high winder Posted October 23, 2012 Report Share Posted October 23, 2012 glad to find a site that has some folks who know a little about datsuns.. i have a 78' b210 that i've had about 8 yrs. i just rebuilt the motor for it and am working out a few bugs with timing,carb, etc. the next step is to do some body/paint work, just replaced the front and rear floor pans and what a PITA it was.. anyways thought i'd say hello and when i can get our home puter to load a pic i'll get some posted. regards, highwinder Quote Link to comment
datzenmike Posted October 23, 2012 Report Share Posted October 23, 2012 Welcome aboard. We have lots of B-210 and 310 owners here. Lots of info on the A series motor and swaps to make it even more fun to drive. Quote Link to comment
Draker Posted October 23, 2012 Report Share Posted October 23, 2012 How's about you post a picture or two? Welcome! Quote Link to comment
Skib Posted October 23, 2012 Report Share Posted October 23, 2012 where in OR are you? more pic demands in 3... 2... 1... Quote Link to comment
INDY510 Posted October 23, 2012 Report Share Posted October 23, 2012 MOAR PICS!!!! 1 Quote Link to comment
high winder Posted October 23, 2012 Author Report Share Posted October 23, 2012 i'm in the roseburg area..i can take pics, the home puter has issues with my digital camera so looks like i'll have to do it at work Quote Link to comment
high winder Posted October 24, 2012 Author Report Share Posted October 24, 2012 Quote Link to comment
Sierra Posted October 24, 2012 Report Share Posted October 24, 2012 Good looking B. Tech included a plus. Btw i have the same floormats :) Quote Link to comment
izzo Posted October 24, 2012 Report Share Posted October 24, 2012 Omfg a tach!!! Did the tach come in the car?? Quote Link to comment
high winder Posted October 24, 2012 Author Report Share Posted October 24, 2012 the tack was in it....and it works like a champ :thumbup: the floor mats were a big buying plus and helped me make my decision. with the rebuilt engine i'm getting about 29 mpg but can't seem to get the carb dialed in puurfect, i had it bored .20 over and wonder if that has anything to with it. Quote Link to comment
king bee66 Posted October 25, 2012 Report Share Posted October 25, 2012 The weber will diminish the economy as well Quote Link to comment
ggzilla Posted October 25, 2012 Report Share Posted October 25, 2012 A .020 overbore won't make a lick of difference, just adds about 18 CCs to the engine size (less than 1.5% change). It is a cleanup method for unusually worn cylinders, and won't affect the carburetor. 29 mpg is about right a stock Weber 32/36. You can fine-tune the weber to increase the fuel economy, should be able to get 35 mpg by leaning out the main jets. Quote Link to comment
high winder Posted October 25, 2012 Author Report Share Posted October 25, 2012 i've been tinkering with carb and just haven't been able to get it quite right following the tune up methods i got off of redline.. the lean just doesn't seem to make it run rich or lean within the two turns they stated in the instructions..i will turn it out a little more and see what happens. maybe i should look into readjusting the valves Quote Link to comment
ggzilla Posted October 25, 2012 Report Share Posted October 25, 2012 Yes, the two turns are simply the initial adjustment. With a running fully-warm engines, you must go however many turns it takes. If you turn the screw all the way in, it will lean out and die. If it doesn't do that then you have a vacuum leak. Note that this will not change the "running rich" condition that affects fuel mileage. That requires a jet change. The adjusment screw is only for the idle and off-idle. Adjusting the valves will not change rich/lean. Quote Link to comment
high winder Posted October 25, 2012 Author Report Share Posted October 25, 2012 okay thanks...thats makes sense i do some more tuning Quote Link to comment
