Round 2, FIGHT! - now with a DE in progress(for real this time...)
Eagle_Adam
  • Replies 2k
Thank red!
Nismo dr stopped by to BS for a bit so I recruited his help. Found a vacuum leak, fixed it, then found a gas leak, then fixed it, then the piston inside the dome got stuck. So we took em both off, cleaned em and fixed em.
Now it idles!!!!! Kinda : p
Vid
http://i1356.photobucket.com/albums/q733/Eagle_Adam/79%20KC%20DD%20-%203rd%20times%20the%20charm/E6E3EFAF-E954-4173-B0AC-53413625113B-3381-000001C203CA3ED9_zps46c01f7d.mp4
Got the carbs dialed in enough to sync them and go for a drive!!
A67F8F76-BD62-4427-B48D-4E817CA81614-338
But then.....
E1E87CE6-FDF8-4ADF-BBC8-A431C0D21308-338
Ended up being the bolt behind the oil pump for the timing cover was loose... Seems to be a common theme in this build :/ but the oil pump got dropped and the bolt tightened down. No more massive leak! Oil pan gasket seems to be leaking too but it's more if a drop every few min instead of just pissing it out like before so I can live with it for now
i just don't like my undercarriage/ engine bay covered in oil.....
Oh well, i still have to drive to Eugene tonight to attend a B-day party i was roped into and pick up my new Can - O - Pee!!!!
