GORILLARILLA21` Posted April 16, 2013 Report Share Posted April 16, 2013 So I took my struts to the shop to get the perches cut. They cut them all right. They cut them right below the perch and the top part that goes through the perch (the thread to the cartridge). My plan was to use a clamp under the perch so I can adjust the ride height. What do I do now? I don't want to weld them as I wanna be able to adjust the ride height.. Thanks. Quote Link to comment
DeviousPsycho620 Posted April 16, 2013 Report Share Posted April 16, 2013 Make them buy you new ones. That's messed up. Quote Link to comment
thisismatt Posted April 16, 2013 Report Share Posted April 16, 2013 Cut the perches off like planned and weld them back together - better yet, section a bit out of them before welding them back together and run a shorter insert. The weld will be inside the coilover collar and will be plenty strong at that leverage point as long as they're welded decently (chamfer the weld joint, butt them square, quality weld). Quote Link to comment
datzenmike Posted April 16, 2013 Report Share Posted April 16, 2013 Well too late now but you still can hack saw them yourself or borrow an angle grinder and a $3 cutting wheel. Just nic above the weld all the way round and tap them up and off. Grind that weld down Quote Link to comment
GORILLARILLA21` Posted April 16, 2013 Author Report Share Posted April 16, 2013 Right on thanks a lot for the pics. Ya ill try to weld the top back on and cut the perch off.. Quote Link to comment
Ranman72 Posted April 16, 2013 Report Share Posted April 16, 2013 Miscomunication ? make the shop fix them you asked for the perch to be removed not the strut to be cut in two Quote Link to comment
the510keeper Posted April 16, 2013 Report Share Posted April 16, 2013 Cut the perches off like planned and weld them back together - better yet, section a bit out of them before welding them back together and run a shorter insert. The weld will be inside the coilover collar and will be plenty strong at that leverage point as long as they're welded decently (chamfer the weld joint, butt them square, quality weld). What Matt said, great idea. you will get more travel out of your shock and spring and still have a low ride Quote Link to comment
jrock4224 Posted April 19, 2013 Report Share Posted April 19, 2013 mr 2 insert.....whats up kris......its jon from the powdercoating shop ......we can get those squared away for yah!!!!bring em back .... i promise i wont make them pink before i give them back Quote Link to comment
