converted_to_datsun Posted November 3, 2012 Report Share Posted November 3, 2012 So my truck had the tailgate welded shut and I cut it open and got a new tailgate cause I wanna use it as a truck. So onto my question... I've heard from a few people you can relocate the latches to the inside. Anyone have pics? I wanna see everything including the piece that the latch grabbs to latch shut Here's some pics cause we all love oic's Welded tailgate Cut open New tailgate Quote Link to comment
Dat Lurka Posted November 3, 2012 Report Share Posted November 3, 2012 I've thought about relocating to the inside. I just thought of a great idea. I'll share it when I draw it up. Quote Link to comment
converted_to_datsun Posted November 3, 2012 Author Report Share Posted November 3, 2012 Cool sounds good dude. I I've heard a couple ideas and skib had a truck where it was done. Quote Link to comment
Dat Lurka Posted November 3, 2012 Report Share Posted November 3, 2012 I'm basically thinking slide latch mounted under the bed lip. Basically this Mounted so that gravity holds the "handle" in the forward slot when latched. Tada. Quote Link to comment
Dat Lurka Posted November 3, 2012 Report Share Posted November 3, 2012 Or even better Quote Link to comment
Dat Lurka Posted November 3, 2012 Report Share Posted November 3, 2012 My latches are totally rusted out and sloppy. Quote Link to comment
converted_to_datsun Posted November 3, 2012 Author Report Share Posted November 3, 2012 I like the spring loaded one! I could make it almost completely hidden. I have the peice that covers the back of the tailgate too Quote Link to comment
Dat Lurka Posted November 3, 2012 Report Share Posted November 3, 2012 Yeah I was thinking mount it on the back with the handle through the gate or just put it under the hooks. Quote Link to comment
sedition88 Posted November 3, 2012 Report Share Posted November 3, 2012 I'll have to find it again, but I've seen someone take the stock latches and put them on the back side of the tailgate. Quote Link to comment
Llittle_Llama Posted November 3, 2012 Report Share Posted November 3, 2012 The spring loaded one looks pretty neat, I like the idea of mounting it in the backside! Quote Link to comment
datzenmike Posted November 3, 2012 Report Share Posted November 3, 2012 Take a latch off and place it on the inside top lip. When you got the tailgate you probably didn't get the other end on the box that the latch slides into. Should be easy enough to weld something in there. Those other latches look like shit. A fence staple and a bent nail would be just as good. You can do this, so make it right. You'll be glad you did every time you look at it. 1 Quote Link to comment
Farmer Posted November 3, 2012 Report Share Posted November 3, 2012 A few members have done it before, but these guys, I think, did it the cleanest. Fontana620 and I believe the other one was Figbuck. Find their build threads. Also need to remember, the stock latch grabs a hook type nub and pulls the bed corners inward to secure the tail gate. Those latched your showing, just blocks the tailgate from opening. Larry Quote Link to comment
wayno Posted November 3, 2012 Report Share Posted November 3, 2012 I have seen seatbelt buckles used on the inside, they were mounted in such a way that when you shut it they just latched, but when you opened it, you had to push the botton on both sides. When I think about it right now, it seems like something would have to stick up for it to work though. :crying: Seems like if it stuck up, it could get bent, but these were classic trucks that never hauled anything anymore. Quote Link to comment
