ArchetypeDatsun Posted October 13, 2013 Report Share Posted October 13, 2013 You found the one I had on my old ZX in my opinion those are the best looking air dams for the ZX where did you find yours at? Quote Link to comment
Ryoskatekov Posted October 13, 2013 Author Report Share Posted October 13, 2013 MSA sells em as "classic fiberglass Airdam" But they order it from some fiber-glass company so I'm not too sure of the origin. You found the one I had on my old ZX in my opinion those are the best looking air dams for the ZX where did you find yours at? Quote Link to comment
Ryoskatekov Posted October 15, 2013 Author Report Share Posted October 15, 2013 hmmm.... Dillema... I sorta want to go all out Wide body 295/50 on the rear 280zx, and at the same time I sorta want to stop doing shit to the body before all the panels become fiberglass...lol. 1 Quote Link to comment
Syncro Posted October 16, 2013 Report Share Posted October 16, 2013 Do it! Widebody ftw!!! Nothing wrong with fiberglass, do some hand formed bubble flares with foam and fiberglass. Quote Link to comment
Ryoskatekov Posted October 16, 2013 Author Report Share Posted October 16, 2013 Do it! Widebody ftw!!! Nothing wrong with fiberglass, do some hand formed bubble flares with foam and fiberglass. Currently I'm planning on buying a rear wide body kit from this "store" (Guna keep it a secret till I get enough money so no-one else can steal my master plan.) since I really love the way they shaped it. Its 4 inches wider so... Plan A: Total cost 1050 -Stay with the current wheel -2in spacers -295 or 275/50 R15 on rear for that meat stance. -widebody Plan B: Total Cost 1634 -Put some deep dish jeep aluminium wheels. they come in rediculous offsets without paying fortune. -1inch 4x4.5 to 5x4.5 adapter -295 or 275/50 R15 -widebody either way It's guna have to extend to next year since I'm broke - a - broke right now. Quote Link to comment
Syncro Posted October 16, 2013 Report Share Posted October 16, 2013 Personally don't like kits, if it ain't home grown, it ain't your own. Quote Link to comment
Fat510 Posted October 17, 2013 Report Share Posted October 17, 2013 have you thought about diamond racing steelies? the 15s go up to 10 inches wide Quote Link to comment
ArchetypeDatsun Posted October 17, 2013 Report Share Posted October 17, 2013 I know what wide body your talking about don't worry I won't share its a cool idea! Quote Link to comment
Ryoskatekov Posted October 17, 2013 Author Report Share Posted October 17, 2013 have you thought about diamond racing steelies? the 15s go up to 10 inches wide Eh, Thanks but no thanks. They're too damn heavy and funny looking. I know what wide body your talking about don't worry I won't share its a cool idea! oh darn. lol Its not IMSA btw. Hint hint. Hopefully that shop is still in buisness. Quote Link to comment
ArchetypeDatsun Posted October 17, 2013 Report Share Posted October 17, 2013 Yeah I knew you had something else in mind besides the IMSA one there are actually a few more there just not seen much. 1 Quote Link to comment
Ryoskatekov Posted October 19, 2013 Author Report Share Posted October 19, 2013 I suck at photoshop Quote Link to comment
Spoona_Jay21 Posted October 23, 2013 Report Share Posted October 23, 2013 I suprisingly think that looks good... Quote Link to comment
bludestiny Posted October 23, 2013 Report Share Posted October 23, 2013 You can fit 305's under rolled fenders in the rear..... Also "Stay with the current wheel" and "295 or 275/50 R15 on rear" will not work. You will probably not find a shop that will mount a 275 on an 8" wide wheel (I think that's what you have). You need a minimum of 10" wide for that width. Quote Link to comment
Syncro Posted October 24, 2013 Report Share Posted October 24, 2013 You'll be lucky to find a shop that'll even mount a 255, always complaining about sidewall stiffness for some reason too. Quote Link to comment
Ryoskatekov Posted October 24, 2013 Author Report Share Posted October 24, 2013 lol, Right now I have 225 and still rubbing. the wheel is 15x9. I guess It is a little too narrow to mount 275. maybe like 245 Quote Link to comment
Ryoskatekov Posted October 24, 2013 Author Report Share Posted October 24, 2013 Step closer to Z31 rear end. Quote Link to comment
bludestiny Posted October 25, 2013 Report Share Posted October 25, 2013 A 275 will fit on a 9" but will be bulged out like crazy. I picked up some 17x9's with 275 toyo RA1's on and they bulged, they just didn't looked right. A 10" would be better. You're probably rubbing because you have a crappy offset or bad spacer combo and stock suspension. When you lower the car you get negative camber which helps fit Quote Link to comment
Ryoskatekov Posted October 26, 2013 Author Report Share Posted October 26, 2013 A 275 will fit on a 9" but will be bulged out like crazy. I picked up some 17x9's with 275 toyo RA1's on and they bulged, they just didn't looked right. A 10" would be better. You're probably rubbing because you have a crappy offset or bad spacer combo and stock suspension. When you lower the car you get negative camber which helps fit Bad suspension for sure. But the only reason why I said 275 was because I sorta wanted that Racecar look If I were to Wide body it and 4 inches of extra fender is pretty damn hard to fill. My rub really isnt from offset (I dont use spacers. 15x9 -15) but from The 60 sidewall ratio and Old suspension components. Quote Link to comment
Ryoskatekov Posted November 2, 2013 Author Report Share Posted November 2, 2013 Started Z31 tail light swap. Its going okay so far. here and there there are parts that doesn't fit too well but It'll work out. The harness is already done. Just gotta make some fiberglass parts to fill up the hole. and also a bracket so the lights wont fall off. Doesn't seem to come up on ebay often. If I do get a welder and a grinder in the future, I might as well cut off the whole panel and put a Z31 one in. Quote Link to comment
Spoona_Jay21 Posted November 3, 2013 Report Share Posted November 3, 2013 that looks great! can't wait too see them once your done Finessing them on. Quote Link to comment
ArchetypeDatsun Posted November 4, 2013 Report Share Posted November 4, 2013 I seen someone do this once I think it looks good plus it's different haven't seen anyone else do it! Quote Link to comment
Syncro Posted November 4, 2013 Report Share Posted November 4, 2013 Wish your car had louvers. Quote Link to comment
Ryoskatekov Posted November 6, 2013 Author Report Share Posted November 6, 2013 Turns out, the place I was planning on buying the widebody, "Show car body parts unlimited" was a complete scam from research. Thank god I didin't have enough money to buy anything. So yeah, I guess I'd have to make my own kit If I were to. You happy Syncro? lol. Quote Link to comment
Syncro Posted November 6, 2013 Report Share Posted November 6, 2013 How were they a scam? I've heard things about their parts not fitting right, but almost all fiberglass parts have to be modified to fit good during installation. Quote Link to comment
Syncro Posted November 6, 2013 Report Share Posted November 6, 2013 To be honest though yeah, making your own kit should be nice, you can make your flares look exactly how you'd want them. I hate off the shelf body parts personally. Quote Link to comment
