iCruZ Posted April 8, 2013 Report Share Posted April 8, 2013 I own a 1970 521 project truck that is missing a rubber support on the transmission mount hopefully this link helps. I live in the 93436 area code http://www.tumblr.com/dashboard 2 Link to comment
datzenmike Posted April 8, 2013 Report Share Posted April 8, 2013 Right, you have to sign up to view the pictures????? Copy the image code and paste the image here. Link to comment
MikeRL411 Posted April 8, 2013 Report Share Posted April 8, 2013 "Location 805" is of no use. Link to comment
420n620 Posted April 8, 2013 Report Share Posted April 8, 2013 93436 = Lompoc Ca Area code 805 North American area code 805 is a California telephone area code. Area code 805 includes most or all of the California counties of San Luis Obispo, Santa Barbara, and Ventura, plus southernmost portions of Monterey County Link to comment
iCruZ Posted April 12, 2013 Author Report Share Posted April 12, 2013 ive checked all the parts stores in my town... its not so easy to find parts for a truck that's over 40 years old as you would think ! especially a part like the one im needing. im from the area code 93436 Lompoc CA Link to comment
datsunpolisher Posted April 12, 2013 Report Share Posted April 12, 2013 Auto zone here in fresno usualy has what i need for my 521 check there site 1 Link to comment
datzenmike Posted April 12, 2013 Report Share Posted April 12, 2013 You are so right. Owning a 4O something Datsun and keeping it on the road will require some ingenuity and a welder. For the odd part you can borrow one or have someone do it. Many people own one and that makes life a lot better. Often it's just as easy to make something else work from another vehicle or simply make something. 1 Link to comment
iCruZ Posted April 13, 2013 Author Report Share Posted April 13, 2013 the part im looking for is not the actual mount that bolts on to the frame of the car . its the rubber that holds up and lifts the "tell end" of the transmission and bolts on to the transmission itself and bracket on the chassy. the job of the rubber im looking for is so yjr transmission doesn't sit so low and is not hitting the chassy. Link to comment
MikeRL411 Posted April 15, 2013 Report Share Posted April 15, 2013 the part im looking for is not the actual mount that bolts on to the frame of the car . its the rubber that holds up and lifts the "tell end" of the transmission and bolts on to the transmission itself and bracket on the chassy. the job of the rubber im looking for is so yjr transmission doesn't sit so low and is not hitting the chassy. As a last ditch effort assuming that you can't find a "substitute" part, take the steel upper and lower plates to a tire recap place and have good 80 durometer or better synthetic rubber block vulcanized in. You might just have to use a Forstner bit to drill out the holes to insert the bolts to the transmission housing but at least you will have a servicable transmission mount that should last as long as you care to keep the truck. Link to comment
