A10's U-nite !!!!
Crank pulleys? Maybe a dozen removed. I just used the 26mm socket and tapped forward on the back. Some jumped right off some took 40-50 taps but they always were moving and gradually came off.
Steering wheels? Loosen nut but leave on the last two turns. Strike back sides towards you with palms. Turn head just in case so you don't loose teeth. Never used a puller but only because I don't have one.
  • Replies 4.1k
I have removed too many crank pulleys to count. 300? 400?
Normally they all come off with ease. But there are always the few that don't.
Yes. Leave a thread or two on-even if using a puller.
I have a scar on the outside of my lower lip from my lip being squeezed between my teeth and a stubborn wheel.
Paint a rising sun flag on the roof and "Oi" on the doors.
Do I see a set of turbines in your future?
i might be seeing a pair of KC Apollos in my cart :)
http://4wheelonline.com/Apollo_DIY_Long_Range.150080.539939#
NO, because Warthog
Edited by Fat510
