22e pistons. Quote Link to comment
RTB Posted January 19, 2014 Author Report Share Posted January 19, 2014 Ok so I think I've found the head I'm going to use. Trading my 4.625 diff for a ported 219 head with Japanese racing valve springs. Need to source some steel intake valve guides. I know you are all picture whores so here you go. 1 Quote Link to comment
RTB Posted January 22, 2014 Author Report Share Posted January 22, 2014 So weather has gotten better and starting with the assembly. Put in the side windows. This weekend putting in the slotted crossmember. Picked up some 15x6 Panasports for 200 bucks locally. Tires are way too big but I will make all my money back plus some on them. Sorry about potato quality 2 Quote Link to comment
