Round 2, FIGHT! - now with a DE in progress(for real this time...)
Eagle_Adam
  • Replies 2k
What size tires are you running on your minty greens there?  I'm running 235/45/18's with the torsions cranked pretty much all the way down, a middle leaf yanked and 3" blocks.  My tires are way too tall though even though they are only 1/2" taller then my stock 195's on the 14" rims.  Yours and Redeye's look perfectly sized.
this is just for my reference:
gasket kit
timing kit
headbolts
Flip center-link
fuel pump( inline pump near the tank, with a filter between it and the tank.)
power steering delete
exhaust mani if the header doesnt fit
redeye mounts - http://community.ratsun.net/topic/39780-620-ka24-motor-mount-brackets/
truck KA slave cylinder and hose  -  using what i already have
centerlink, ball joints, and tierods, end links, and sway bar bushings
reverse taper for flipped centerlink
new exhaust..... again
pathfinder accelerator cable
3 or 4 90 degree bends for the heater hoses
figure out radiator hoses
powder coating
figure out ECU mounting
nail down wire and relay routing for the wire tuck
fuel line clamps from a maxima (JY grab) and new high pressure fuel line
electric fans
electric fan controller
EGR delete - http://www.ebay.com/itm/261266445926
fuel pressure reg
theres probably more :/
got a few things purchased today thanx to parts sales over the weekend!!!
If this helps i used fuel pump part number E2000 from airtex, it is a Ford fuel pump. I mounted mines below the fuel tank right on the frame rail. Be sure to use the rubber isolators that come with it. If not it will be really loud.
For my radiator I'm using one from a 96 vw jetta. It has house outlets on the correct side too. It doesn't have a filler neck though, so i used one from a dodge Durango which is remote mounted. I was able to use a factory oem lower radiator hose from the 240sx with a just a little trimming.
And I'm only using a 14" fan on the front of the radiator. Absolutely NO cooling issues either even in 100+ degree weather and racing the truck at the drag strip!!
these should look pretty good behind my titans i guess....
just cant help myself sometimes
got these
5ADE3BAF-55F6-4985-8EBA-39EB1AC62AB7-147
and these hoses
9356172A-270F-42A8-ACE9-831CF9134463-147
and these
A1913011-C07D-4E9D-969B-4B3C56F86398-147
and these loaded calipers....
0CDD0C95-110B-40FD-94EE-2B96ED352867-346
guess its time for a rear disc brakes!!!!
these ^^^^
means this vvvvv
DD257DE5-06DD-4C59-AB1C-A9335162B338-503
SHOULD NEVER HAPPEN AGAIN
  • Like 3
