Diggin the new Enkeis
  • Replies 15
  • 1 month later...
Lets expand on this a lil. Are any of the sizes/offsets even feasible??
I know I sound like a noob, but I've spent sooo many hours researching wheels, I'm bout to pull my hair out.
some say you can't fit 15x7 on zero even under flares, then I see pics where they fit just fine under stock.
jumps from 0 to 25 in the 7in grrrrrr
then i see people say 15x8 on zero with a little modding, but hate to order and not fit at all.
have 280zx shocks. 2 door.
don't pick my my 510 till next week so i cant just go measure.
here;s enkei size chart
http://www.enkei.com/size_chart/COMPE.pdf
15 x 7J +0 will be fine.
omg thank you, after everything that was my guess too.
no lie, you guys don't make it easy.
I totally understand there's variance due to ride height, what shocks you have, and so on.
but 350z's have a million more variables, and ranging size options, and still x10 easier too figure out.
When you see ads for parts, they mean stock cars. If you have 280zx struts, you have .75in less track width (per side) for deeper dish wheels. 4dr and 2dr rear suspension is the same. The issue you run into is you cant roll and pull as muh on a 4dr as you can on a 2dr. Otherwise anything that fits a 2dr will fit a 4dr. Wagon rear ends are different and require different spec wheels though.
  • 4 weeks later...
Why not pick up the et25's and then run a spacer to set them exactly where you want them?
cause your studs are only so long
7 inch rim.
+25 is for stock 510 struts fit front and back can slam car down
+12 or +15 will be Ok for 280zx struts and rears still fit fine in back
zero up front OK or really about perfect. rears might need to be rolled.
PS these Enkeis look good
  • 1 month later...
