Window runner/channel
Sierra
  • Replies 11
Those are Glass Run A (long peice) and Glass Run B (short piece).
For a 1977-1978 2-door sedan:
Nissan part numbers
80335-H5309 RUBBER-GLASS RUN A
80336-H5000 RUBBER-GLASS RUN B
You can also use generic Bailey Channel.
> ggzilla. How come there is two different sizes?
Nissan sells it in two separate pieces. Glass Run B is for the side next to the door hinge. The longer Glass Run A is for the other side and runs up an over the top of the glass too.
If you buy generic from Spectrum or Scotts, they simply cut generic to length and charge you. The corner is simply a 45 degree partial cut.
Only $30/side from Nissan.
Here is B110. B210 is the same but of course a different length and shape of glass differs.
Yes you do. get some weather strip adhesive from your local parts store.  read and follow directions.   be careful, as it is messy and very sticky.
for removing adhesives with out eating away at your paint...  here is a trick.    Grease and wax remover   Or   Lighter fluid.. easier to get a hold of and tons of uses.
the main ingredient in Grease and wax remover is Naptha.   (lighter fluid)   but dont use the G/W remover in your lighter  :)
