Round 2, FIGHT! - now with a DE in progress(for real this time...)
Eagle_Adam
  • Replies 2k
....ya....and probably not the last....
Sweet F'n score!! :thumbup:
ROTFL!
Well I've got the 2nd hardest part figured out!!
Leacaon signed up to help with wiring!!!
So all I really have left to figure out it a tranny mount, driveline, fuel pump, and regasket kit/timing kit.
  • Like 3
this was a dream.....
this is reality VVVVVV
this is just for my reference:
gasket kit
timing kit
Flip center-link
fuel pump( inline pump near the tank, with a filter between it and the tank.)
power steering delete
exhaust mani if the header doesnt fit
redeye mounts - http://community.ratsun.net/topic/39780-620-ka24-motor-mount-brackets/
truck KA slave cylinder and hose
centerlink, ball joints, and tierods, end links, and sway bar bushings
reverse taper for flipped centerlink
new exhaust..... again
pathfinder accelerator cable
3 or 4 90 degree bends for the heater hoses
figure out radiator hoses
powder coating
figure out ECU mounting
nail down wire and relay routing for the wire tuck
fuel line clamps from a maxima (JY grab) and new high pressure fuel line
theres probably more :/
lol .... which is why mine sits on a pallet gathering dust.......I got a sick a/t tranny if u wanna build a sleeper...seriously hough lots of the stuff can be cheap but theres still stuff u got to buy at sometpoint.... quiz redeye ... hes got a clean ka dohc motor swapped 620
so i re-read ur build today and couldnt figure out what trans you used......
there was a lot i was trrying to absorb so its there im sure.....
but can ya tell me anyway?
I have the 5 speed from the KA and was hoping to use it but have not been able to take measurements yet
Jjockitch had a left over Napz trans bellhousing ,, maybe he could throw that in your rig next time your up there...Switch it onto your existing trans,,, good to go
I think
this would be ideal, id like to keep the 5 speed thats in the truck for another project
gasket kit
timing kit
Flip center-link
powder coating
and right off the bat there is more...
electric fans and control box for them
im pretty sure stephen used the 720 trans from a z24 truck. i know he stuck with the B type box.
Yep I used the 720 trans. You will need to slot the cross member to fit the KA tranny, it isn't a huge amount though.
Get the Can/Am box it takes care of the fan relay and the fuel pump relay. It also ties them into the ECU to turn them on and off (pretty sure, still need to install mine).
Ok, ill have to read up on what it takes to put the KA trans in.
the canam box will be up to Laecaon, hes the one who opted in for the wiring help.
gasket kit
timing kit
Flip center-link
Airtex E1000 is the one I used (filter before the pump and a filter at the intake). Don't forget to pick up some high pressure fuel line as well as some OEM Nissan High pressure clamps (the clamps are free at PnP)
Can I have the hoses? :D
again keep the truck stuff
If you have a good exhaust guy he can tie a new down pipe into your existing exhaust easily.
I cut a couple stock ones up and used some repair couplers from the parts store to start with. I got my stainless tube with the 90 in it from summit and cut down the rubber hoses I had already.
powder coating
GREEN! :D
ooh there's the line and clamps, good call.
This is a pretty good list. Do you have a plan for flipping the center link taper? If I think of anything else I will post up :)
i dont yet, i noticed your comment about a local 4x4 shop doing it, was gunna look into that :D
thanx for your help
