FiveSeventyZee Posted August 10, 2012 Report Share Posted August 10, 2012 So the way I'm reading this means the ones that have a pin number means i want to hook up the relay block to the end of the wire going into the ECU and the ones that just have the item (example: brown - A.A.C. valve) i want to hook up the relay block to the end of the wire going to the sensor/valve/whatever on the engine? because those ones also go into the ECU and when I cut the wire I have 2 ends to chose from....thats where I get lost... if I'm assuming everything correctly the ECU never sees the air regulator, A.A.C. valve or ground wire? Quote Link to comment
Icehouse Posted August 10, 2012 Author Report Share Posted August 10, 2012 Never cut the wires going into the ECU. There are two plugs that have all the "good wires" that don't plug into the engine. Splice everything there. Don't cut anything from the ECU. 1 Quote Link to comment
FiveSeventyZee Posted August 10, 2012 Report Share Posted August 10, 2012 hmmm okay. seems I have to find them. do you by chance know the location on an s13 KA-e harness? Quote Link to comment
INDY510 Posted August 10, 2012 Report Share Posted August 10, 2012 . You don't need to un-wrap the harness.. and don't start cutting wires!!! ... if it's actually a COMPLETE harness it should be easy(ish) Take a picture of the complete harness layed out on the floor ... I'm shure someone here will know exactly which plugs have the good wires You are most likely looking for 2 green relays .... or two bright green plugs where the relays used to be (one with blk/pnk one with red wires) Quote Link to comment
FiveSeventyZee Posted August 10, 2012 Report Share Posted August 10, 2012 awesome. found them! glad I have 2 harnesses haha. ones attached to all the sensors on the engine and ones loose. both uncut, it made much more sense when looking at the one on my floor rather than in the car. thanks for the help guys. sorry if these questions have already been covered. I'm running on empty over here. been working on the car day in day out. gotta get it on the road to move, my lease started on the first and junior's gotta get me there :P ps, it was these two thanks again Quote Link to comment
FiveSeventyZee Posted August 10, 2012 Report Share Posted August 10, 2012 wait!....there are 2 brown wires....how do i know which one goes to the A.A.C. valve? kind of hard to follow it without tearing into the harness Quote Link to comment
Icehouse Posted August 10, 2012 Author Report Share Posted August 10, 2012 I think they actually tie into each other. Try doing a continuity test. My money is on them tying into each other though. Quote Link to comment
FiveSeventyZee Posted August 10, 2012 Report Share Posted August 10, 2012 alright Ill check. if they do tie into eachother should I connect them both to the relay block or just one....I guess it doesn't really make a difference... edit: they do tie in to eachother. they didn't when I first checked and it confused the shit out of me then I thought for a second, plugged the ecu into the harness and all of a sudden...continuity...haha bit of a derp moment but I got past it :P again...thanks guys Quote Link to comment
FiveSeventyZee Posted August 14, 2012 Report Share Posted August 14, 2012 okay tried to fire it up today and i've got almost everything situated, but i'm not getting a spark. does anyone know which wire on the 2 coil plugs is the power wire? i've got white, black, light green/black on the plug that goes into the pickup and light green/black, black/red on the one that goes into the coil plus a black one that I can only assume is ground edit: found power, its the black/red wire on the coil....but somehow i'm not getting a spark...could my coil have gone bad? the KA ran with this coil a month ago when it was still in the 240sx.... Quote Link to comment
dennis Posted August 20, 2012 Report Share Posted August 20, 2012 This is what I used. I also only used a few wires at the pig tail off the ecu connector. http://www.frsport.com/SR20DET-Swap-Engine-Harness-Wiring-Diagram-Guide-SR-SR20_t_26.html Quote Link to comment
97hardbodyfl Posted August 21, 2012 Report Share Posted August 21, 2012 so i have a 97 hardbody with th sohv ka and it has bad con rod bearings and timing kit which i replaced that dam kit so mamy times that i said the hell with this im going dohc... so i bought a ka24de from a 95 240 and it came with 2 ecus 5 spd and an auto. no harness tho... i want to swap it but im at a stand still.what do i do... i dont have all the sensors for the de or the dizzy. but i still have every thing from my truck. Quote Link to comment
AKSabin Posted August 23, 2012 Report Share Posted August 23, 2012 HI folks...Icehouse/Wolfman...Great job on the diags. I have a 66 roadster I am attempting a VG30 install with. The donor was an 87 300zx that ran excellent with no codes...using ECU, harness, and various other parts. Currently, I have both diagnostic lights on constantly in run mode and in diagnostic mode they seem to be doing a self check though all combinations (orriginal ECU and spare). Internal inspection shows no sign of trauma. Also, as for the can-am box, is there a link where I can aquire this? Quote Link to comment
Datsun411SSS Posted September 14, 2012 Report Share Posted September 14, 2012 I am getting ready to do my s13 ka24de swap into my 411sss and I think i have identified which wires I need to connect to the can/am box. In the picture below, I connect the wires with the labels to the can/am box correct? The orange wire for the starter solenoid, I connect the car's signal wire to it and then it leads to the ecu correct? 1 Quote Link to comment
FiveSeventyZee Posted September 26, 2012 Report Share Posted September 26, 2012 yes and yes Quote Link to comment
ratsunissan Posted October 2, 2012 Report Share Posted October 2, 2012 correct me if im wrong i need to splice about 8 wires coming from the ecu runoff? or are all the goodies in these two plugs? (blue and white) ps: this is an s14 harness Quote Link to comment
Creepy Cruiser Posted October 2, 2012 Report Share Posted October 2, 2012 Everything you need is in the long white plug right there. The blue plug is for a relay, just plug the relay back into it (unless you're using the CAN/AM box, then wire it to the relay on it instead). The CAN/AM boxes are awesome btw.. Quote Link to comment
Icehouse Posted October 2, 2012 Author Report Share Posted October 2, 2012 The blue plug is actually the ECCS relay. But yes if your not using a CAN/AM box you can use it as is. Quote Link to comment
Creepy Cruiser Posted October 2, 2012 Report Share Posted October 2, 2012 Fixed, lol. (Thank you. That's what I get for posting when still half asleep, lol) Quote Link to comment
ratsunissan Posted October 2, 2012 Report Share Posted October 2, 2012 yeah im using the box and thats what i thought just wanted to make sure before i started. thanks! Quote Link to comment
ratsunissan Posted October 2, 2012 Report Share Posted October 2, 2012 if someone could tell me what goes where on the can/am box tho. that be very helpful. i know the left is fuel, middle is the eccs and the right is a ground and ign but if someone has the time to tell me each port thatd be great! Quote Link to comment
ratsunissan Posted October 3, 2012 Report Share Posted October 3, 2012 Yeah I have that printed off already..I'm pretty sure I'm just over thinking the whole thing haha. So all wires from the blue plug plug into the eccs portion of the box Im pretty sure i have that figured out. Then for the ignition part of the box all my wires come from my stock 720 ign? For fuel 2 wires come out the Ecu return and 2 for the fuel pump? What else? Quote Link to comment
ratsunissan Posted October 5, 2012 Report Share Posted October 5, 2012 come on jeff i know you wired up a 95 ka before please help im at a standstill. another question that diagram says ecu pin number but we use the returns from the ecu so isnt that different? i cant find a pinout of the returns Quote Link to comment
Icehouse Posted October 5, 2012 Author Report Share Posted October 5, 2012 Yes I've wired a quite a few S14 KA's, O how I hate them :) The stupid foam around the firewall grommet, The million extra wires that Nissan decided to run with the EFI..... You only need one wire from the blue plug. It's a red w/black. Well actually two. The black w/white as well. The rest come off that extra big white plug. Make sure to trace them back to the ECU since there are multiples of each color. There is a link to FSM's for all the engines on the first page of this thread. Quote Link to comment
Turbo210 Posted October 6, 2012 Report Share Posted October 6, 2012 Stoping in just to say I can't wait until my can/am box comes in I'm doing a Ka24e in my 1981 Datsun 210 sedan.Btw can any one post a pic up of the can/am box with the wires running in it thx Quote Link to comment
