PRICE CHECK on robello built 2150 complete running setup
Looking for a price check on my current motor.
Robello built z20 block bored to 2150.
Head was just redone last year, maybe 200 miles on it.
44 mukinis
nissan comp header
nissan comp oil pan
oil spray bar
280zx 5 speed
lightened flywheel with kevlar clutch
*have a spare long block just like it that needs to be rebuilt.
Going to run a KA and would like to sell the complete setup to fund the swap.
Motor is currently running in the car, though my fuel pump is acting up.
8A5888A0-AF08-4A10-9792-73E41F517C64-181
550EC77B-3E34-4D85-9191-FF8741985F33-181
38AC52B4-6983-4D0A-96EC-655E953EFE8E-181
499EDF6F-E93A-4407-AB12-277170DC4804-181
  • Replies 21
thanks for the thread jack asshats, so much for a price check
What is this shopright?
Its a for sale thread, rule #1 reads..
1/ The item for sale MUST have a price on it. Auction style postings will not be tolerated.
So list a price and w/e someone agrees to is what its worth, very easy.
I thought it showed on my name, Bay Area, California
it does not show up on Mobil devices but will on a home or laptop computer
not sure what your motor is worth, what head is on it
estimation on used motor 1500
No this is a price check thread. it if is in the wrong section, MOD please move. Every forum im on has a price check that people do before posting for sale to eliminate wild ass postings. IF that is not done here or not the community then I will delete and go about my merry way.
i know its a long rod, but as for the bore and stroke and what the rods/pistons are…. Rebello keeps those to himself. They are not publicized as to avoid other making the same engines and Dave no longer having a business. He did some head work last year, valve job, etc and stating that it is a head he did. Port and polish etc, and that the cam in there is the biggest they make for that motor. Thats about all i got out of him.
<p>Ah, I get the trade secrets. Well an 85mm bore block has an upper limit to how far it can be bored. You say long rod so that kind of limits a stroke increase. Z20E rods, Z22 pistons on Z20 crank and block. Nice. Well balanced high revving crank and rods with a slightly larger bore. Probably a U67 head Can you look between the #1 and #2 spark plugs...<br />
<br />
<img alt="710stuff010Large.jpg" src="http://i138.photobucket.com/albums/q251/datzenmike/L%20Z%20Heads%20and%20Motors/710stuff010Large.jpg" /></p>
<p> </p>
<p>A good rebuild will cost about $1,500 minimum... and that's if you supply the block and head. So buying a complete motor rebuilt and ready to go Probably $1,800. Then it needs a cam and valve train and an intake and multiple carbs, header likely... so another say $1,200 +. Say $3K ish.</p>
<p> </p>
<p> </p>
<p>IE dizzy, alternator, zx 5 speed, starter, flywheel and clutch all extra.</p>
<p> </p>
<p> </p>
<p> </p>
Yea ASSHAT!! you need to post on the PRICE CHECK thread; this is the FOR SALE thread :devil: .
